As a newbie I had some trouble sorting this, so I am setting out the steps that FlightAware and others on this forum showed me. Basically the PiAware SD image will not work on the Pi 4, as it needs updating. However, PiAware can be installed successfully using the command line in Raspbian Buster.
You need to type the following lines. Each needs to be loaded with the Enter key:
Thanks for this tuto !
Is it possible to change the “piaware-repository_3.7.1_all.deb” with the “piaware-repository_3.7.2_all.deb” version, or is it not working with a Pi4 ?
That’s actually incorrect.
Only the repository will have that version.
Due to the repository changing he will still have installed the latest dump1090-fa / piaware version. (try i dare you! )
I dont understand if this is the case, then why the repository package is versioned like piaware-repository_4.0_all.deb? It can be versionless like piaware-repository_all.deb
I’m not certain either … at least having a link that redirects to the most current package would be great. (versioning is kinda required for debian packages and there are changes like renewing the key for the repository and stuff)
I got my pi 4 today and I can’t seem to get flightaware to work , it works fine on my older 3b , I’ve done the code but no matter what it doesn’t work , have I missed something
