Setting up from scratch with Trixie?
Hi there,
Well the time has come…I have 8 Pi’s with my ‘main’ box running my VR stuff which looks like it has a corrupt SD Card and will not boot. My carefully curated backup system failed a while ago where most of my Pi’s lost the ability to clone the system card to a spare as I had been doing for years.
I rebooted my main PoE switch and 7 Pi’s came back up but of course the one that failed was my VR box…typical…the very one that I would have no idea of how to start from scratch on.
So…as I am still running Bullseye on all 8 of the Pi 4 4GB I figured I’d better get up to date and so downloaded Pi Imager and wrote Trixie to a 128GB microSD Card, inserted it into my ‘dead’ Pi and plugged it into the PoE cable and Yay…up it came.
So now I need to start from scratch installing the four packages I feed;
FlightAware
FlightRadar 24
RadarBox 24
ADS-B Exchange
But how best to go about this?
Which package to install first and how to configure from scratch using the AirSpy 2 I have sat in its box since Feb 2022 instead of the old RadarBox Green dongle I have been using since 2020-ish?
Is there a resource anywhere that might help me or is there a patient, kind-hearted soul that can walk this ‘forgotten more than I ever knew in the first place’ sap through the entire process please which might also serve to help others in the future?
I don’t have direct access to any of my Pi’s through keyboard/mouse/monitor but access through RDP, SSH and various Apps which may very well be a problem now I am using Trixie as ISTR things like XRDP would not even work properly when using 64-bit Bullseye let alone a 3-generation newer Raspberry Pi OS.
So how best to proceed with a virgin Pi/Trixie to add my four Flight Feeders, AirSpy 2 etc.
Thanks & kind regards,
-=Glyn=-
Well, there is this thread about trixie and piaware.
abcd567 also wrote somewhere how to add different feeders to one install, not sure if is in this one, as well.
Maybe it is also worth to take a look at ADSB.im, it is a convenient way to feed different aggregators and a lot of other stuff, maybe you could consolidate the amount of Pis you are using.
By far the easiest way: Use a premade image:
https://adsb.im
Oh someone already pointed it out.
There is also new sites using the tar1090 interface you would have seen on adsbexchange that are easy to add with the image:
https://adsb.lol / https://globe.airplanes.live / https://globe.adsb.fi and a couple others.
Airspy R2 will work out of the box.
If you have a filtered LNA that’s recommended for ADS-B with the airspy but it will work fine without it.
Hi @GlynH
Glad to see you after a long gap. How are you doing?
Here is the how-to you require.
(1) Installing dump1090-fa & piaware on Raspberry Pi OS Trixie
Flightaware has not (yet) released their packages for Trixie. However you can still Install pre-built packages from my PPA (Personal Package Archieves) on Github. I have built these packages using Flightaware source code, and have tested these and running on two of my RPis for more than 2 months without any issue.
(1.1) Issue following 3 commands to add list of packages at my PPA, to your RPi’s apt sources list
NOTE: First two commands are very long, and their right-most part may not be visible. Please scroll right to see and copy these in full
sudo wget -O /etc/apt/sources.list.d/abcd567a.list https://abcd567a.github.io/debian13/abcd567a.list
sudo wget -O /etc/apt/keyrings/abcd567a-key.gpg https://abcd567a.github.io/debian13/KEY2.gpg
sudo apt update
(1.2) Issue following commands to install dump1090-fa, piaware & piaware -web:
sudo apt update
sudo apt install dump1090-fa
sudo reboot
sudo apt install piaware
sudo apt install piaware-web
(1.3) Configure piaware:
sudo piaware-config feeder-id xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
(1.4) IMPORTANT: As you will install pre-built packages by this method from my PPA, in order to avoid any conflict with Flightaware Repository in future (when they release their package for Trixie), I strongly recommend that after installation of packages is comleted and running ok, remove entry of my PPA from your RPi’s apt sources list. This can be done by following commands:
sudo rm /etc/apt/sources.list.d/abcd567a.list
sudo rm /etc/apt/keyrings/abcd567a-key.gpg
sudo apt update
(2) Install Graphs by @wiedehopf
sudo bash -c "$(curl -L -o - https://github.com/wiedehopf/graphs1090/raw/master/install.sh)"
(3) Install Additional Feeders
(3.1) Flightradar24 Feeder
wget -qO- https://fr24.com/install.sh | sudo bash -s
After completing email. feeder-key, replied YES, to following question:
Would you like to use autoconfig (*yes*/no)$: yes
Next issued following commands:
sudo systemctl enable fr24feed
sudo systemctl restart fr24feed
(3.2) Planefinder Feeder
wget http://client.planefinder.net/pfclient_5.3.29_arm64.deb
sudo dpkg -i pfclient_5.3.29_arm64.deb
After installation completed, in browser opened following address, and completed configuration:
IP-of-DebianPC:30053
(3.3) AIS-catcher
sudo bash -c "$(wget -O - https://raw.githubusercontent.com/abcd567a/install-aiscatcher/master/install-aiscatcher.sh)"
(3.4) Planeplrotter uploadedr - ppup1090
sudo bash -c "$(wget -O - https://github.com/abcd567a/ppup1090/raw/master/install-ppup.sh)"
(3.5) RadaBox24
The Radarbox24 feeder is NOT available for Trixie
It is available for for Bookworm, but their repository & installation script are designed for Bookworm & Bullseye, and fail on Trixie.
