Graphs for dump1090 -- my version with install script
Yeah my graphs are not compatible with the adsb-receiver graphs.
Or rather either one is active or the other is active.
Very useful, thank you.
You can see where I decreased my gain from 14 to 13 yesterday.
signal-level
Heres mine started few hours ago adjusted gain from 17 to18 where it normally sits for past months but now i can see the results
Screenshot_404
i have got happy medium with best aircraft count and messages balance
Yeah at least for that it’s useful :slight_smile:
No need to write down when you changed the gain for comparison of graphs.
If you update again could you show if and how the graph changes?
I would expect the mean signal to increase a bit.
Oh wow, what an abomination of a sentence -.-
I updated just before I posted last night so it would have been roughly where the red line is.
updated
Not sure which purple lines you mean.
the noise levels referred to in the legend at the bottom. I have not yet updated the graphs.
Airspy does not provide noise levels.
The signal graph for airspy as i wrote above is just based on the RSSI values for all planes.
Biggest RSSI value becomes peak, smallest RSSI value becomes weakest signal.
Average of all planes becomes mean signal.
For rtl-sdr the mean signal is averaged over all messages not over all planes.
So the results can be quite different.
But when you change gain, changes are visible in this graph, for that alone it’s useful.
Have I missed an update or is it still not plotted?
Noise
For me, with a slight bug in the ability to see colours correctly, it’s quite hard to see the blue-ish(?) line on the green background. It kind of blends in with the green… :upside_down_face:
Seems it’s not drawing correctly for you.
It shouldn’t be that washed out.
Should look like this:
Anyway do this:
sudo sed -i -e 's/0099FF/000000/' /usr/share/graphs1090/graphs1090.sh
Write the command down you’ll need it again after you update :wink:
The command changes the line to black.
Just to clarify, noise is not plotted, the RSSI of the weakest plane being received is ploted.
Probably my laptop that has some problems with colours.
Anyway, it now looks much better!
Thanks for the fix for us with bugs in the visual databus :crazy_face:
I think making a different color scheme is next on the agenda.
But configurable colors most likely, so people who want to keep the old scheme can keep it.
Having options is always nice, but we are happy with what we get since we don’t have to do the work ;).
Thanks for the work you do :slight_smile:
@wiedehopf
I am unable to install the graph. Any clue on it? Thanks.
The following NEW packages will be installed:
  collectd-core rrdtool
0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/1,362 kB of archives.
After this operation, 4,399 kB of additional disk space will be used.
Preconfiguring packages ...
Selecting previously unselected package collectd-core.
(Reading database ... 42503 files and directories currently installed.)
Preparing to unpack .../collectd-core_5.7.1-1.1_armhf.deb ...
Unpacking collectd-core (5.7.1-1.1) ...
Selecting previously unselected package rrdtool.
Preparing to unpack .../rrdtool_1.6.0-1+b1_armhf.deb ...
Unpacking rrdtool (1.6.0-1+b1) ...
Setting up rrdtool (1.6.0-1+b1) ...
Setting up collectd-core (5.7.1-1.1) ...
Job for collectd.service failed because the control process exited with error co        de.
See "systemctl status collectd.service" and "journalctl -xe" for details.
invoke-rc.d: initscript collectd, action "start" failed.
● collectd.service - Statistics collection and monitoring daemon
   Loaded: loaded (/lib/systemd/system/collectd.service; enabled; vendor preset:        enabled)
   Active: activating (auto-restart) (Result: exit-code) since Tue 2019-06-25 08        :04:37 +08; 47ms ago
     Docs: man:collectd(1)
           man:collectd.conf(5)
           https://collectd.org
  Process: 1469 ExecStartPre=/usr/sbin/collectd -t (code=exited, status=1/FAILUR        E)
Jun 25 08:04:37 piaware-E201805-694 systemd[1]: collectd.service: Control pr…s=1
Jun 25 08:04:37 piaware-E201805-694 systemd[1]: Failed to start Statistics c…on.
Jun 25 08:04:37 piaware-E201805-694 systemd[1]: collectd.service: Unit enter…te.
