Unfortunately it won’t just be a case of buying one and swapping out an existing Pi because this new one is now powered via a USB-C connector and it requires a 3 amp PSU.
I will get one but not straight away. The only Pi I have which might benefit from the higher performance is the one mounted outside at the top of my mast that’s running my feeder and getting a decent power supply to it was a challenge at a couple of amps. Replacing it with a Pi 4 would require a lot of extra work.
Maybe also better to wait and see how much cooling it needs before putting it in an enclosure outside.
My first impression is that the changes make it more useful as a desktop replacement or small server, but not necessarily as a headless feeder. Maybe for an airspy set up with -m 20?
Actually that’s a valid point - There’s also an official micro-USB to USB-C adapter. Somehow, one of these new boards ended up in my shopping basket and then the checkout button was pressed. The DC-DC converter I’m using is rated at 3A (heatsinked). Whether I swap it or not, it’ll be interesting to fire it up and see how well it works and whether the existing software is all compatible with the new OS.
USB3 & a more reliable USB controller are pretty attractive; I suspect this will work better for anyone that’s trying to drive significant USB traffic (e.g. Airspy…)
nb: the piaware 3.7.1 sdcard is unlikely to boot on a Pi 4, but the next release should pick up whatever bootloader changes are needed.
That’s what I picked up on and is largely the reason I’ve ordered one, despite saying earlier that I wasn’t that interested in swapping mine out from the washing line!
I’ll build from Buster Lite anyway so this shouldn’t be an issue for me.
I’ve just run up Buster on a Pi3B+ and all the FA stuff seems to be working perfectly. I installed Piaware, PiAware-Web and Dump1090-fa and everything worked.
Funnily enough, just for the hell of it, I’ve just written a new Stretch Lite image and am going through the process to update to Buster just to see if it works. There’s nothing else on it but I’ve not done an update like this before. I won’t use it for anything, I’m just doing it to see if I can.
When it comes to card writing, it’s all about Etcher (BalanaEtcher) for me.
My upgrade worked fine, but as i chose to keep my own configuration files i had to fix some of them.
You are asked if you want the old or the new configuration file if it has been modified.
If you don’t know about the config file it’s probably best to install the new version and not keep the old (keeping the old one is the default).
During the update systemctl and journalctl stopped working, that was quite alarming.
But after the update ran its course, they went back to normal
Also i have quite some packages installed for building dump1090, dump978 and piaware.
That’s quite a few packages to upgrade.
Mine has arrived and this is definitely going to need some cooling if I mount it outside because the CPU is sitting at 59°C while it’s just idle on the desk in my shack.
