How do I enter the correct location for my Receiver ?.
https://flightaware.com/adsb/stats/user/FrancisHShortall
Orange bar —> right side → cog wheel.
Be very exact with the position for the MLAT system.
The receiver/local map will get the position from Flightaware automatically after that.
If it doesn’t go fast enough for you, just reboot it.
Is your home location exposed if you are “very exact”? I picked a nearby intersection for my MLAT location.
No, flightaware doesn’t even show the exact position on your local map unless you change a dump1090-fa setting.
On the webpage you can’t even make it display an exact position, it’s always rounded.
You can chose to round to full degrees even.
From the stats page where you also configure you location:
Precision on Coverage Map ( )Exact ( )1 km ( ) 10 km
(exact didn’t work last time i checked bu it’s not what you want anyway)
Just open your own stats page in incognito/privat browsing mode and you should see what others see.
You are lucky that your MLAT is even working
Anyway set it to 10km if you are concerned about it.
Many Thanks, Sorted.
Frank S.
Right on cue, xlcd provides perspective