Jun 25 08:04:37 piaware-E201805-694 systemd[1]: collectd.service: Failed wit…e'.
Hint: Some lines were ellipsized, use -l to show in full.
dpkg: error processing package collectd-core (--configure):
 subprocess installed post-installation script returned error exit status 1
Processing triggers for systemd (232-25+deb9u11) ...
Processing triggers for man-db (2.7.6.1-2) ...
Errors were encountered while processing:
 collectd-core
E: Sub-process /usr/bin/dpkg returned an error code (1)
Failed to install required packages: collectd-core rrdtool lighttpd unzip python
Exiting ...
~ $ systemctl status collectd.service
   Active: activating (auto-restart) (Result: exit-code) since Tue 2019-06-25 08:10:24 +08; 8s ago
  Process: 2615 ExecStart=/usr/sbin/collectd (code=exited, status=1/FAILURE)
  Process: 2612 ExecStartPre=/usr/sbin/collectd -t (code=exited, status=0/SUCCESS)
 Main PID: 2615 (code=exited, status=1/FAILURE)
Jun 25 08:10:24 piaware-E201805-694 systemd[1]: collectd.service: Main process exited, code=exited, status=1/FAILURE
Jun 25 08:10:24 piaware-E201805-694 systemd[1]: Failed to start Statistics collection and monitoring daemon.
Jun 25 08:10:24 piaware-E201805-694 systemd[1]: collectd.service: Unit entered failed state.
Jun 25 08:10:24 piaware-E201805-694 systemd[1]: collectd.service: Failed with result 'exit-code'.
Just try again.
Also check the log:
sudo journalctl -u collectd --no-pager
I tried and still cannot install.
Jun 25 17:31:03 piaware-E201805-694 systemd[1]: collectd.service: Service hold-off time over, scheduling restart.
Jun 25 17:31:03 piaware-E201805-694 systemd[1]: Stopped Statistics collection and monitoring daemon.
Jun 25 17:31:03 piaware-E201805-694 systemd[1]: Starting Statistics collection and monitoring daemon...
Jun 25 17:31:03 piaware-E201805-694 collectd[16939]: Failed to open types database `/usr/share/graphs1090/dump1090.db': No such file or directory.
Jun 25 17:31:03 piaware-E201805-694 collectd[16939]: plugin_load: plugin "syslog" successfully loaded.
Jun 25 17:31:03 piaware-E201805-694 collectd[16939]: plugin_load: plugin "rrdtool" successfully loaded.
Jun 25 17:31:03 piaware-E201805-694 collectd[16939]: plugin_load: plugin "table" successfully loaded.
Jun 25 17:31:03 piaware-E201805-694 collectd[16939]: plugin_load: plugin "interface" successfully loaded.
Jun 25 17:31:03 piaware-E201805-694 collectd[16939]: plugin_load: plugin "memory" successfully loaded.
Jun 25 17:31:03 piaware-E201805-694 collectd[16939]: plugin_load: plugin "cpu" successfully loaded.
Jun 25 17:31:03 piaware-E201805-694 collectd[16939]: plugin_load: plugin "aggregation" successfully loaded.
Jun 25 17:31:03 piaware-E201805-694 collectd[16939]: plugin_load: plugin "match_regex" successfully loaded.
Jun 25 17:31:03 piaware-E201805-694 collectd[16939]: plugin_load: plugin "df" successfully loaded.
Jun 25 17:31:03 piaware-E201805-694 collectd[16939]: plugin_load: plugin "disk" successfully loaded.
Jun 25 17:31:03 piaware-E201805-694 collectd[16939]: plugin_load: plugin "python" successfully loaded.
