Hello,
I just installed piaware 3.5.3 as per described at the “https://flightaware.com/adsb/piaware/install”
The version of Debian I Installed is as below:
root@orangepizero:~# sudo lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description: Debian GNU/Linux 8.8 (jessie)
Release: 8.8
Codename: jessie
The RTL-SDR (NooElec SMArt black) & official Flightaware Pro Stick plugged into the USB port
Only 1 dongle plugged in at a time, both giving the same result
root@orangepizero:~# lsusb
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 002: ID 0bda:2838 Realtek Semiconductor Corp. RTL2838 DVB-T
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
root@orangepizero:~# sudo piaware-status
PiAware master process (piaware) is running with pid 458.
PiAware ADS-B client (faup1090) is not running.
Local ADS-B receiver (dump1090) is not running.
no program appears to be listening for connections on port 30005.
got ‘couldn’t open socket: connection refused’
Your feeder ID is xxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx (configured at /etc/piawa re.conf:9)
root@orangepizero:~# sudo service dump1090-fa status
Loaded: loaded (/lib/systemd/system/dump1090-fa.service; enabled)
Active: activating (auto-restart) (Result: exit-code) since Sun 2018-01-21 23:00:06 CET; 8s ago
Process: 1296 ExecStart=/usr/bin/dump1090-fa $RECEIVER_OPTIONS $DECODER_OPTIONS $NET_OPTIONS $JSON_OPTIONS $PIAWARE_DUMP1090_LOCATION_OPTIONS --write-json /run/dump1090-fa --quiet (code=exited, status=1/FAILURE)
Main PID: 1296 (code=exited, status=1/FAILURE)
Jan 21 23:00:06 orangepizero systemd[1]: Unit dump1090-fa.service entered failed state.
root@orangepizero:~# sudo service piaware status
Loaded: loaded (/lib/systemd/system/piaware.service; enabled)
Active: active (running) since Sun 2018-01-21 22:52:27 CET; 17min ago
Main PID: 458 (piaware)
└─458 /usr/bin/piaware -p /run/piaware/piaware.pid -plainlog -statusfile /run/piaware/status.json
Jan 21 23:08:57 orangepizero sudo[1515]: pam_unix(sudo:session): session closed for user root
Jan 21 23:08:57 orangepizero piaware[458]: no ADS-B data program seen listening on port 30005 for 251 seconds, next check in 60s
Jan 21 23:09:29 orangepizero sudo[1524]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/netstat --program --tcp --wide --all --numeric
Jan 21 23:09:29 orangepizero sudo[1524]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jan 21 23:09:29 orangepizero sudo[1524]: pam_unix(sudo:session): session closed for user root
Jan 21 23:09:29 orangepizero piaware[458]: no ADS-B data program is serving on port 30005, not starting multilateration client yet
Jan 21 23:09:57 orangepizero sudo[1533]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/netstat --program --tcp --wide --all --numeric
Jan 21 23:09:57 orangepizero sudo[1533]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jan 21 23:09:57 orangepizero sudo[1533]: pam_unix(sudo:session): session closed for user root
Jan 21 23:09:57 orangepizero piaware[458]: no ADS-B data program seen listening on port 30005 for 311 seconds, next check in 60s
Few months ago. I also using the same method which based on the page PiAware - dump1090 ADS-B integration with FlightAware - FlightAware and it works without any issue.
Please help me to diagnose what is going on with this installation or I missed some other steps…
Thank you and I appreciate your comments / instructions to fix this.
Regards,
Fung Sai Hou
WBKK
