How to Install and Configure Piaware 5.0 SD card image - Quickstart Guide
The official RPi power supply is 5.1V, not 5.2V.
RPi%20Official%20Power%20Supply
I had the same issue where both dongle would not fit into the pi at the same time. I bought a powered USB 3 , 4 port, and it seems to work fine. Having the ports powered seems to be the best bet so it doesnā€™t need to pull power from the pi.
This is the longer term plan but we didnā€™t get it done for 3.7
INVALIDARGUMENT ???
maybe it canā€™t find the serial number specified.
taking a look at the config file generated probably doesnā€™t hurt either.
cat /etc/default/dump978-fa
May I know any difference between the dump1090-fa 3.6.3 and this 3.7.0.1?
*Just for 1090MHz band.
Thanks in advance.
Nothing major.
Itā€™s gonna be released soon anyway.
@wiedehopf, thanks for the info.
Will re-flash to the latest version once officially launch.
Have a nice weekend to you all. Good day.
Regards.
Just do a bog standard update.
Really no reason to reflash if your sd-card image is on stretch already.
sudo apt update
sudo apt dist-upgrade
should give you the up to date versions of everything.
I tried using the ā€œsudo apt-get updateā€ then ā€œsudo apt-get upgadeā€ but nothing to have the PiAware updated.
Anyway, will try again. Thanks @wiedehopf.
Oh, dist-upgrade?
Ah I see. Will try later ya.
Thanks.
FYI, I received my powered USB Hub. I bought a small Anker travel 4 port, and a 2-Port Anker USB Power adapter that supports 2.4amp per port and intelligence to keep voltage over 5volt. Pi and Hub run off that with higher end Anker Micro-USB cables (I have always found their cables to be great quality). After doing this my 1090 reception improved GREATLY. Comparing time of day, I increased my messages per second and aircraft seen by somewhere between 50% and 80%. I have no real data on 978 reception as the flights are so far and in between. (Less than 10 flights a day)
So far I have only tested this on one unit with both 1090 and 978 dongles installed, FlightAware Orange sticks. Alone, no problem, but with both installed the power draw on the Piā€™s usb bus seems to be an issue.
Anyone else running 1090 and 978 on the pi, please try replicating my setup with maybe a good externally powered USB hub you may have laying around, and see if you get the same results. I am curious to see if I am an isolated incident or not.
Also, sidenote. 3.7.1 was released on the PiAware github, Guessing a new image very soon.
Yesterday re-imaged microSD card with latest Raspbian Stretch Lite image, then built and installed ver 3.7.1 packages from github source code.
Version 3.7.1 Add-on Package Install
Here in Toronto, UAT planes are not many, only occassional. This is the first occurance since installed v 3.7.1
dump1090-localhost-aircraft_978-24h-4
What do you think about ferrites on USB cables? And have you tried max_usb_current=1 setting for Pi?
Never used ferrite on usb cable. Using $2.99, 4ft USB extender cable from neighborhood Dollar Store.
Never used usb_max_current setting either.
After some google it seems it doesnā€™t have any effect on the RPi version 3 and up.
My site information say green for mlat and ā€œMultilateration (MLAT): Supported / Enabledā€
however, the piaware-status confuses me stating fa-mlat-client is not runing.
Is something that I have missed ?
pi@piaware:~ $ piaware-status
PiAware master process (piaware) is running with pid 458.
PiAware ADS-B client (faup1090) is not running.
PiAware ADS-B UAT client (faup978) is running with pid 32220.
Local ADS-B UAT receiver (dump978-fa) is running with pid 32168.
no program appears to be listening for connections on port 30005.
dump978-fa (pid 32168) is listening for connections on port 30978.
faup978 is connected to the ADS-B UAT receiver.
got ā€˜couldnā€™t open socket: connection refusedā€™
dump978 is producing data on localhost:30978.
Your feeder ID is XXX (from /var/cache/piaware/ feeder_id)
pi@piaware:~ $
You are not running dump1090-fa.
There is no MLAT for UAT because all planes on that protocol have GPS.
Has anyone had any success in outputting data in a format modesmixer2 can accept for UAT data? I saw digging around thereā€™s a program called uat2json that converts uat data to modes data that most programs can understand, but theyā€™re working with modified dump978 versions vs PiAwareā€™s version.
I have 3 locations, of which 2 are UAT. Right next to a small training airport, so I get lots of UAT data. I feel all my data back to ModeSMixer2, running the simple built in web-view it produces as a ā€œmaster viewā€ of all my plane data from all 3 Piā€™s, then output that to PlanePlotter. However ModeSMixer2 and almost all apps donā€™t like UAT messages, yet. If ModeS conversion canā€™t be done to feed ModeSMixer2, is there a better program to feed all my Piā€™s UAT and ADS-B, and Mode-S data into thatā€™s web-accessible like ModeSMixer2ā€™s web interface?
Send a picture of your hub set up
