I have two Raspberry Pi’s running at once. My first one is only running PiAware image feeding Flightaware. The second Pi is running ADS-B Reviever scripts and image on Stretch. I want to do is install AcarsDecoder2 (AD2) on either Pi’s with a RTL-SDR V3 dongle that is serialized by me. Is this possible?
How-to Install AcarsDeco2 on Pi2 or Pi3 already running Raspbian Stretch and dump1090 (mutability or fa)
STEP-1, ALTERNATIVE-1
1.1.1 - Download on Desktop/Laptop, the AcarsDeco2 file from http://xdeco.org/?page_id=30
Raspberry Pi 2/3 (Broadcom SoC BCM2836/37 ARMv7 Quad Core) Raspbian GNU/Linux 9.0 (Stretch):
acarsdeco2_rpi2-3_deb9_20180603.tgz
1.1.2 - Copy the downloaded file acarsdeco2_rpi2-3_deb9_20180603.tgz to RPi’s folder /home/pi
using WinSCp or FileZilla
1.1.3 - In RPi, create a folder acars
to hold AcarsDeco2 files, and move the file acarsdeco2_rpi2-3_deb9_20180603.tgz into it
pi@raspberrypi:~ $ sudo mkdir acars
pi@raspberrypi:~ $ sudo mv acarsdeco2_rpi2-3_deb9_20180603.tgz acars/
STEP-1, ALTERNATIVE-2
1.2.1 - In RPi, create a folder acars
1.2.2 - I have uploaded acarsdeco2_rpi2-3_deb9_20180603.tgz to my DropBox account. Using wget command
, you can directly download it from my Drop-Box to RPi and save it in newly created folder acars
pi@raspberrypi:~ $ sudo wget -O acars/acarsdeco2_rpi2-3_deb9_20180603.tgz "https://www.dropbox.com/s/q5tjkkrodsyert7/acarsdeco2_rpi2-3_deb9_20180603.tgz?dl=1"
STEP-2
2.1 - Move into folder acars
pi@raspberrypi:~ $ cd acars
2.2 - Extract downloaded .tgz
file
pi@raspberrypi:~/acars $ sudo tar xzvf acarsdeco2_rpi2-3_deb9_20180603.tgz
acarsdeco2
acarsdeco2.readme
LICENSE.MIT
datasets/
datasets/aircrafts_p.txt
datasets/acars_mls.txt
datasets/aircrafts_s.txt
datasets/airlines.txt
STEP-3
3.1 - Serializ two DVB-T / Prostick dongles
Dongle 1 (for dump1090-mutability): Serial # 00000000
Dongle 2 (for AcarsDeco2): Serial # 00000001
Instruction to serialize are here:
How to Change Serial Number of Dongle - ADSB 1090 + UAT 978 Dongles Plugged Into Same Pi
3.2 - Plug Both Dongles in Pi
3.3 - Reboot Pi
sudo reboot
STEP-4
Check what AcarsDeco2 has detected as DVB-T / Prostick dongles available and their serial numbers
pi@raspberrypi:~/acars $ ./acarsdeco2 --device-list
AcarSDeco2 v.20180603
Available Devices:
0 mnf: Realtek prod: RTL2832U serial: 00000000
1 mnf: Realtek prod: RTL2832UFA serial: 00000001
STEP-5; Run AcarSDeco2 Manually
pi@raspberrypi:~/acars $ ./acarsdeco2 --device-index 1 --gain 49.6 --freq 131550000 131725000 --http-port 8686 &
[1] 981
pi@raspberrypi:~/acars $ AcarSDeco2 v.20180603
Using device: 1 mnf: Realtek prod: RTL2832UFA serial: 00000001
Sampling rate: 1400000.018544 sps
Supported Gains (dB): 0.0 0.9 1.4 2.7 3.7 7.7 8.7 12.5 14.4 15.7 16.6 19.7 20.7 22.9 25.4 28.0 29.7 32.8 33.8 36.4 37.2 38.6 40.2 42.1 43.4 43.9 44.5 48.0 49.6
Freq: 131.637 MHz
Freq Correction: 0 ppm
Gain: 49.6 dB
Trying to use 16 buffers in memory explicitly allocated to support zero-copy
STEP-6 : Automated start at boot / reboot
6.1 - Create a blank file ad2.sh
, make it executable, and open it for editing
pi@raspberrypi:~/acars $ sudo touch ad2.sh
pi@raspberrypi:~/acars $ sudo chmod +x ad2.sh
pi@raspberrypi:~/acars $ sudo nano ad2.sh
6.2 - Copy-paste following code in new blank file ad2.sh
/home/pi/acars/./acarsdeco2 \
--device-index 1 \
--gain 49.6 \
--freq 131550000 131725000 \
--http-port 8686 \
6.3 - Save (Ctrl+o) and Close (Ctrl+x)
6.4 - Open file rc.local
for editing
sudo nano /etc/rc.local
6.5 - Copy-paste following line in file rc.local
just above last line (i.e. just above exit 0
/home/pi/acars/ad2.sh &
6.6 - Save (Ctrl+o) and Close (Ctrl+x)
STEP-7
IP-OF-PI:8686
LOG
FLIGHTS
This is good. Here is my argument line on the windows version;
@echo off
cmd /c acarsdeco2.exe --http-port 8888 --device-serial V3-2 --gain 19.7 --freq 131550000 --freq 131725000 --freq 131875000 --freq 131125000 --outConnectUdp pp:127.0.0.1:9742 --silhouettes C:\acarsdeco2\silhouettes --frdb C:\acarsdeco2\flightroute.sqb --db C:\acarsdeco2\basestation.sqb --banners C:\acarsdeco2\logos --outServer sbs:30008 --outServer ad2:31008 --vrs-url http://127.0.0.1 --logfile c:\acarsdeco2\logs\ACARS
exit
Is it possible to feed Plane Plotter with this line --outConnectUdp pp:127.0.0.1:9742? To my windows computer where Plane Plotter resides?
