when trying to install Piaware 7.1 loading it to the sd card kept failing. repeated the flashing to the card a few more times with the same issue. so i downloaded the file again and retried with the same results. gave up waited a few days. tried again and it worked. anyone had this issue or know why it happened.
I’ve had a different failure mode.
I pulled a working card that had become unreliable, and flashed it with a new image. This worked perfectly for a small number of reboots before failing again. I formatted the card and reflashed. Again it worked perfectly for a small number of reboots and failed again.
Testing the card in a PC showed no problems at all.
On the plus side, a failing SD card takes up very little space in your rubbish bin.
But only with the Piaware image?
I am still using Etcher for any image. The only error at the end is this one below, but the installation went fine and i can use it as usual.
