I want to install the ADS-B flighttracking software on a odroid C2.
But i can not find how to do that, the standard image is for a raspberry pi, and doesn’t work on the Odroid.
Is there a step by step installation Guide?
There is nothing official, but you might find this thread useful: Package Install of Piaware ver 7.2 on ARM64 / AARCH64 and AMD64 / x86_64 Machines
In case you want to look at readsb instead of dump1090-fa (very similar): https://github.com/wiedehopf/adsb-wiki/wiki/Raspbian-Lite:-ADS-B-receiver
As caius wrote, you’ll just have to use a Debian or Ubuntu image for the C2, get connected via SSH and go from there.
Does it come with a linux image? Otherwise i’m pretty sure Odroid offer an image.
If none of the pre-built packages work on OP’s OS (unknown), he may built these packages from source-code right on his C2 using following scripts:
Copy-paste following command in SSH console and press Enter key. The script will built & install dump1090-fa.
SCROLL RIGHT TO SEE AND COPY THE COMMAND IN FULL
sudo bash -c "$(wget -O - https://raw.githubusercontent.com/abcd567a/piaware-ubuntu20-amd64/master/install-dump1090-fa.sh)"
Copy-paste following command in SSH console and press Enter key. The script will built & install piaware.
sudo bash -c "$(wget -O - https://raw.githubusercontent.com/abcd567a/piaware-ubuntu20-amd64/master/install-piaware.sh)"
Copy-paste following command in SSH console and press Enter key. The script will built & install piaware-web.
sudo bash -c "$(wget -O - https://raw.githubusercontent.com/abcd567a/piaware-ubuntu20-amd64/master/install-piaware-web.sh)"
Thanks for all information, tommorow i will try the different solutions.
The goal is to feed to flightradar and flightaware.
Which OS image you have installed (or will install) on Odroid C2?
I have just installed Debian Stretch.
Stretch is too old. I think it has already reached end of support.
Better try one of following latest ones:
Download page: https://dietpi.com/#download
Image download link: https://dietpi.com/downloads/images/DietPi_OdroidC2-ARMv8-Bullseye.7z
Installation instructions: https://dietpi.com/docs/install/
Download page:https://www.armbian.com/odroid-c2/
Image download link: https://redirect.armbian.com/odroidc2/Jammy_current
I think you would be much better off using a current Ubuntu 20.04 LTS
https://wiki.odroid.com/odroid-c2/os_images/ubuntu/v4.1
I used to use Ubuntu to feed with an Odroid XU4 but I have since moved the feeder to a RPi 4.
now i have installed Ubuntu 20.04 LTS.
Then:
after
all this, it was working on an Odroid C2.
I als installed fr24feeder, and that is also working.
Is it possible also to feed to adsbexchange, and is there also a unbuntu script for?
sudo bash -c "$(wget -nv -O - https://raw.githubusercontent.com/adsbxchange/adsb-exchange/master/install.sh)"
wget http://client.planefinder.net/pfclient_5.0.161_armhf.deb
sudo dpkg -i pfclient_5.0.161_armhf.deb
After installation of planefinder package, in your browser go to following address and complete signup:
ip-of-odroid:30053
sudo bash -c "$(wget -O - http://apt.rb24.com/inst_rbfeeder.sh)"
sudo bash -c "$(curl -L -o - https://github.com/wiedehopf/graphs1090/raw/master/install.sh)"
Thanks,
I have installed all the option you give.
Planefinder and adsbexchange are working
But radarbox24 is not working, and Graphs is not working.
What are outputs of following commands?
uname -a
lsb_release -a
apt-cache policy rbfeeder
For graphs not working, please wait for responce from @wiedehopf
uname -a
Linux odroid 3.16.82-59 #1 SMP PREEMPT Mon Jun 15 17:18:37 UTC 2020 aarch64 aarch64 aarch64 GNU/Linux
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 20.04.4 LTS
Release: 20.04
Codename: focal
N: Unable to locate package rbfeeder
radarbox not workign is usually just the config not set to network_mode.
Ubuntu 20.04 is a known issue, search the graphs1090 readme.
The arm64 fix should work for you.
just tried the arm64 fix, bud didn’t help
on the ui page i see empty icons, and no data
but with the “sudo apt update” i see an error, maybe that is the problem.
i placed the command “apt list --upgradable”
and that fixed the problem.
Run the rbfeeder installation script again.
What is output message when installation script finishes?
I don’t think there is rbfeeder for anything but armhf.
If rbfeeder for a particular OS ver is not available, then last line of output of rbfeeder installation script will be following::
Don't know how to install for a distribution named
The workaround is to cheat the script to think Ubuntu “focal” is Debian “bullseye”
@Dutchronnie : Try following workaround
wget http://apt.rb24.com/inst_rbfeeder.sh
sudo nano inst_rbfeeder.sh
Scroll down to following line:
Comment it out (place # at its start), and add a line below it VERS=bullseye
Save file
Give following command, and RB24 feeder will most likely get installed without any further issues.
sudo bash inst_rbfeeder.sh
thanks again for alll the help.
The workarround did the fix for radarbox.
but MLAT is not working.
the instructions on the radarbox site don’t work.
Is this related to the same workarround?
