Why is O14 showing up as Invalid airport code/ No such airport
It worked for me on the first try:
Neil’S Sky Ranch Airport (Ninnekah, OK) [O14]
FWIW, if I put in the obvious typo “014” (zero instead of capital o) it fails with “Unknown or Invalid Airport Code”. I assume you’re not that absent-minded, but honestly, I might do that.
OK type in O14 yes the airport and shows up in the little map with planes in the vincenty but to the left in that little box is where its showing up as Invalid airport code/ No such airport
It would seem that the “Invalid airport code/ No such airport” message only comes up if there are no arrivals/departures. If you click on the “view info” button everything comes up ok.
I’ve read through the FAQ and see that there area some general codes for larger multiple-airport areas. I’ve tried to enter ZLA and KZLA to view activity and both times the response was “invalid code, use proper IATA coding”.
Any suggestions for what I’m doing wrong?
The area codes only work on the flight finder.
That’s a great tool, I just forgot where to use it.
Thanks again
