I added a new Raspberry with dump1090 and PiAware 3.5.1 to my account some weeks ago and have a problem with the position displayed on FlightAware (I already have two other Pis with identical settings at different locations which work without any problems): If I enter the coordinates in the “My ADS-B” section they are saved and it says “Location Source: User entered”, but after some minutes the Coordinates are set to (0, 0) and it says “Location Source: Receiver”. Can anyone tell me how to either switch off the transmission of the coordinates or set the correct coordinates in the Raspberry Pi?
Yes I clicked “Safe”. After I clicked the save button the correct coordinates appeared in the overview, but only for a few minutes until they were overwritten by the wrong one by the system.
I have not installed and used dump1090 Malcom Robb recently, but about 2 years ago when once I installed it, I created a file dump1090.sh to start it at boot.
sudo nano /etc/init.d/dump1090.sh
I dont know exactly what you have done, but If you also have created this file, add to above line following: --lat xx.xxxx --lon yy.yyyy
so that the line becomes:
@quis777 why don’t you simply use the flightaware sd-card image. it is super-easy to install/config and delivers perfect results as dump1090-fa is way better than the old malcomrob flavor …
I don’t use the sd-card image because I also use my Pi for other stuff than feeding, therefore I need/want the Raspbian. But I changed to dump1090-fa now, which didn’t change anything, the same problem still persists.
After sudo dpkg --purge piaware command, all configuration will also be purged, including Unique feeder identifier UUID.
If you dont want to retain existing station number “SITE 67827”, then click this link while logged-in to your FA account and you will get a new Station number: http://flightaware.com/adsb/piaware/claim
