As I am reading and trying to learn things with RPi, Linux, scripts, etc (which nothing seems straight forward), I see folks have generated a map of coverage from their ADS-B installation like the one attached. But I am confused on exactly how this is being done. Hoping folks can point in the right direction with some steps to follow??
My setup is simply a RPi3, FA dongle and antenna. I access the RPi via SSL or remote desktop control from a Windows 10 machine.
hi
I use Virtual Radar Server and/or ModeSmixer.
both application create a so called ‘polar plot’ or ‘max range plot’ by connecting
dots 1° or 10° apart. The dots being the furthest away aircraft received
by the user’s receiver.
Well I got virtual radar server installed, configured receivers and location based on my reading. It has been sitting here for a couple of hours now and still no plots. Also, checked the option under web server to allow internet users to see receiver range plots. So I must be missing something as I am not getting range plots.
ok my setup as follows
dongle → rpi → dump1090-mutability beast 30005 on ip 192.168.0.xxx
vrs on pc : tools → options → receiver → 192.168.0.xxx port 30005
vrs map on browser → click menu → receiver → receiver range → receiver → all altitudes and after a while it will draw the plot.
however if you dont see any traffic it means there is connection problem and therefore no plot.
I see I missed one important part in the receiver locations setup. I set my receiver location but noticed I did not choose a location after I added the receiver, port, ip, etc. So, I wasn’t getting the receiver range menu but now I am.
One last clarifying question. From the RPi, which port do I need to add? Just 30005, what about 30002 and 30003? When I add all those ports, I have messages/data coming on all 3 from my RPi. As I found, these were the outbound ports. So do I need all of them or just one?
30002 - Outbound - RAW Format
30003 - Outbound - Base station Format
30005 - Outbound - Beast format
I am only using the FA dongle and PiAware setup. Thank you all for helping a noob out.
@abcd567 - It was the loss (restriction) of google maps that prompted me to write it. It works on any “openlayers” implementation of dump1090. FA is open layers, not sure about the latest mutability, but as it is just a replacement web interface (html/public_html) it certainly works with mutability installs if the complete directory is replaced (the short cut being to index.html and not gmap.html)
works OK for dump1090-fa.
I only had to change the two sets of coordinates
for map/site center in /html/config.js
very handy the button feature to activate items as required !
(i love plain terrain without labels)
brgds/evangel
PS I had written similar utility for Windows sometime ago in VB.
Will try to find and post it here. Works for the VRS-PlanePlotter
combo in M$windoze.
#First re-name existing folder "html" to "html-orignal" to preserve it,
#enabling revert in case something breaks
$ sudo mv /usr/share/dump1090-mutability/html /usr/share/dump1090-mutability/html-orignal
#Check folder "html" has been successfully re-named to "html-orignal"
$ ls /usr/share/dump1090-mutability/
config-template html-orignal
#Clone the Alkissack code
$ git clone https://github.com/alkissack/Dump1090-OpenLayers3-html.git
#Copy cloned "public_html" as "html"
$ sudo cp -a Dump1090-OpenLayers3-html/public_html /usr/share/dump1090-mutability/html
#Check that folder "public_html" has successfully copied as folder "html"
config-template html html-orignal
#Rename "index.html" to "gmap.html"
$ cd /usr/share/dump1090-mutability/html/
$ sudo mv index.html gmap.html
#Clear Browser cache (Ctrl+Shift+Delete) and Reload browser (Ctrl+F5)
Map changed from default Mutability map to dump1090-fa/SkyView type map. It is OK
Why all planes are shown originating from UK? I am in Toronto Canada.
You mentioned config.js in your previous post
I now changed default and site coordinates in config.js, but still the same result.
$ sudo nano /usr/share/dump1090-mutability/html/config.js
// Default center of the map.
DefaultCenterLat = 43.5xxx;
DefaultCenterLon = -79.6xxx;
// The google maps zoom level, 0 - 16, lower is further out
DefaultZoomLvl = 7;
// Center marker. If dump1090 provides a receiver location,
// that location is used and these settings are ignored.
SiteShow = true; // true to show a center marker
SiteLat = 43.5xxx; // position of the marker
SiteLon = -79.6xxx;
SiteName = "Rx"; // tooltip of the marker
