I can’t seem to install Piaware and I don’t understand why the piaware software ‘appears’ not to have an OS installed?? If I follow the piaware guide, when i boot the Pi the green light goes on for a couple of seconds, then stops.
So I have tried booting with Raspbian Buster. Neither add/remove or the command line finds piaware. I have tested the dongle and it is working.
I am clearly doing something wrong or missing something - help!!
Thanks for your help, I have to get my head around Pi after a couple of years away! PiAware now installed, claimed, but unfortunately I don’t appear to be picking up anything. I know I am in a ‘quiet’ area (near Mildenhall and Lakenheath)…
wiedehopf - the updates did the trick, and the dump1090 command shows data. Skyview does too, although the map opens in southern Italy!
foxhunter - correct time/date are correct in raspbian desktop. no idea about location… Dongle is a FlightAware Pro Stick Plus 1.0
I was hoping to pick up STN movements, the airport being only 40 miles away, but I’m getting nothing from that direction.
Interestingly I sent a support ticket to FlightAware and I got a reply stating that Piaware does not work with the Pi 4. He thought it might be introduced at the update after next! There is at least one Pi retail outlet that is selling FlightAware as a package with the Pi 4.
For completeness, there are a few things going on here:
The prebuilt piaware packages are built against Stretch and are likely to have problems if installed on a Buster system
Building piaware from source should build and run OK on Buster
The piaware sdcard image (different to the prebuilt packages! Yes, it’s confusing) is based on Stretch
The Pi 4 hardware requires a kernel and boot firmware that is only available for Buster - so the PiAware sdcard image won’t work on a Pi 4.
It’s possible to run 3.7.1 on a Pi 4 / Buster install but you will need to build from source.
The next release, 3.7.2, won’t change this; the surprise distribution update happened too late in the piaware release cycle and right now we just want to get 3.7.2 out the door. 3.8 will have Buster support.
No idea what the prepackaged kit includes; this is a third party thing that we don’t have any visibility into.
The pre-built Stretch packages for piaware and dump1090-fa seem to be running just fine on Buster.
I can confirm it myself for piaware, not for dump1090-fa.
But i’m pretty sure after the kernel problems had resolved themselves multiple people reported that dump1090-fa was running just fine.
On Raspberry Pi / Raspbain Buster, the package install has no problem of any sort, not even dependencies.
On OrangePI PC / Armbian Buster, the package install has problem of dependencies. I simulated the installation as if it is on Stretch by changing apt source from Buster to Stretch. Even after that, I had to manually install Recommended dependencies
I didn’t have to make any changes to piaware or dependencies when I upgraded from Stretch to Buster. I ran dump1090-fa for a month or so with no issues with an rtl dongle and now in network only mode with airspy.
The only issue I had was relating to the mlat client in use by other feeders where I had to manually update a library. Piaware mlat didn’t have that issue however.
