Need help with PiAware
Hello, I have setup my PiAware image today on a raspberry pi 3B. I am using a generic USB DVB-T dongle (Blue) which meets thw dongle requirements. I am using a proper power supply, 5V 3A 24AWG power supply which works fine. My SD card is completely fine. It is a new sandisk ultra 32GB.
My issue is that I have only recieved aircraft during the first 2 minutes of boot, then nothing else shows up. My tracker currently has an uptime of 3 hours.
On my piaware information website, my radio (yellow) says “Connected to receiver but no recent data seen”. The piaware and flight aware are both green. My MLAT (Yellow) says “No clock synchronization with nearby receivers”. On my Piaware configuration page, if I try to set a nearby airport, it continously says “searching…”
How do I get my receiver up and working?
For Beginners - How-to Set Receiver Location
Sounds like a failure of the antenna connector/cable.
Done. I am still not getting any aircraft though.
Hmm… I dont know.
pi@RaspberryPi:~ $ rtl_test -t
Found 1 device(s):
  0:  Realtek, RTL2838UHIDIR, SN: 00000001
Using device 0: Generic RTL2832U OEM
Detached kernel driver
[R82XX] PLL not locked!
Sampling at 2048000 S/s.
Reattached kernel driver
Rtl_adsb:
pi@RaspberryPi:~ $ rtl_adsb
Found 1 device(s):
Tuner gain set to automatic.
Tuned to 1090000000 Hz.
Exact sample rate is: 2000000.052982 Hz
Sampling at 2000000 S/s.
*d132de82848ffdb35d84de7f43b8;
*843262e29b3d98be2efc83ebbd0e;
*b17eb31211ab0efd4e2925f93e55;
*e24221aaec46032489bcae73c1fa;
*d6bf4bd15166ff3685949403616b;
*a0406598c5be7d5b3a34fae40d75;
*a001451c2015b671d8a5e00d5202;
*ad44093999543b1f202685d5e800;
*8d450931ec2c2d00013804682473;
*ca792b4f0a16d9d7c50dcb40020a;
*a8201519a22da712bf6d69d22ac4;
*8d6074af5829b61fd20a32368c90;
*d05c7b923f26bc0d5a50da9b7bbc;
*a36964c511a594495b4234176114;
*cfee46e9a94a5cd5c7315de0aa5b;
^CSignal caught, exiting!
I still think the problem is that your dongle DVB-T driver is not blacklisted.
No kernel driver should be loaded that only leads to problems.
Please show the output of
sudo lsmod | grep rtl
Also the -t with rtl_test makes it not do what you want it to do.
Use
rtl_test -s 24000000
pi@piaware:~ $ sudo lsmod | grep rtl
rtl2832                20480  0
i2c_mux                16384  1 rtl2832
dvb_usb_rtl28xxu       32768  0
dvb_usb_v2             24576  1 dvb_usb_rtl28xxu
dvb_core              110592  2 dvb_usb_v2,rtl2832
pi@piaware:~ $
rtl_test:
pi@RaspberryPi:~ $ rtl_test -s 24000000
Found 1 device(s):
Invalid sample rate: 24000000 Hz
WARNING: Failed to set sample rate.
Info: This tool will continuously read from the device, and report if
samples get lost. If you observe no further output, everything is fine.
Reading samples in async mode...
User cancel, exiting...
Samples per million lost (minimum): 0
This all looks good please try the blacklisting i proposed earlier again and then check the lsmod command again.
sudo nano /etc/modprobe.d/blacklist.conf
add the following two lines
blacklist rtl2832
blacklist dvb_usb_rtl28xxu
then CTRL-O to save and CTRL-X to exit
show the output of
sudo cat /etc/modprobe.d/blacklist.conf
then
sudo reboot
then
pi@piaware:~ $ sudo cat /etc/modprobe.d/blacklist.conf
blacklist rtl2832
pi@piaware:~ $
Any chance it’s working now?
If not post the output of
sudo journalctl -u dump1090-fa -n50 --no-pager
Nope still not working.
pi@piaware:~ $ sudo journalctl -u dump1090-fa -n50 --no-pager
-- Logs begin at Thu 2016-11-03 17:16:42 UTC, end at Thu 2018-11-22 21:14:39 UTC. --
Nov 22 21:03:36 piaware systemd[1]: Started dump1090 ADS-B receiver (FlightAware customization).
Nov 22 21:03:36 piaware dump1090-fa[490]: Thu Nov 22 21:03:36 2018 UTC  dump1090-fa 3.6.3 starting up.