Following is the workaround for installing rbfeeder on RPi (arm64) running OS Trixie:
(3.5.1) Install tools
sudo apt install dirmngr gnupg
(3.5.2) Set apt
Note: Following three (3) commands are very long. Scroll right to see and copy these in full
gpg --keyserver keyserver.ubuntu.com --recv-keys F2A8428D3C354953
gpg --export --armor F2A8428D3C354953 | sudo gpg --dearmor -o /etc/apt/keyrings/rb24.gpg
echo "deb [signed-by=/etc/apt/keyrings/rb24.gpg] https://apt.rb24.com/ bookworm main" | sudo tee /etc/apt/sources.list.d/rb24.list
(3.5.3) Update apt and install rbfeeder:
sudo apt update
sudo apt install rbfeeder
(3.5.4) After installation is completed, signup as follows:
sudo systemctl restart rbfeeder
After a few seconds, RBFeeder will connect to the AirNav servers and you can view your sharing-key with this command:
sudo rbfeeder --showkey
If you already have a sharing-key from a previous installation, you can set the same key using this command:
sudo rbfeeder --setkey ‹your sharing key›
(3.5.5) Install mlat-client
The installation of mlat-client from RB24 repository by command sudo apt install mlat-client fails with following error message:
mlat-client:arm64 Depends python3 (< 3.12) but this is not installable (Trixie apt provides python 3.13)
Solution: Build & install mlat-client using source code
sudo apt install git build-essential debhelper dh-python python3-dev python3-setuptools python3-pyasyncore
git clone https://github.com/mutability/mlat-client
cd mlat-client
sudo dpkg-buildpackage -b --no-sign
cd ../
sudo dpkg -i mlat-client_0.2.13_*.deb
And that is all. The rbfeeder installation is completed.
Check status by following command
sudo systemctl status rbfeeder
Please see this post:
@abcd567 I came across this today while exploring tcltls-rebuild on GitHub.
https://core.tcl-lang.org/tcltls/tktview?name=6dd5588df6
It seems the problem was finally fixed in October. Does this mean that the apt-mark hold tcl-tls associated with your version of PiAware for Trixie is no longer required?
I just now removed hold from tcl-tls and isuied sudo apt update and sudo apt upgrade, and the package i built (tcltls-rebiilt) was immediately replaced by tcl-tls from Debian repository.
apt-cache policy tcl-tls
tcl-tls:
  Installed: 1.8.0-2
  Candidate: 1.8.0-2
  Version table:
 *** 1.8.0-2 500
        500 http://deb.debian.org/debian trixie/main arm64 Packages
        100 /var/lib/dpkg/status
I then rebooted Pi and after reboot, checked pisware. It reported failure due to TLS. Please see screenshot attached below.
Now there’s 4 packages that can’t be upgraded in Trixie:
pi@trixie:~ $ sudo apt update
Hit:1 http://deb.debian.org/debian trixie InRelease
Hit:2 http://deb.debian.org/debian trixie-updates InRelease
Hit:3 http://deb.debian.org/debian-security trixie-security InRelease
Hit:4 http://archive.raspberrypi.com/debian trixie InRelease
4 packages can be upgraded. Run 'apt list --upgradable' to see them.
pi@trixie:~ $ apt list --upgradable
libcamera-ipa/stable 0.6.0+rpt20251202-1 arm64 [upgradable from: 0.5.2+rpt20250903-1+b1]
librpicam-app1/stable 1.10.1-1 arm64 [upgradable from: 1.10.0-1]
rpicam-apps-core/stable 1.10.1-1 arm64 [upgradable from: 1.10.0-1]
tcl-tls/stable 1.8.0-2 arm64 [upgradable from: 1.7.22-2+fa1]
pi@trixie:~ $ sudo apt upgrade
Not upgrading:
  libcamera-ipa  librpicam-app1  rpicam-apps-core  tcl-tls
Summary:
  Upgrading: 0, Installing: 0, Removing: 0, Not Upgrading: 4
I guess it doesn’t matter though --those 3 other packages seem to be related to camera software, which I’m not using.
