How to Install and Configure Piaware 5.0 SD card image - Quickstart Guide
That won’t work as dump1090-fa won’t accept the dump978-fa output format as input.
You could probably make the javascript of the webinterface load the aircraft.json for dump978.
that would involve making that available at dump1090-fa/data2 for example (via lighttpd)
Then change the javascript to process a 2nd aircraft.json.
Maybe i’ll take a look, no promises though.
After carefully following the above instructions I seem to have done something wrong. I have a 1090 antenna attached to the blue dongle and the 978 antenna attached to eh orange dongle. Both are attached to a powered hub feeding into my Pi. when checking the status of each I receive the following message. Your guidance is appreciated. Please forgive a newbie.
image|690x388
That image doesn’t work.
You probably removed brackets or sth.
(or didn’t wait for the upload to complete)
Sorry, let me try again.
pi@piaware:~ $ sudo systemctl status dump978-fa ● dump978-fa.service - dump978 ADS-B UAT receiver
Loaded: loaded (/lib/systemd/system/dump978-fa.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Wed 2019-04-03 20:21:36 UTC; 4 weeks 1 days ago
Process: 556 ExecStart=/usr/share/dump978-fa/start-dump978-fa (code=exited, status=64)
Main PID: 556 (code=exited, status=64)
Apr 03 20:21:36 piaware systemd[1]: Started dump978 ADS-B UAT receiver.
Apr 03 20:21:36 piaware systemd[1]: dump978-fa.service: Main process exited, code=exited, status=64/n/a
Apr 03 20:21:36 piaware systemd[1]: dump978-fa.service: Unit entered failed state.
Apr 03 20:21:36 piaware systemd[1]: dump978-fa.service: Failed with result ‘exit-code’.
The 1090 instance seems to be working as it should.
Thanks again for the help.
Status doesn’t help… no actual log included.
Use this:
sudo journalctl -eu dump978-fa
Thanks, output below.
– Logs begin at Thu 2016-11-03 17:16:42 UTC, end at Thu 2019-05-02 21:32:42 UTC. –
Yeah that says nothing.
dump978-fa probably isn’t enabled.
post the output of
sudo piaware-config
Did you reboot after changing the settings?
Yes but will do so again
Check the log again.
I’m not sure why there is nothing in the log with that config for piaware.
pi@piaware:~ $ sudo journalctl -eu dump978-fa
May 02 21:58:22 piaware dump978-fa[2603]: json-port: listening for connections o
May 02 21:58:22 piaware dump978-fa[2603]: Found Rafael Micro R820T tuner
May 02 21:58:23 piaware dump978-fa[2603]: Detached kernel driver
May 02 21:58:23 piaware dump978-fa[2603]: Found Rafael Micro R820T tuner
May 02 21:58:23 piaware dump978-fa[2603]: Reattached kernel driver
May 02 21:58:23 piaware systemd[1]: dump978-fa.service: Main process exited, cod
May 02 21:58:23 piaware systemd[1]: dump978-fa.service: Unit entered failed stat
May 02 21:58:23 piaware systemd[1]: dump978-fa.service: Failed with result 'exit
May 02 21:58:53 piaware systemd[1]: dump978-fa.service: Service hold-off time ov
May 02 21:58:53 piaware systemd[1]: Stopped dump978 ADS-B UAT receiver.
May 02 21:58:53 piaware systemd[1]: Started dump978 ADS-B UAT receiver.
May 02 21:58:53 piaware dump978-fa[2745]: raw-port: listening for connections on
May 02 21:58:53 piaware dump978-fa[2745]: json-port: listening for connections o
May 02 21:58:54 piaware dump978-fa[2745]: Found Rafael Micro R820T tuner
May 02 21:58:54 piaware dump978-fa[2745]: Detached kernel driver
May 02 21:58:55 piaware dump978-fa[2745]: Found Rafael Micro R820T tuner
May 02 21:58:55 piaware dump978-fa[2745]: Reattached kernel driver
May 02 21:58:55 piaware systemd[1]: dump978-fa.service: Main process exited, cod
May 02 21:58:55 piaware systemd[1]: dump978-fa.service: Unit entered failed stat
May 02 21:58:55 piaware systemd[1]: dump978-fa.service: Failed with result 'exit
lines 290-312/312 (END)
May 02 21:58:22 piaware dump978-fa[2603]: json-port: listening for connections on 0.0.0.0:30979
May 02 21:58:22 piaware dump978-fa[2603]: json-port: listening for connections on [::]:30979
May 02 21:58:23 piaware systemd[1]: dump978-fa.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
May 02 21:58:23 piaware systemd[1]: dump978-fa.service: Unit entered failed state.
May 02 21:58:23 piaware systemd[1]: dump978-fa.service: Failed with result ‘exit-code’.
May 02 21:58:53 piaware systemd[1]: dump978-fa.service: Service hold-off time over, scheduling restart.
May 02 21:58:53 piaware dump978-fa[2745]: raw-port: listening for connections on 0.0.0.0:30978
May 02 21:58:53 piaware dump978-fa[2745]: raw-port: listening for connections on [::]:30978
May 02 21:58:53 piaware dump978-fa[2745]: json-port: listening for connections on 0.0.0.0:30979
May 02 21:58:53 piaware dump978-fa[2745]: json-port: listening for connections on [::]:30979
May 02 21:58:55 piaware systemd[1]: dump978-fa.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
May 02 21:58:55 piaware systemd[1]: dump978-fa.service: Unit entered failed state.
May 02 21:58:55 piaware systemd[1]: dump978-fa.service: Failed with result ‘exit-code’.
Did you physically unplug the dongles after setting the serial numbers?
Note the pi monitor is showing Receiver: error:not connected to Mode S receiver:not connected to UAT receiver.
and
Multilateration: error: Multilateration enabled but client is not running
No. I will do so now.
After writing a new serial number the power needs to be completely removed before the new number will show.
Thanks. I have power cycled the USB hub and the Pi.Still showing the same console messages as above.
what does
rtl_test
show?
What is INVALIDARGUMENT ?
May be single quotes ’ ’ to be removed from /etc/default/dump978-fa ?
RECEIVER_OPTIONS="--sdr driver=rtlsdr,serial=00000978 --format CS8"
Unlikely, the piaware-config was fine and it’s the sd-card image.
OK, agreed, but what INVALIDARGUMENT is?
