True, the Pi24 image is ugly, but still does its job.
Comparing based on GUI, I will rate as follows: #1 - tar1090 #2 - dump1090-fa #3 - dump1090-mutability ver1.15/EB_VER (currently used by FR24) #4 - dump1090 (Malcolm Robb)
Sorry that I forgot to include it. I remember it being mentioned in forum posts occasionally, but never used it, so dont know much about it. Where would you place it in my rating list?
I call it a tie with tar1090. Depends how many bells and whistles one wants. No need to apologize to me, I didn’t create it, but I really like it and think he did a great job. Super glad I came across it, so figure it’s worth the publicity as others may enjoy as well.
EDIT/ADD - Reference to a post I made sometime back with some basic instructions for those who may be interested to try without overwriting any existing overlays:
These are shown twice if i am correct. Once in the first chart, then further down in “ADS-B” maxima.
There is a small deviation in the line, the second one looks “flattened” and lower than in the first chart.
The max. message rate at this point in time was 1102
Not a big difference, but noticeable. I would like to understand what makes the difference here.
The screenshots were taken from the 8 hour selection, in the 2 hour selection, both lines are the same.
But also on the 24 hour scaling, the first line looks “smoother”
The bottom graph is technically more accurate, as we have a value for every minute, which is best shown with steps instead of drawing lines from point to point (slopes).
Also for longer time scales the maxima graph behaves quite a bit different than the first graph, as transitioning data to one pixel representing longer time spans means you need to either average or maximize / minimize over the represented data points.
Thanks for the explanation. Makes totally sense.
I am dealing with lots of charts in my job and personally like the non-adjusted ones with steps more giving more accuracy and showing the time perspective better
I assume you wanted to add something different, but you quoted my question twice
After upgrading to Ubuntu 20, the graphs1090 don’t work anymore.
sudo journalctl --no-pager -u collectd
Aug 16 15:31:53 Ubuntu-Latitude-E6420 collectd[3943427]: ERROR: dlopen("/usr/lib/collectd/python.so") failed: /usr/lib/collectd/python.so: undefined symbol: PyFloat_Type. The most common cause for this problem is missing dependencies. Use ldd(1) to check the dependencies of the plugin / shared object.
Aug 16 15:31:53 Ubuntu-Latitude-E6420 collectd[3943427]: dlopen("/usr/lib/collectd/python.so") failed: /usr/lib/collectd/python.so: undefined symbol: PyFloat_Type. The most common cause for this problem is missing dependencies. Use ldd(1) to check the dependencies of the plugin / shared object.
Aug 16 15:31:53 Ubuntu-Latitude-E6420 collectd[3943427]: plugin_load: Load plugin "python" failed with status 2.
Aug 16 15:31:53 Ubuntu-Latitude-E6420 collectd[3943427]: Found a configuration for the `python' plugin, but the plugin isn't loaded or didn't register a configuration callback.
Aug 16 15:31:53 Ubuntu-Latitude-E6420 collectd[3943427]: Plugin python failed to handle option ModulePath, return code: -1
Aug 16 15:31:53 Ubuntu-Latitude-E6420 collectd[3943427]: Error: Parsing the config file failed!
Aug 16 15:31:53 Ubuntu-Latitude-E6420 systemd[1]: collectd.service: Main process exited, code=exited, status=1/FAILURE
Aug 16 15:31:53 Ubuntu-Latitude-E6420 systemd[1]: collectd.service: Failed with result 'exit-code'.
Aug 16 15:31:53 Ubuntu-Latitude-E6420 systemd[1]: Failed to start Statistics collection and monitoring daemon.
top shows the percentage of CPU utilization as it relates to 1 core so if you have a 4 core processor and top shows 100% for the process, then that process is actually using 25% of the total cycles available. I believe collectd is reporting the % utilization related to the total cycles available.
@wiedehopf Is there an easy way to get multiple instances running? I’ve got multiple instances of dump1090-fa dump978-fa skyaware978 and tar1090 working well but I can’t figure out how to do it with graphs1090 other than hacking the scripts to add an instance id. So far, that’s not worked out too well.
