Piaware upgrade from Raspberry Pi 2B to Raspberry Pi 3
Hi guys,
I just spent the afternoon on my Antenna mast and installed the FlightAware Antenna, the results are amazing !
However, some closer to the Antenna flights sometimes disappear and I was wondering if my " old " Pi2B was not under too much load due to the new data being fed as such a huge rate.
Would moving to a Pi3 really help to compute " faster " and miss less flights ?
What would be the process to move a perfectely working Pi2 setup to a Pi3 ?
Thanks a lot !
i run pi2 without any issue cpu-wise up to 300-350 aicrafts in parallel and mlat active. so i think a new pi isn’t necessary :slight_smile:
p.s. the close to antenna aircraft problem looks more like to have a too high gain setting and higher gain antennas are more blind overhead than those with low gain.
Hi TomMuc,
Yes indeed, I did a monitorinbg using the " top " command and saw that my Pi2 is only using about 40/45 % CPU and there is plenty free RAM.
