I have just completed an install from source on a Pine A64. All functionality appears to be working correctly, with the following 2 exceptions:
The SkyAware map shows the receiver location as being about 50 miles north of it’s actual location. The location is manually set in the dump1090-fa configuration and in the Feeder Stats page settings. It appears correctly on the ADS-B Feeder Statistics page. The receiver does not have a GPS connected. Is there some place to manually set the SkyAware map receiver location?
On the ADS-B Feeder settings for this feeder, I manually entered the antenna height above sea level. The antenna height displayed for the receiver is correct - 10ft. However, Ground Elevation, which I did not enter shows 4,334 feet. This makes no sense because the antenna is physically located at 10ft AMSL. Seems to me, ground elevation should be the same as the antenna height in this case. Is there a way to change this setting?
Thanks in advance,
-Scott
