I got 404 Not Found from Mapzen Shutdown :( · Mapzen
I assume one has to sign up with Bing maps to get the keys.
Geoff
Geoff
because they shut-down
https://mapzen.com/blog/shutdown/
Ah, so that map option is defunct now then ![]()
Geoff
Silly question, I love the naming of your distance rings. Where do I put that code?
script.js can be found in the folder
/usr/share/dump1090-fa/html
Reinstalling dump1090-fa will overwrite the files in this folder with originals in case you screw it up.
An alternative to reinstall:
First create a backup copy of file you are going to edit
cd /usr/share/dump1090-fa/html/
sudo cp script.js script.js.orig
Now edit the file
sudo nano script.js
If you screw up the file, replace it with a fresh copy from backup
#Delete screwed up file
sudo rm script.js
#Create a fresh copy from backup
sudo cp script.js.orig script.js
On my old setup I could see my polar chart, how do I get this back, I am using version 3.6.3 dump1090-fa, I’m sure it will be something very simple that I have forgotten to do
That looks the coverage map of virtual radar server? At least vrs has the ability to create such a map, but you’ll have to install and configure it to read your feeders output.
It is also possible to create a coverage map directly in Skyview, I think it is included in the customisations @alkissack developed. You’ll have to edit some files and add/copy code.
If you are also feeding Planefinder there is one located at http://pi:30053/
EDIT: and click on the P button at the top left to toggle Polar Range Chart
Is there a way to turn on the history tracks for aircraft? I thought I found settings for it, but I’m still not seeing them. The old UI had a button to toggle the track lines. I don’t see a settings button on this new UI. Am I missing something?
Which UI do you have now? There should be a “show all tracks” button in the top right.
There was that button on the UI that came with PiAware. I switched to the one that’s being talked about in this thread (GitHub - alkissack/Dump1090-OpenLayers-html: Modifications to the Openlayers html files (part of the dump1090-fa branch)).
It appears there is one option for showing the track for the selected aircraft, then there is a button to select all aircraft, which essentially gives me what I was looking for.
Someone asked for help in this thread.
I installed Al Kissack’s web files and it works for me, but I have a question.
How/where do you change the settings so the aircraft are colored by altitude. I read the instructions on Al’s Github, but I wasn’t able to understand what to change. I found the reference to AK9C to be rather cryptic. I found that section in planeObjects.js, but didn’t know what to change.
Thanks!
Hi
I wonder if someone can help me
I have renamed my /usr/share/dump1090-fa/html folder
I have copied the files from Alkissacks Dump1090 OpenLayers public_html folder into /usr/share/dump1090-fa/html
I have then cleared my browser cache (many times) but I still dont see any of the UK Airspace options
I still see the US options
Any ideas what I might be doing wrong
I’m running PiAware 6.1
Graham
Hi
All sorted now - was copying files to the wrong directory
Copied them into /usr/share/skyaware/html folder and all worked
Graham
