How-to Serialize Dongles for ES1090 + UAT978
sudo systemctl stop piaware
sudo systemctl stop dump978-fa
rtl_test -t -d 00000978
rtl_test -t -d 00001090
I think you should read this howto: How to Install and Configure Piaware 5.0 SD card image - Quickstart Guide
This error when running rtl_test is always due to some program using it still running.
dump1090-fa and dump978-fa get restarted by piaware, so you need to stop that as well.
Also when you reboot the services obviously start up again.
Yes, you have to tell piaware the serial numbers, as shown in quote below from QuickStat Guide (you should read the guide in full).
I started from section 5 (serialize dongles) of the Quickstart 3.7.1 guide since the SD card already has 3.7.1 on it and I don’t need to set up ssh and wi-fi, etc. on the installation and I’m still having problems.
The ā€œConfigure UAT 978ā€ commands did not give any error when the commands were issued and I rebooted.
The dump978-fa status then gave:
pi@piaware:~$ sudo systemctl status dump978-fa
ā— dump978-fa.service
Loaded: not-found (Reason: No such file or directory)
Active: inactive (dead)
I temporary stopped dump1090 and dump978 and ran a test on the 978 dongle and the dongle appears fine:
pi@piaware:~$ rtl_test -t
Found 1 device(s):
0: Realtek, RTL2838UFA, SN: 00000978
Using device 0: Generic RTL2832U OEM
Sampling at 2048000 S/s.
I am thinking about doing the whole quickstart guide from the beginning – thinking something funky happened in the upgrade from 3.6.3. to 3.7.1 causing dump978-fa issues – so I might leave my main piB3 running 1090 only and take my backup pi3B/backup SD card and wipe the sd card and write 3.7.1 on it and play with that until hopefully I get 978 working and eventually both dongles working on the same pi3B.
I may edit this file later with the troubleshooting section log results if I still can’t figure it out with more playing with it.
New image is probably best. But you can try just installing dump978-fa, i’m not sure it’s automatically installed on update.
sudo apt install dump978-fa
I did a clean install of 3.7.1 on another card and went through the 3.7.1 quickstart guide in its entirety.
I’m not getting 978 issues about error 404 pulling up the 978 map or missing file or directories when doing a status check, but I am getting the ā€œ978 UAT Radioā€ status box being yellow. It says UAT receiver is running but no data seen, so I don’t know if the usb claim thing I’m still getting testing the dongles (even with disabling both dumps to test) is the reason why or if it’s just because there may not be a lot of close 978 traffic tonight.
My next step is probably to read the 350 replies to the 3.7.1 quickstart guide thread in case what I’m seeing has been reported in that thread and I get some other things to try, or post there since I think I"m getting into stuff that’s beyond serializing the dongles now.
@rsmath
sudo systemctl stop piaware dump1090-fa dump978-fa
rtl_test -t -d 0
rtl_test -t -d 1
sudo systemctl restart dump1090-fa dump978-fa piaware
Here are the results of the rtl_test commands instructed and they appear to me to be normal results. Am I supposed to be redo the ā€œConfigure UAT 978ā€ using 0 and 1 in place of the serial numbers of the respective dongles as shown in the quickstart guide or keep it using serial numbers 00001090 and 00000978?
pi@piaware:~ $ rtl_test -t -d 0
Found 2 device(s):
0: Realtek, RTL2832U, SN: 00001090
1: Realtek, RTL2838UFA, SN: 00000978
Detached kernel driver
[R82XX] PLL not locked!
Reattached kernel driver
pi@piaware:~ $ rtl_test -t -d 1
Found 2 device(s):
Using device 1: Generic RTL2832U OEM
pi@piaware:~ $ sudo systemctl restart dump1090-fa dump978-fa piaware
@rsmath
Both dongles are OK.
What is the output of following commands?
Problem may be in antenna, antenna cable, or connector.