Thanks - I will leave the hold in place.
If you get sick of the Not upgrading: message
sudo apt remove libcamera-ipa librpicam-app1 rpicam-apps-core
Ok. Also this could be a phased upgrade. Maybe wait a few days to get the upgrade. I think I have seen this before.
Reading package lists… Done
Building dependency tree… Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
rbfeeder : Depends: libcurl4 (>= 7.16.2) but it is not installable
Depends: libglib2.0-0 (>= 2.12.0) but it is not installable
Depends: librtlsdr0 (>= 0.6.0) but it is not installable
E: Unable to correct problems, you have held broken packages.
This happens if your OS is 32-bit (armhf).
Ok. How install radarbox on my orange pc light?
What are outputs of following commands?
uname -a
lsb_release -a
cat /etc/os-release
dpkg --print-architecture
dpkg --print-foreign-architectures
cat /proc/cpuinfo | grep Hardware
cat /proc/cpuinfo | grep model
6.12.68-current-sunxi #2 SMP Fri Jan 30 09:28:49 UTC 2026 armv7l armv7l armv7l GNU/Linux
Distributor ID: Ubuntu
Description: Armbian 26.2.0-trunk.368 noble
Release: 24.04
Codename: noble
"Armbian 26.2.0-trunk.368 noble
armhf
Allwinner sun8i Family
ARMv7 Processor rev 5 (v7l)
Try following commands:
sudo apt update
sudo apt install rbfeeder:armhf
sudo apt --fix-broken install
If above fails, then reimage your microSD card with Armbian Bookworm. All packages from Flightaware and Radarbox24 are compatible to this OS on OrangePi PC. This is what Ivhave done on my OrangePiPC.
Downloaded Armbian Bookworm image from Armbian archives linked below:
https://armbian.lv.auroradev.org/archive/orangepipc/archive/
I have worked Fa, piaware, FR, dump1090.
I need last - RB
RB24 is NOT compatible to Ubuntu 24 (Noble) on OrangePi PC.
If you want RB24, please re-image your microSD Card with 32-bit (armhf) Armbian Bookworm. The RB24 is compatible on it.
I have also installed RB24 on my OrangPI PC.
I first tried Armbian Trixie, but did not succeed. Then wrote 32-bit Armbian Bookworm on microSD card, and succeeded to install all feeders including RB24.
You can download the Armbian Bookworm for OrangePi OC frim Armbian archieves linked below:
Click on Screenshot to See Larger Size
Good news
Yesterday I forked githubairnav/rbfeeder source code to my Github repository.
This source code was last updated 4 years ago, and failed to compile on Bookworm, Trixie, Forky, and Noble.
I did necessary modifications / updates to my forked copy. The source code of my forked copy became compatible to Bookworm, Trixie, Forky, and Noble.
I have successfully compiled and installed rbfeeder:armhf on my OrangePiPC (armv7) with following 32-bit OS
(1) Armbian Trixie
(2) Armbian Noble
I have made these .deb packages available on my Github site.
Anyone can install these packages on 32-bit OrangePiPC by following metdod:
(1) Armbian Ubuntu Noble
NOTE: The first command is very long and its right-most part may not be visible
Please scroll right to see and copy it in full
wget https://github.com/abcd567a/rbfeeder/releases/download/v1.0/rbfeeder_1.0.20_noble_armhf.deb
sudo dpkg -i rbfeeder_1.0.20_noble_armhf.deb
## The above command will give error message (Missing dependencies), and halt.
## Issue following command to fix the issue of missing dependencies.
## It will start installing missing dependencies and complete the installation of rbfeeder.
## NOTE: Following three commands are very important
sudo usermod -aG plugdev rbfeeder
sudo wget -O /etc/udev/rules.d/rtl-sdr.rules https://github.com/abcd567a/temp/raw/main/rtl-sdr.rules
sudo reboot
## After reboot, check status
(2) Armbian Trixie
wget https://github.com/abcd567a/rbfeeder/releases/download/v1.0/rbfeeder_1.0.20_trixie_armhf.deb
sudo dpkg -i rbfeeder_1.0.20_trixie_armhf.deb
sudo reboot
Install mlat-client
mlat-client: Depends python3 (< 3.12) but this is not installable (Trixie apt provides python 3.13)
Build & install mlat-client:
sudo apt install git build-essential debhelper dh-python libgcc-14-dev
sudo apt install python3-pyasyncore python3-dev python3-setuptools
cd mlat-client
cd ../
sudo apt-mark hold mlat-client
