Never used wi fi with any of my RPI versions. I am currently using the above OS. Do I need to re flash a SD card with ??? to switch on the Wi Fi. I need to put a PI4 up on a masthead enclosure and have run out of network cables, so, give wi fi a go.
I have been doing some searching since my post, will this link in regards to setting up wi fi work with the debian buster lite I am currently using?? (not looked at you link yet)
For anyone that might be using Wi - FI, from looking at the documentation and Googling off that, there appears to be some problems with the RPI 4 and wi fi distance, anyone having such distance problems from their router, this might throw a spanner in the works for what I am planning.
Thanks all. Didn’t have to use config before 1st boot but thanks for that link. Have now confirmed one of my masthead RPI 4’s is now working on Wi - Fi. Thanks for your replies. Config’d via sudo raspi-config. Now I read somewhere today with these PI4’s that if you connect a network cable, it will turn off the Wi - Fi automatically … true or???