Noted that the 00000978 has FA in it’s name (RTL2838UFA), indicating it is FlightAware prostick. If it is blue one (prostick plus), it has a 1090 mhz filter inside. Although it is healthy, It will not work properly on 978 mhz due to the integral filter.
Do NOT redo serial numbers. Leave these at 00001090 and 00000978
Each dongle has now 2 numbers: device (0 or 1) and serial (00001090 or 00000978).
The configs of dump1090-fa and dump978-fa are done using serial number, and NOT device number.
scroll right to see seria numbers
I’m using a blue dongle with Flightaware’s logo on it for the 1090 and an orange dongle with Flightaware’s logo on it for 978 as I think I came across something about what you said when doing research for what gear I would need for 978 reception.
On your suggestion, I’ll check my connections or try a piece of wire for an temporary test antenna to see if it is antenna or coax that might be the issue.
Here’s the output from the status dumps:
pi@piaware:~ $ sudo systemctl status dump1090-fa
ā— dump1090-fa.service - dump1090 ADS-B receiver (FlightAware customization)
Active: active (running) since Sun 2019-09-01 03:47:09 UTC; 1h 11min ago
Main PID: 9217 (dump1090-fa)
└─9217 /usr/bin/dump1090-fa --net-bo-port 30005 --fix --device-index 00001090 --gain -10 --ppm 0 --max-
Sep 01 03:47:09 piaware systemd[1]: Started dump1090 ADS-B receiver (FlightAware customization).
Sep 01 03:47:09 piaware dump1090-fa[9217]: Sun Sep 1 03:47:09 2019 UTC dump1090-fa 3.7.1 starting up.
Sep 01 03:47:09 piaware dump1090-fa[9217]: rtlsdr: using device #0: Generic RTL2832U (Realtek, RTL2832U, SN 000010
Sep 01 03:47:10 piaware dump1090-fa[9217]: Detached kernel driver
Sep 01 03:47:10 piaware dump1090-fa[9217]: Found Rafael Micro R820T tuner
Sep 01 03:47:10 piaware dump1090-fa[9217]: rtlsdr: enabling tuner AGC
pi@piaware:~ $ sudo systemctl status dump978-fa
ā— dump978-fa.service - dump978 ADS-B UAT receiver
Loaded: loaded (/lib/systemd/system/dump978-fa.service; enabled; vendor preset: enabled)
Active: active (running) since Sun 2019-09-01 03:46:38 UTC; 1h 13min ago
Main PID: 9038 (dump978-fa)
CGroup: /system.slice/dump978-fa.service
└─9038 /usr/bin/dump978-fa --sdr driver=rtlsdr,serial=00000978 --raw-port 30978 --json-port 30979
Sep 01 03:46:40 piaware dump978-fa[9038]: Found Rafael Micro R820T tuner
Sep 01 03:46:40 piaware dump978-fa[9038]: Reattached kernel driver
Sep 01 03:46:41 piaware dump978-fa[9038]: Detached kernel driver
Sep 01 03:46:41 piaware dump978-fa[9038]: Found Rafael Micro R820T tuner
Sep 01 03:46:41 piaware dump978-fa[9038]: Exact sample rate is: 2083333.135571 Hz
Sep 01 03:46:41 piaware dump978-fa[9038]: [R82XX] PLL not locked!
Sep 01 03:46:41 piaware dump978-fa[9038]: SoapySDR: using maximum manual gain 49.6 dB
Sep 01 03:46:41 piaware dump978-fa[9038]: SoapySDR: using stream setting buffsize=262144
Sep 01 03:46:42 piaware dump978-fa[9038]: [::]:30978: accepted a connection from [::1]:34604
Sep 01 03:46:44 piaware dump978-fa[9038]: [::]:30978: accepted a connection from [::1]:34606
@rsmath
All (both dumps & both dongles) seem OK.
You either currently have low UAT traffic, or have a bad antenna/cable/connection.
Run status commands again after say 15 minutes.
sudo systemctl status piaware
Adjust the gain for UAT to 35, that generally gives better results with the Orange FA dongle.