Nov 22 21:03:36 piaware dump1090-fa[490]: rtlsdr: using device #0: Generic RTL2832U OEM (Realtek, RTL2838UHIDIR, SN 00000001)
Nov 22 21:03:36 piaware dump1090-fa[490]: Found Rafael Micro R820T tuner
Nov 22 21:03:37 piaware dump1090-fa[490]: rtlsdr: enabling tuner AGC
Nov 22 21:03:58 piaware dump1090-fa[490]: Thu Nov 22 21:03:58 2018 UTC  No data received from the SDR for a long time, it may have wedged
Nov 22 21:05:06 piaware dump1090-fa[490]: Thu Nov 22 21:05:06 2018 UTC  No data received from the SDR for a long time, it may have wedged
Nov 22 21:06:06 piaware dump1090-fa[490]: Thu Nov 22 21:06:06 2018 UTC  No data received from the SDR for a long time, it may have wedged
Nov 22 21:07:06 piaware dump1090-fa[490]: Thu Nov 22 21:07:06 2018 UTC  No data received from the SDR for a long time, it may have wedged
Nov 22 21:08:07 piaware dump1090-fa[490]: Thu Nov 22 21:08:07 2018 UTC  No data received from the SDR for a long time, it may have wedged
Nov 22 21:09:07 piaware dump1090-fa[490]: Thu Nov 22 21:09:07 2018 UTC  No data received from the SDR for a long time, it may have wedged
Nov 22 21:10:07 piaware dump1090-fa[490]: Thu Nov 22 21:10:07 2018 UTC  No data received from the SDR for a long time, it may have wedged
Nov 22 21:11:07 piaware dump1090-fa[490]: Thu Nov 22 21:11:07 2018 UTC  No data received from the SDR for a long time, it may have wedged
Nov 22 21:12:07 piaware dump1090-fa[490]: Thu Nov 22 21:12:07 2018 UTC  No data received from the SDR for a long time, it may have wedged
Nov 22 21:13:08 piaware dump1090-fa[490]: Thu Nov 22 21:13:08 2018 UTC  No data received from the SDR for a long time, it may have wedged
Nov 22 21:14:08 piaware dump1090-fa[490]: Thu Nov 22 21:14:08 2018 UTC  No data received from the SDR for a long time, it may have wedged
sudo pkill -9 dump1090-fa
sudo systemctl restart dump1090-fa
-- Logs begin at Thu 2016-11-03 17:16:42 UTC, end at Thu 2018-11-22 21:18:11 UTC. --
Nov 22 21:17:42 piaware dump1090-fa[1079]: rtlsdr: enabling tuner AGC
Nov 22 21:17:42 piaware dump1090-fa[1079]: rtlsdr_demod_write_reg failed with -4
Nov 22 21:17:42 piaware dump1090-fa[1079]: rtlsdr_demod_read_reg failed with -4
Nov 22 21:17:42 piaware dump1090-fa[1079]: rtlsdr_write_reg failed with -4
Nov 22 21:17:42 piaware dump1090-fa[1079]: Failed to submit transfer 0!
Nov 22 21:17:43 piaware dump1090-fa[1079]: Failed to submit transfer 0!
Nov 22 21:17:43 piaware dump1090-fa[1079]: Thu Nov 22 21:17:43 2018 UTC  No data received from the SDR for a long time, it may have wedged
Nov 22 21:17:44 piaware dump1090-fa[1079]: Failed to submit transfer 0!
Nov 22 21:17:45 piaware dump1090-fa[1079]: Failed to submit transfer 0!
Nov 22 21:17:46 piaware dump1090-fa[1079]: Failed to submit transfer 0!
Nov 22 21:17:47 piaware dump1090-fa[1079]: Failed to submit transfer 0!
Nov 22 21:17:48 piaware dump1090-fa[1079]: Failed to submit transfer 0!
Nov 22 21:17:49 piaware dump1090-fa[1079]: Failed to submit transfer 0!
Nov 22 21:17:50 piaware dump1090-fa[1079]: Failed to submit transfer 0!
Quite curious. rtl_test works but dump1090 does not.
Just out of curiosity, does
sudo sytemctl stop dump1090-fa
still work?
pi@piaware:~ $ rtl_test -s 24000000
    No supported devices found.
replugging the dongle back in:
    Found 1 device(s):
rtlsdr_demod_read_reg failed with -1
rtlsdr_demod_write_reg failed with -1
No supported tuner found
Enabled direct sampling mode, input 1
Supported gain values (1): 0.0
rtlsdr_write_reg failed with -1
Floating point exception
BTW, earlier I had done the RTL test on the other raspberry pi since I did not know what to stop.
interestingly enough the device seems to work worse when the kernel driver is blacklisted.
sudo rm /etc/modprobe.d/blacklist.conf
sudo reboot
My best guess is: device does not work without kernel drive for DVB-T for whatever stupid reason.
But dump1090 won’t work properly because the kernel driver somehow gets the device back.
Do you have a picture of the dongle maybe others can avoid it?
The dongle looks the same as any other DVB-T+FM+DAB (blue) generic dongle.
-- Logs begin at Thu 2016-11-03 17:16:42 UTC, end at Thu 2018-11-22 21:33:13 UTC. --
Nov 22 21:33:01 piaware dump1090-fa[481]: weirdness: rtlsdr gave us a block with an unusual size (got 0 bytes, expected 262144 bytes)
But this dongle works on the 3B+?
Then somehow this dongle and this pi 3b just don’t work together using dump1090 at least.
I dont know if it works with the 3B+, I had plugged the dongle into the RPi3B+ and ran the RTL test and it gave the result showed as “pi@raspberrypi”
i’m confuse do you have one raspberry pi or do you have two?
if you have two just change over the sdcard so you definitely know it’s the dongle.
also maybe you could use the newer pi for dump1090 and your problem would be solved (doubting that it will work on the other pi either though)
(already pretty sure it’s just the dongle not liking dump1090 but it’s worth a try)
