Raspi Pi gear required
Yes that is correct - N Connector male for the antenna, and SMA connector male for the dongle.
thanks Caius, ordered :slight_smile:
quick question for a possible future installation - at the moment I’m running with a 50ohm cable as suggested further up the thread. Is there an advantage to that over a 75ohm RG-6 Quad Shield Co-Ax cable ?
LMR400 is far superior to RG-6.
LMR240 is significantly better than RG-6.
LMR200 or CFD200 is also better than RG-6. (not sure how much better)
Just look up the attenuation at 1 GHz/ 1000 MHz.
That should be listed in the datasheet.
Less per 100ft is better. Note that it’s sometimes listed per 100m.
Hi Wiedehopf
Thanks that’s all I needed to know !
What’s your current setup including antenna, cabling and receiver?
Your stats don’t look too promising, but it might be the terrain. Not bad either though :slight_smile:
What is the Maximum Range I can Get?
You might benefit from a filter after all: Amazon.com: ADS-B Dual 978 MHz + 1090 MHz Band-Pass SMA Filter : Electronics
You might even consider using the current stick for the future installation and replacing your current setup with this combination: Useful items for purchase · wiedehopf/adsb-wiki Wiki · GitHub
The LNA has very good filtering already built in.
it’s because of where it is situated, I have no choice at the moment but in the future I may do hence trying to do the homework on the cable
If you add an amplifier (LNA) at the antenna, you can use the cheaper RG6 cable after that. I am using a 45 meter RG-6 cable.
