I recently tried moving my Piaware system to the top of a water tower, where I expected reception should be great. It all seems to work, the system checks in to the server, I’m shown as online, but it shows no aircraft! piaware-status says:
PiAware master process (piaware) is running with pid 14120.
PiAware ADS-B client (faup1090) is running with pid 30830.
PiAware mlat client (fa-mlat-client) is running with pid 14201.
Local ADS-B receiver (dump1090-fa) is running with pid 30607.
dump1090-fa (pid 30607) is listening for ES connections on port 30005.
piaware is connected to FlightAware. dump1090 is NOT producing data on localhost:30005.
Exactly the same hardware in a different location (my house) with a far less optimal antenna location gives reasonable performance and shows aircraft.
After many rounds of trouble shooting, I am left with the possibility that there is something poisonous about the location on the water tower. There are other electronics up there, including a VHF repeater. There’s a long ethernet run to get connectivity up there. Is it possible that very local RFI is blocking the signal? Any ideas how I could test/fix that ?
Thanks, I did go through that thread at the start of the trouble-shooting process. I also switched power supplies and removed USB extension cables. I finally reached the conclusion that the only variable that caused the problem was location!
Thanks, that’s strange, location does seem to be a factor. When it’s at the house and ‘working’, I seem to get that error message when there are no aircraft detected, but it disappears when an a/c is on my screen. Of course that could be cause not effect! But on the water tower, exactly the same setup, I never see a/c and always get the “NOT producing data” error. Anyway, I’ve ordered a Pro Stick Plus, I’ll see what effect that has.
And yeah with a repeater on there you’ll need filters.
The FA Pro+ won’t cut it as it has an LNA before the filter and the LNA can be overloaded as well somewhat easily.
You said your order the FA pro+ stick.
Anyhow doesn’t look like interference from the stats.json, more like the antenna not being connected or blocked.
Are you using the same gain settings when the set-up is on the water tower as when it’s at your house? Maybe it’s getting overloaded when it’s way up there because signals are stronger.
