pi@raspberrypi:/ $ sudo dpkg -i piaware-repository_7.2_all.deb
Selecting previously unselected package piaware-repository.
(Reading database … 59764 files and directories currently installed.)
Preparing to unpack piaware-repository_7.2_all.deb …
Unpacking piaware-repository (7.2) …
Setting up piaware-repository (7.2) …
pi@raspberrypi:/ $ sudo apt-get update
Get:1 Index of /raspbian buster InRelease [15.0 kB]
Hit:2 Index of /debian buster InRelease
Hit:3 http://repo.feed.flightradar24.com flightradar24 InRelease
Get:4 http://flightaware.com/adsb/piaware/files/packages bullseye InRelease [1,860 B]
Get:5 http://flightaware.com/adsb/piaware/files/packages bullseye/piaware armhf Packages [6,366 B]
Fetched 23.2 kB in 2s (10.8 kB/s)
Reading package lists… Done
pi@raspberrypi:/ $ sudo apt-get install piaware
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
piaware : Depends: libboost-program-options1.74.0 (>= 1.74.0) but it is not installable
Depends: libboost-regex1.74.0-icu67 but it is not installable
Depends: libc6 (>= 2.29) but 2.28-10+rpi1 is to be installed
Depends: libffi7 (>= 3.3~20180313) but it is not installable
Depends: libgcc-s1 (>= 3.5) but it is not installable
Depends: libmpdec3 but it is not installable
Depends: libreadline8 (>= 7.0~beta) but it is not installable
Depends: libstdc++6 (>= 9) but 8.3.0-6+rpi1 is to be installed
E: Unable to correct problems, you have held broken packages.
Looks like you missed the bit in point 1 where it says " Raspbian Bullseye or Bullseye Lite OS installed"
You seem to have buster.
Follow the instructions @wiedehopf has posted to hopefully recover.
If you already have a feeder ID, do NOT claim as above. Instead configure piaware with it by following command
(Replace xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx by you actual feeder-d
Does the file piaware-repository_7.2 ~ bpo10+1_all.deb differ from this file I allready had downloaded: piaware-repository_7.2_all.deb?
I only use raspberry to my weatherstation and feeding FR24. Don’t know much about debian, linux and all the other - I know much more about dos and windows!
I just have to try to read a bit about MLAT and a possible solution.
You have done an excellent job. Maybe you should make a little guide about these hints - in the same way as your very excellent guides in the FR24 forum
Please also post config of fr24feed as you are using Pi24 image. In Pi24 image, fr24feed controls decoder
(When posting here, replace fr24 key by xxxxx for privacy reasons)
