PiAware sees no aircraft
Hello,
I have just set up a PiAware using a DVB stick and one of those tiny little aerials (cut to correct length) that I know are not great.
I am currently building myself a collinear coax antenna but I have the PiAware set up with what I currently have available.
The issue is I notice that despite living right below a flight path my PiAware sees zero aircraft.
I set the system up following the procedure on the PiAware website on a Raspberry Pi 3, it has wifi access. When looking at my own local statistics on my home network I can see that the PiAware knows if I unplug the DVB - it says ‘AJAX call failed (error: Not Found) Maybe dump 1090 is no longer running?’
So I presume that the DVB is set up and working - is my presumption correct?
Is there some way of knowing for sure?
I would like to have at least seen at least some aircraft before having to wonder whether it’s my homemade antenna or not…
Charlie.
What DVB stick exactly? Some rtlsdr-compatible dongles have tuners that can’t reach 1090MHz. You need one with a R820T or R820T2 tuner.
Hi obj,
I wondered that too, I recall that it I had it operating and seeing aircraft a few years ago, and have just started to get back into it again.
It looks exactly like that one in the top right here: ADS-B dump1090 - Though I know that doesn’t actually mean much.
I pulled the cover and the RTL chip is labelled RTL2832U - I am caused to think that it can tune between 500kHz and 1.7GHz.
Thanks,
Charlie.
There are two chips in a DVB-T
The Tuner chip is R820T
The dongles which have (RTL2832U + R820T), are OK for 1090 Mhz
The dongles which have (RTL2832U + FC0012), are NOT OK for 1090 Mhz
Chip FC0012 is not Realtec. It is Fitipower.
You can see this in the output of 2nd command below
## Install test software rtl-sdr
sudo apt install rtl-sdr
## Stop piaware & dump1090-fa to free the dongle for test
sudo systemctl stop piaware dump1090-fa
## To test your dongle, give following command
## Output will show the tuner chip found
rtl_test -t
Thanks abcd567,
That’s it, FC0012, no work around?
Charlie.
Unfortunately no workaround. Return it to the seller if possible, and purchase another one with chips RTL2832U + R820T (or better R820T2)
I didn’t see that test initially, I was just reading off the chip labels.
I did that test and it gave me the following:
Found 1 device(s):
0: Realtek, RTL2838UHIDIR, SN: 00000001
Using device 0: Generic RTL2832U OEM
usb_claim_interface error -6
Failed to open rtlsdr device #0.
I have ordered an R820T2 device. No point returning the FC0012, I have had it for years.
Thankyou Guys.
Above output shows that you performed rtl_test -t without first stopping dump1090-fa. First stop dump1090-fa & piaware, then perform the test
sudo systemctl stop dump1090-fa piaware
rtl_test -t
When I tested after stopping dump1090-fa, the output shows both the chips
Okay, now it says ‘Found Fitipower FC0012 tuner’.
Handy to know for the future, thankyou!
