I have been using this system for a few weeks now and must say I am very impressed with the reception especially compared to my earlier set up. One thing that I have not been able to do achieve - when viewing my Pi Skyview is it possible to view other feeders on the same map?
If i understand your question correctly, no you can’t.
The data you are viewing is local to your network.
If you have a buddy though and he were to expose the beast data for example by opening a port on his router and using dyndns for a web address, then you could use something like this: GitHub - wiedehopf/combine1090: Combine data from multiple ADS-B receivers into one readsb decoder / tar1090 webinterface
Equally if you own multiple receivers you can view them in one map this way.
A better solution is probably to use a VPN or something instead of exposing the beast data to the internet.
Many thanks for your reply and explanation. Much appreciated.
Instal VirtualRadar.
Add own receiver
And add data-feed-from-adsbexchange
https://www.wiganpi.co.uk/feed-data-from-adsbexchange-to-virtual-radar-server/
P.S. Share your data - ADS-B Exchange
