Hi, new build here and I’m struggling with what might be bad hardware - but I’m hoping that you can help.
The current build is on Raspian Bullseye + Piaware + Dump1090-fa, though I had the same problems using the image distributed by Flightaware, as well.
Everything appears to have installed OK, but I’m stuck with not getting any actual data. See below and notice that the dump1090 is NOT producing data on localhost:30005 - that’s where I’m stuck.
pi@raspberrypi:~ $ piaware-status
PiAware master process (piaware) is running with pid 599.
PiAware ADS-B client (faup1090) is running with pid 644.
Local ADS-B receiver (dump1090-fa) is running with pid 342.
dump1090-fa (pid 342) is listening for ES connections on port 30005.
Your feeder ID is <redacted> (from /var/cache/piaware/feeder_id)
This is the kit available from Flightaware with the Pi-Zero, antenna, RTL/SDR, etc …
Ideas? Or given that his has happened consistently across two separate installs, should I presume bad hardware and seek a replacement?