Jun 25 17:31:03 piaware-E201805-694 collectd[16939]: Traceback (most recent call last):
Jun 25 17:31:03 piaware-E201805-694 collectd[16939]:   File "/usr/lib/python2.7/site.py", line 554, in <module>
Jun 25 17:31:03 piaware-E201805-694 collectd[16939]:     main()
Jun 25 17:31:03 piaware-E201805-694 collectd[16939]:   File "/usr/lib/python2.7/site.py", line 536, in main
Jun 25 17:31:03 piaware-E201805-694 collectd[16939]:     known_paths = addusersitepackages(known_paths)
Jun 25 17:31:03 piaware-E201805-694 collectd[16939]:   File "/usr/lib/python2.7/site.py", line 272, in addusersitepackages
Jun 25 17:31:03 piaware-E201805-694 collectd[16939]:     user_site = getusersitepackages()
Jun 25 17:31:03 piaware-E201805-694 collectd[16939]:   File "/usr/lib/python2.7/site.py", line 247, in getusersitepackages
Jun 25 17:31:03 piaware-E201805-694 collectd[16939]:     user_base = getuserbase() # this will also set USER_BASE
Jun 25 17:31:03 piaware-E201805-694 collectd[16939]:   File "/usr/lib/python2.7/site.py", line 237, in getuserbase
Jun 25 17:31:03 piaware-E201805-694 collectd[16939]:     USER_BASE = get_config_var('userbase')
Jun 25 17:31:03 piaware-E201805-694 collectd[16939]:   File "/usr/lib/python2.7/sysconfig.py", line 582, in get_config_var
Jun 25 17:31:03 piaware-E201805-694 collectd[16939]:     return get_config_vars().get(name)
Jun 25 17:31:03 piaware-E201805-694 collectd[16939]:   File "/usr/lib/python2.7/sysconfig.py", line 528, in get_config_vars
Jun 25 17:31:03 piaware-E201805-694 collectd[16939]:     _init_posix(_CONFIG_VARS)
Jun 25 17:31:03 piaware-E201805-694 collectd[16939]:   File "/usr/lib/python2.7/sysconfig.py", line 412, in _init_posix
Jun 25 17:31:03 piaware-E201805-694 collectd[16939]:     from _sysconfigdata import build_time_vars
Jun 25 17:31:03 piaware-E201805-694 collectd[16939]:   File "/usr/lib/python2.7/_sysconfigdata.py", line 6, in <module>
Jun 25 17:31:03 piaware-E201805-694 collectd[16939]:     from _sysconfigdata_nd import *
Jun 25 17:31:03 piaware-E201805-694 collectd[16939]:   File "/usr/lib/python2.7/plat-arm-linux-gnueabihf/_sysconfigdata_nd.py", line 1
Jun 25 17:31:03 piaware-E201805-694 collectd[16939]: SyntaxError: Non-ASCII character '\xa4' in file /usr/lib/python2.7/plat-arm-linux-gnueabihf/_sysconfigdata_nd.py on line 1, but no encoding declared; see http://python.org/dev/peps/pep-0263/ for details
Jun 25 17:31:03 piaware-E201805-694 systemd[1]: collectd.service: Control process exited, code=exited status=1
Jun 25 17:31:03 piaware-E201805-694 systemd[1]: Failed to start Statistics collection and monitoring daemon.
Jun 25 17:31:03 piaware-E201805-694 systemd[1]: collectd.service: Unit entered failed state.
Jun 25 17:31:03 piaware-E201805-694 systemd[1]: collectd.service: Failed with result 'exit-code'.
After restart also the same.
Please show any errors for these commands:
sudo apt purge -y collectd-core rrdtool python libpython2.7
sudo apt install -y collectd-core rrdtool lighttpd unzip python
sudo apt install -y libpython2.7
The install script will hopefully work after that.
Maybe not though, we will see.
Ah and please show the output of this:
cat /etc/os-release
If you are still on jessie i’d strongly recommend just making a new sd-card with buster.
Previosuly installed the graph on PiAware 3.7.1 SD.
Anyway, I already re-flash the uSD card to Raspbian Buster. All installations works, including the How-to Read / Set Gain from SkyView and Gmap - #104 by abcd567.
*Just change this (If using Raspbian Buster): - sudo apt install php7.3-cgi
Thanks for the reply. You are great for this graph, bigger look.
Best regards.
You can make the pictures even larger if you want.
It’s configured in the file /etc/default/graphs1090
Thanks for the advise.
Cheers.
