did all above still nothing
print out of airspy_adsb no 30005 ??
pi@rpi4-20210823:~$ apt-cache policy dump1090-fa
dump1090-fa:
Installed: (none)
Candidate: (none)
Version table:
4.0 -1
100 /var/lib/dpkg/status
pi@rpi4-20210823:~$ apt-cache policy piaware
piaware:
Installed: 5.0
Candidate: 5.0
Version table:
*** 5.0 100
Something gone wrong. First remove existing files & folders of dump1090
sudo rm dump1090-fa*
sudo rm -rf dump1090
Now issue following commands.
git clone https://github.com/flightaware/dump1090
cd dump1090
git fetch --all
git reset --hard origin/dev
sudo sed -i 's/dh-systemd,//' debian/control
sudo dpkg-buildpackage -b --no-sign
What are last few lines of output of last command? Does it say dump1090-fa package is built?
What is output of following command?
ls /home/pi/
pi@rpi4-20210823:~$ ls
Desktop Templates dump1090-fa-pkg-4.0 piaware-web_5.0_all.deb
Documents Videos dump1090-fa_6.0~dev_arm64.buildinfo piaware-web_5.0_arm64.buildinfo
Downloads airspy dump1090-fa_6.0~dev_arm64.changes piaware-web_5.0_arm64.changes
Music airspy_adsb-linux-x86_64.tgz dump1090-fa_6.0~dev_arm64.deb piaware_builder
Pictures dump1090 piaware-repository_5.0_all.deb tcltls-rebuild
Public dump1090-fa-dbgsym_6.0~dev_arm64.deb piaware-web
pi@rpi4-20210823:~/dump1090$ ls
COPYING anet.h cprtests.c demod_2400.o interactive.c sdr.c sdr_limesdr.o track.o
Jenkinsfile anet.o cprtests.o dsp interactive.o sdr.h sdr_rtlsdr.c util.c
LICENSE bladerf cpu.c dsp-types.h mode_ac.c sdr.o sdr_rtlsdr.h util.h
Makefile comm_b.c cpu.h dump1090 mode_ac.o sdr_bladerf.c sdr_rtlsdr.o util.o
Makefile.cpufeatures comm_b.h cpu.o dump1090.c mode_s.c sdr_bladerf.h sdr_stub.c view1090
README-json.md comm_b.o cpu_features dump1090.h mode_s.h sdr_bladerf.o sdr_stub.o view1090.c
README.md compat crc.c dump1090.o mode_s.o sdr_hackrf.c starch view1090.o
adaptive.c convert.c crc.h faup1090.c net_io.c sdr_hackrf.h starch-benchmark wisdom
adaptive.h convert.h crc.o fifo.c net_io.h sdr_hackrf.o stats.c wisdom.aarch64
adaptive.o convert.o debian fifo.h net_io.o sdr_ifile.c stats.h wisdom.arm
ais_charset.c cpr.c debian-jessie fifo.o oneoff sdr_ifile.h stats.o wisdom.generic
ais_charset.h cpr.h debian-stretch icao_filter.c prepare-build.sh sdr_ifile.o tools wisdom.x86
ais_charset.o cpr.o demod_2400.c icao_filter.h public_html sdr_limesdr.c track.c
anet.c cprtests demod_2400.h icao_filter.o public_html_merged sdr_limesdr.h track.h
dump1090-fa:
Installed: (none)
Candidate: (none)
Version table:
4.0 -1
You have this package built, but architecture is arm64, while my case was armhf, and installation command i told you was for armhf
Install it with command with correct architecture (arm64)
sudo dpkg -i dump1090-fa_6.0~dev_arm64.deb
SkyAware unknown version
so correct version now editing conf now i think
as im running 64bit i only got _adsb not aarch64 so will add that now
Now not sure which install i need for aarch64
could you point me in correct direction please
many thanks
john
The script has built for correct architecture arm64 for RPi model 4
(for my RPi model 2 B, architecture is armhf).
Skyaware will show “unknown verion” initially. To fix it:
(1) Reboot Pi
(2) Clear browser cache Ctrl+Shit+Delete
(3) Reload browser Ctrl+F5
Why you want aarch64 install when your RPi Model 4 has architecture arm64?
The dump1090-fa ver 6.0~dev package is correctly built for arm64. Simply install it by command I have given in my previous post.
yes your right
i understand now arm64 cool
cleared cache and rebooted twice still no versions on -fa or skyaware also no aircraft
First install rtl-sdr
sudo apt-get install rtl-sdr
Next run following command. What is output of last command?
sudo systemctl stop piaware dump1090-fa
rtl_test -t
pi@rpi4-20210823:~$ rtl_test -t
No supported devices found.
this would be correct as im on airspy ?
pi@rpi4-20210823:~$ sudo systemctl stop piaware dump1090-fa
If you have a prostick or dvbt, remove airspy and plugin prostick and see if dump1090 and skyview start working ok
Hmmm dark blue no its not working on -fa or skyaware
still nothing after reboot
ok i now have darkblue donlge plugged in with v6 ident
but airspy mini when plugged in dont work
If dump1090-fa ver 6.0~dev and skyaware are working ok with prostick, that means they are ok.
May be you need something extra to do to make it work for airspy. Ask this in airspy thread. I have no idea about airspy mini. I dont have one.
ok thankyou ..............
no planes with any dongle
will go repost
What is output of rtl_test - t with prostick pluggedin? This is important.
LATER ADDITION:
As you have posted in other thread it is showing error3, I have posted solution few days ago here:
After above, unplug then replug prostick and then reboot Pi.
