I keep getting this message, i have connected the DVB usb dongle and Ariel to a friends pi and all worked fine, so I’m confdent they are working ok, I’ve reimaged my Pi and updated all thats necessary , and added piaware , I’ve checked throttling and result is 0x0 I’ve also added a new power supply as i was previously getting undervoltage issues. here are some checks i’ve done
Any ideas , of what’s wrong, any help or suggestions gladly received
im running
Raspberry Pi 3 Model B Rev 1.2
PRETTY_NAME=“Raspbian GNU/Linux 11 (bullseye)”
NAME=“Raspbian GNU/Linux”
VERSION_ID=“11”
VERSION=“11 (bullseye)”
VERSION_CODENAME=bullseye
ID=raspbian
ID_LIKE=debian
HOME_URL=“http://www.raspbian.org/”
SUPPORT_URL=“RaspbianForums - Raspbian”
BUG_REPORT_URL=“RaspbianBugs - Raspbian”
Piaware status
mawdz09@raspberrypi:~ $ sudo piaware-status
PiAware master process (piaware) is running with pid 1315.
PiAware ADS-B client (faup1090) is running with pid 1369.
PiAware mlat client (fa-mlat-client) is running with pid 1329.
Local ADS-B receiver (dump1090-fa) is running with pid 1353.
dump1090-fa (pid 1353) is listening for ES connections on port 30005.
Your feeder ID is XXXXXXXXXXXXXXXXXX (configured at /etc/piaware.conf:9)
LSUSB
mawdz09@raspberrypi:~ $ lsusb
Bus 001 Device 004: ID 0bda:2838 Realtek Semiconductor Corp. RTL2838 DVB-T
Bus 001 Device 003: ID 0424:ec00 Microchip Technology, Inc. (formerly SMSC) SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Microchip Technology, Inc. (formerly SMSC) SMC9514 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
sudo systemctl status dump1090-fa -l
mawdz09@raspberrypi:~ $ sudo systemctl status dump1090-fa -l
Active: active (running) since Thu 2023-08-17 08:21:00 BST; 5min ago
Main PID: 1353 (dump1090-fa)
Tasks: 3 (limit: 1595)
CPU: 48.806s
└─1353 /usr/bin/dump1090-fa --quiet --device-type rtlsdr --gain 60 --adaptive-range --fix --lat 53.36149 →
Aug 17 08:21:00 raspberrypi dump1090-fa[1353]: rtlsdr: using device #0: Generic RTL2832U OEM (Realtek, RTL2838UHIDIR, S>
Aug 17 08:21:00 raspberrypi dump1090-fa[1353]: Detached kernel driver
Aug 17 08:21:00 raspberrypi dump1090-fa[1353]: Found Fitipower FC0012 tuner
Aug 17 08:21:01 raspberrypi dump1090-fa[1353]: rtlsdr: tuner gain set to about 28.2 dB (gain step 5) (tuner AGC enabled)
Aug 17 08:21:01 raspberrypi dump1090-fa[1353]: [FC0012] no valid PLL combination found for 1090000000 Hz!
Aug 17 08:21:01 raspberrypi dump1090-fa[1353]: adaptive: using 50% duty cycle
Aug 17 08:21:01 raspberrypi dump1090-fa[1353]: adaptive: enabled adaptive gain control with gain limits 7.1dB (step 2) >
Aug 17 08:21:01 raspberrypi dump1090-fa[1353]: adaptive: enabled dynamic range control, target dynamic range 30.0dB
Aug 17 08:21:01 raspberrypi dump1090-fa[1353]: Allocating 4 zero-copy buffers
Aug 17 08:21:11 raspberrypi dump1090-fa[1353]: adaptive: reached upper gain limit, halting dynamic range scan here
