Hello. Some time ago adsbexchange com stopped working for me. Using this topic Reddit - Dive into anything I quickly changed the entries to adsb.fi and now I can’t see my receiver even in the local network ((I’m not talking about the http://192.168.1.21/skyaware/, but the adsbexchange map, which was also viewed from the outside). On the adsb.fi homepage , I see tjhat I am connected, but I don’t know how to view only my receiver. On ADSBexchange Anywhere I see “no feeder connections”. Is it possible to share data to theseservices simultaneously, in parallel? If so, what’s the best way to do it? Best Regards.
Can’t you just run the scripts in the ADSBExchange GitHub page:
And run the scripts in the ADSBfi GitHub Page:
And they both work. Seems to work for me.
Thank you for your answer. I probably could if I had a clear image. As I probably already have most of these things installed, I need a more detailed answer, i.e. what to check, what to change, what to remove, what to add, etc. I fear that by following these descriptions step by step, I may do more harm than good.
Look on both pages for “Update the feed client without reconfiguring” section. Run commands listed there, see if it helps.
