I’m having real issues getting my PiAware to work.
I’ve tried different ways of installing PIAware and dump1090 including via wget and from source on github but the results of both installation attempts didn’t seemed to work correctly.
When I input piaware-status in terminal I get back:
PiAware master process (piaware) is running with pid 800.
PiAware ADS-B client (faup1090) is not running.
Local ADS-B receiver (dump1090) is running with pid 744.
readsb (pid 717) is listening for ES connections on port 30005.
piaware is NOT connected to FlightAware.
Does anyone have an idea what is not working? I’m a total noob so have no idea and would love some help
Well let’s see if your ADsB dongle is present on your system.
please post the output of the command
lsusb
this will show the connected USB devices. without the dongle connected the software will report an error
Also describe your set-up, what type of hardware are you using, did you use the image based set-up or the package based set-up ?
What os version are you running ?
Command
cat /etc/os-release
pi@raspberrypi:~ $ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 093a:2510 Pixart Imaging, Inc. Optical Mouse
Bus 001 Device 003: ID 0bda:2832 Realtek Semiconductor Corp. RTL2832U DVB-T
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
The Prostick isn’t listed but it is plugged in.
I have a Raspberry Pi 4B running Raspberry OS attached to a USB mouse, bluetooth keyboard, official PI 7inch LCD in plastic case, and the Prostick Plus with 1090 antenna.
I installed Raspberry OS using NOOBS and then did a package install of PiAware and dump1090.
2021-12-17 16:12:16 (21.8 KB/s) - written to stdout [3126/3126]
OK
pi@raspberrypi:~ $ sudo apt update
Hit:1 Index of /debian bullseye InRelease
Hit:2 Index of /raspbian bullseye InRelease
Hit:3 http://flightaware.com/adsb/piaware/files/packages buster InRelease
Hit:4 http://flightaware.com/adsb/piaware/files/packages stretch InRelease
Hit:5 https://abcd567a.github.io/ppa/piaware ./ InRelease
Reading package lists… Done
Building dependency tree… Done
All packages are up to date.
pi@raspberrypi:~ $ sudo apt install piaware
piaware is already the newest version (6.1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
pi@raspberrypi:~ $ sudo piaware-config feeder-id xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
feeder-id is unchanged
pi@raspberrypi:~ $ sudo piaware-config allow-auto-updates yes
allow-auto-updates is unchanged
pi@raspberrypi:~ $ sudo systemctl restart piaware
pi@raspberrypi:~ $ sudo apt install dump1090-fa
dump1090-fa is already the newest version (6.1).
pi@raspberrypi:~ $ sudo reboot
I then went to the IP and it showed and active PiAware for a moment but when I clicked on the menu items at the top is went back to inactive.
I then ran piaware-status:
pi@raspberrypi:~ $ piaware-status
PiAware master process (piaware) is running with pid 761.
Local ADS-B receiver (dump1090) is running with pid 721.
readsb (pid 700) is listening for ES connections on port 30005.
pi@raspberrypi:~ $ sudo apt purge piaware
The following package was automatically installed and is no longer required:
tcl-tls
Use ‘sudo apt autoremove’ to remove it.
The following packages will be REMOVED:
piaware*
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
After this operation, 11.6 MB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database … 195596 files and directories currently installed.)
Removing piaware (6.1) …
Processing triggers for man-db (2.9.4-2) …
Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u2) …
(Reading database … 195142 files and directories currently installed.)
Purging configuration files for piaware (6.1) …
Processing triggers for rsyslog (8.2102.0-2) …
The following NEW packages will be installed:
piaware
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 3,946 kB of archives.
After this operation, 11.6 MB of additional disk space will be used.
Get:1 https://abcd567a.github.io/ppa/piaware ./ piaware 6.1 [3,946 kB]
Fetched 3,946 kB in 8s (499 kB/s)
Selecting previously unselected package piaware.
(Reading database … 195137 files and directories currently installed.)
Preparing to unpack …/archives/piaware_6.1_armhf.deb …
Unpacking piaware (6.1) …
Setting up piaware (6.1) …
Created symlink /etc/systemd/system/default.target.wants/piaware.service → /lib/systemd/system/pi
aware.service.
Created symlink /etc/systemd/system/piaware.service.wants/generate-pirehose-cert.service → /lib/s
ystemd/system/generate-pirehose-cert.service.
Set feeder-id to xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx in /etc/piaware.conf:7
PiAware master process (piaware) is running with pid 878.
Local ADS-B receiver (dump1090) is running with pid 839.
readsb (pid 796) is listening for ES connections on port 30005.
Your feeder ID is xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx (configured at /etc/piaware.conf:7)
Still not working. Also did a roboot to check if that helped but nothing showing on the web page at my Pi’s IP.
Readsb is a Mode-S/ADSB/TIS decoder for RTLSDR, BladeRF, Modes-Beast and GNS5894 devices. As a former fork of dump1090-fa it is using that code base but development will continue as a standalone project with new name. Readsb can co-exist on the same host system with dump1090-fa, it doesn’t use or modify its resources. However both programs will not share a receiver device at the same time and in parallel.
I’d remove the readsb setup and then try to restart piaware.
Thinking I will start a new install of of Raspberry OS from NOOBS on a new SD and do the things above again there to make sure there are not other issues I’ve created by trying different things…
First login to the Pi via SSH and run
sudo raspi-config.
Set the system settings (option 1)
Set the timezone (option 5)
expand the file system (option 6)
reboot the Pi and start installing.