(If you have an uputronics 978 MHz LNA as well you’ll need to change the gain to 15)
The radio turning yellow for UAT is normal if no UAT planes are around.
@rsmath
Your problem is most likely due to very low/occassional UAT traffic. I had same problem as UAT traffic here in Toronto is occassional.
@rsmath
Generally it’s quite problematic to use two dongles on the same Pi.
The quality/voltage of the power supply becomes very important to ensure both dongles are supplied with sufficient voltage.
What Pi / powersupply are you using?
The RPi Official power supply is recommended, especially for using two dongles.
No, it is not, at least for me.
I have a RPi model 2, with non-official power supply from ebay/seller from China. It worked ok for about 2months for piaware 3.7.1 sd card image with 2 dongles and both dump1090 & dump978 enabled.
End of July, my other Pi (Orangepi pc) died. To restore my stations, I wrote Raspbian Buster, then installed two stations on same surviving RPi. It is working flawlessly since last one month.
It has following adsb software running 24/7:
  • dump1090-mutability
  • dump1090-mutability2
  • piaware
  • piaware2
  • fr24feed
  • fr24feed2
  • pfclient
  • pfclient2
  • adsbexchange
  • adsbexchange2
  • rbfeeder
  • opensky-network
  • RadarVirtuel
  • Graphs by @wiedehopf
Later addition:
I am using following 2 dongles for 2 instances of dump1090-mutability:
  • Flightaware ProStick (orange) with integral lna + FA light blue filter + indoor PCB antenna
  • Radar Box’s FlightStick (green) with integral filter & lna + indoor optimized mag-mount whip on cookie can.
All is good this afternoon. Around 1pm, the UAT 978 Radio button was no longer yellow but green. I opened the 978 map and saw 2 aircraft flying into Santa Fe airport (40 miles and behind a mountain from me). That proved to me dongle and antenna were all fine and that there is just a lot less 978 traffic than I would have expected for my area (not traffic numbers of large major airports but not that of a rural airport either).
I’m amazed about 978! Normally I lose planes into Santa Fe on 1090 because of the mountain (so I never get to see more than part of their descent). I was able to track both planes through descent and landing and lost them halfway down the runway after ground contact!
To answer other posts, my power supply is CanaKit 5V 2.5A Raspberry Pi 3 Power Supply / Adapter / Charger (UL Listed) so not the official one but I think just as capable as the official one due to supporting 2.5A of any Pi needs (the Pi3B and the two dongles I’ve plugged into the USB port).
I am not using a LNA but I’m using the Flightaware external filter that says it’s good for both 978 and 1090, so my chain is the Flightaware 978 antenna, then RG-6 coax to the Flightaware external (metal cylinder with connectors on both ends) filter then to orange Flightaware dongle plugged into my Pi3B.
I’ll still mess with gain using 35 as suggested. I remember how when I first started 1090, it improved my results to tweak the gain using aircraft stats from one of the postings on this forum about a method to try using data to find a sweet spot. 978 is going to be much harder right now to find a sweet spot as I don’t have a lot of data points to play with unless traffic really gets busy during a weekday.
Thanks for all the help and I hope this discussion from the last couple of days may help others!
If any one is interested to run two-in-one :slightly_smiling_face: RPi:
Well, that doesn’t mean that it’s not problematic.
You are aware of all the power issues and using two dongles makes that happen more often.
Glad it’s working. Your stats for 1090 seem to have dropped quite a bit, but that’s probably just temporary from the installation.
Do you have the graphs installed, they should show any change quite easily (GitHub - wiedehopf/graphs1090: Graphs for readsb / dump1090-fa / dump1090 (based on dump1090-tools by mutability))
They also show for example how many 978 planes are TIS-B.
Who was the brain trust that coded dump978-fa ??? Why is the syntax different than dump1090-fa ??? It seems that piaware-config does nothing after piaware is installed. If I had not run into this post, I would still be banging my head against the desk. IT SHOULD NOT BE THIS DIFFICULT TO CONFIGURE TWO RADIOS !!!