It should be possible. You can try by adding --outConnectUdp pp:xxx.xxx.xxx.xxx:9742
to the file ad2.sh
The text in file ad2.sh
will now becomes like this:
(Replace xxx.xxx.xxx.xxx
by actual LOCAL IP OF WINDOWS DESKTOP)
/home/pi/ad2/./acarsdeco2 \
--device-index 1 \
--gain 49.6 \
--http-port 8686 \
--outConnectUdp pp:xxx.xxx.xxx.xxx:9742 \
I cannot check it, as I dont have plane plotter on my windows.
However I did above modification to ad2.sh
and started acarsdeco2. It seems to start sending data to a non-existant planeplotter, as shown in second-last line below:
pi@raspberrypi:~/ad2 $ ./ad2.sh
2018-07-22 11:20:53.213 INFO outConnectUdp(PP:192.168.0.10:9742) started
Freq: 131.637 MHz
Gain: 49.6 dB
2018-07-22 11:20:53.846 INFO outConnectUdp(PP:192.168.0.10:9742) start sending
exactly ! it works, provided the user has enabled port forwarding for port 9742 in his/her router for the IP of the machine running Planeplotter.
So far success. I forgot about the port forward. When I did configure my modem I had to use my lan ip address instead of the local ip. now to finish up.
Also remember to select what type of connection, for example TCP or UDP. UDP is the correct one.
I have just now edited the how-to and made following modification:
The name of the folder which holds AcarsDeco2 files was originally ad2
I have now changed it to acars
This is to avoid confusion as name ad2
was used for a folder as well as for the script file ad2.sh
Now folder name is acars
and script file name is ad2.sh
I am having a problem. when I cun the command line test all is great. acarsdeco2 is providing data to my copy of planeplotter. When I set it up to run the ad2.sh automatically the program runs but no data input to my copy of plane plotter.
–device-index 1
–gain 19.7
–freq 131550000 131725000 131875000 131125000
–http-port 8686
–outConnectUdp pp:192.168.0.100:9742
While running a test:
./acarsdeco2 --device-index 1 --http-port 8686 --gain 19.7 --freq 131550000 --freq 131725000 --freq 131875000 --freq 131125000 --outConnectUdp pp:192.168.0.100:9742
Try following:
(1) In file ad2.sh
, delete the above code, and COPY-PASTE the code given below:
--device-index 1 \
--gain 19.7 \
--freq 131550000 \
--freq 131725000 \
--freq 131875000 \
--freq 131125000 \
--http-port 8686 \
--outConnectUdp pp:192.168.0.100:9742 \
(2) If above fails, then in file ad2.sh
, COPY-PASTE the single-line code given below:
It is a long line. Scroll right to see it in full.
/home/pi/acars/./acarsdeco2 --device-index 1 --http-port 8686 --gain 19.7 --freq 131550000 --freq 131725000 --freq 131875000 --freq 131125000 --outConnectUdp pp:192.168.0.100:9742
No luck with either configurations, however the program runs in either way. I still dont get UDP traffic to PP under the ad2.sh.
Try again after adding sudo
at start of first line in file ad2.sh
. The first line will then become like below:
sudo /home/pi/acars/./acarsdeco2 \
Still no luck.I even checked my port forward just incase. but right now I have PUTTY open up as a terminal running the command line and it works sending data to Plane Plotter but if I use ad2.sh no luck.
No idea why this is happening
Hopefully someone else comes up with a solution.
abcd567,
Your help (like always) is very appreciated!
abcd567, is it possible that running the program from the command line with a console is the only way to have output across a local domain? Right now I am running dumpvdl2 from the Pi’s command line console with Udp output to Plane plotter on my windows computer.
I suppose you have run sudo chmod +x ad2.sh
do you see acars messages in the web interface ?
one thing to note, the frequencies should not be spaced longer than 1Mhz, ie 131.5 132.5 or 136.9 (vdl)
Thank you… works like a charm
