PiAware 3.8 Zip file reports as corrupt
Hi
Have tried to download latest PiAware software for RaspberryPi.
When I use Etcher to flash an 8GB sdhc card it fails.
Both WinRar and 7z are reporting the file as corrupt (CRC).
regards
I just tried the download and the file comes down okay. If you have a MD5 checksum tool for Windows, check the downloaded file. It should have the name and checksum:
ca21cdb23bc691f4bb050122d2b022e9 piaware-sd-card-3.8.0.img.zip
If it doesn’t then it’s likely the file was downloaded badly or interrupted. Delete it and try again and confirm the name and checksum.
There’s a new tool you might want to try called Raspberry Pi Imager. I’ve ditched Etcher and use this now instead.
Hi
Tried again but winrar still reports the file as corrupt.
I’m using firefox browser and downloading this file from http://piaware.flightcdn.com/piaware-sd-card-3.8.0.img.zip
I used a couple MD5 checkers on this file.
They both report the checksum as:
04f99f22c6ef4ba16e05095b37f43040
which is different to the one you reported.
Going to try wget to see if any different.
regards
I can’t reproduce the corruption on a fresh download. The ca21cdb… md5sum mentioned above is the correct one.
I tried with the latest Firefox on Windows and get the same as I get on the Mac
C:\Users\Chris\Downloads>certutil -hashfile piaware-sd-card-3.8.0.img.zip MD5
MD5 hash of file piaware-sd-card-3.8.0.img.zip:
ca 21 cd b2 3b c6 91 f4 bb 05 01 22 d2 b0 22 e9
CertUtil: -hashfile command completed successfully.
Perhaps there’s an extension (or something unwanted) in your Firefox messing around with the download. There’s an option in Firefox to restart without them. 3 lines menu upper-right corner → Help → Restart with Add-ons Disabled. Wget as you say is also a good test.
I just downloaded as well, I get the same MD5 and I can unzip the image successfully.
feek@ShackiMac ~ % md5 /Users/feek/Downloads/piaware-sd-card-3.8.0.img.zip
MD5 (/Users/feek/Downloads/piaware-sd-card-3.8.0.img.zip) = ca21cdb23bc691f4bb050122d2b022e9
feek@ShackiMac ~ %
If you use Etcher or whatever it’s called these days, you can write the image without unzipping it but of course you have to get a good download first.
Thank you all for your help. Much appreciated.
I now have the file downloaded with the correct MD5 CRC.
I achieved this by using a different computer and a mobile phone hotspot.
I did try downloading with wget but am embarrassed to say I got a different CRC than I did with the other corrupt downloads using firefox.
Pure speculation, but I think the problem may have something to do with virus protection.
When I get some time next week I’ll temporarily turn virus protection off and re-test.
Anyway thanks again for the help. Not being able to get the zip file is now SOLVED.
It could indeed be that but it’s a poor show from whatever software would interfere like that. On the flip side it could theoretically be a virus or malware, trying to insert itself into images and code that you download. Worth doing a full scan and ensuring everything’s behaving as it should. It might be worth checking any other downloads you got too, in case they have been similarly affected.
@obj, perhaps the MD5 sum could be included next to the links on PiAware - build your own ADS-B ground station for integration with FlightAware - FlightAware to help people check they have an intact download if needed.
Not related to this issue, but a similar unusual problem:
I can clone dump1090-fa source code on all types of distros on VM, but two days ago failed on NetBSD on VM:
SSL Certificate issue.
localhost# git clone https://github.com/flightaware/dump1090.git dump1090-fa
Cloning into 'dump1090-fa'...
fatal: unable to access 'https://github.com/flightaware/dump1090.git/': SSL certificate problem: unable to get local issuer certificate
Succeeded only after this workaround.
localhost# git config --global http.sslVerify false
localhost# git config --global http.sslVerify true
That’s a local problem with your root CA store.
