Debian 13 Trixie (Stable) was officially released on Aug 09, 2025
https://www.debian.org/distrib/
Screenshots of Debian 13.0.0 amd64, installed in Oracle VM on Windows 11 PC
Click on Screenshot to See Larger Size
Click Again to See Full Size
Installed dump1090-fa, piaware, piaware-web and dump978-fa
1 of 4: Install dump1090-fa
sudo bash -c "$(wget -O - https://raw.githubusercontent.com/abcd567a/piaware-ubuntu-debian-amd64/master/install-dump1090-fa.sh)"
2 of 4: Install piaware
sudo bash -c "$(wget -O - https://raw.githubusercontent.com/abcd567a/piaware-ubuntu-debian-amd64/master/install-piaware.sh)"
3 of 4: Install piaware-web
sudo bash -c "$(wget -O - https://raw.githubusercontent.com/abcd567a/piaware-ubuntu-debian-amd64/master/install-piaware-web.sh)"
4 of 4: Install dump978-fa
sudo bash -c "$(wget -O - https://raw.githubusercontent.com/abcd567a/piaware-ubuntu-debian-amd64/master/install-dump978-fa.sh)"
Installed Graphs by @wiedehopf
sudo bash -c "$(curl -L -o - https://github.com/wiedehopf/graphs1090/raw/master/install.sh)"
Installed Additional Feeders
(1) Flightradar24
on PC (amd64 / x86_64 ) and on RPi (arm64 / aarch64)
wget -qO- https://fr24.com/install.sh | sudo bash -s
After completing email. feeder-key, replied YES, to following question:
Would you like to use autoconfig (*yes*/no)$: yes
Next issued following commands:
sudo systemctl enable fr24feed
sudo systemctl restart fr24feed
(2) Planefinder
amd64 / x86_64 PC
wget http://client.planefinder.net/pfclient_5.0.162_amd64.deb
sudo dpkg -i pfclient_5.0.162_amd64.deb
arm64 / aarch64 RPi
wget http://client.planefinder.net/pfclient_5.3.2_arm64.deb
sudo dpkg -i pfclient_5.3.2_arm64.deb
After installation completed, in browser opened following address, and completed configuration:
IP-of-DebianPC:30053
(3) AIS-catcher
sudo bash -c "$(wget -O - https://raw.githubusercontent.com/abcd567a/install-aiscatcher/master/install-aiscatcher.sh)"
(4) Planeplrotter uploadedr - ppup1090
sudo bash -c "$(wget -O - https://github.com/abcd567a/ppup1090/raw/master/install-ppup.sh)"
(5) RadaBox24 - only for RPi
The Radarbox24 feeder is NOT available for amd64
It is available only for for RPi (arm64), but their repository & installation script are designed for Bookworm & Bullseye, and fail on Trixie.
Following is the workaround for installing rbfeeder on RPi (arm64) running OS Trixie:
(a) Install tools
sudo apt install dirmngr gnupg
(b) Set apt
Note: Following three (3) commands are very long. Scroll right to see and copy these in full
gpg --keyserver keyserver.ubuntu.com --recv-keys F2A8428D3C354953
gpg --export --armor F2A8428D3C354953 | sudo gpg --dearmor -o /etc/apt/keyrings/rb24.gpg
echo "deb [signed-by=/etc/apt/keyrings/rb24.gpg] https://apt.rb24.com/ bookworm main" | sudo tee /etc/apt/sources.list.d/rb24.list
(c) Update apt and install rbfeeder:
sudo apt update
sudo apt install rbfeeder
(d) After installation is completed, signup as follows:
sudo systemctl restart rbfeeder
After a few seconds, RBFeeder will connect to the AirNav servers and you can view your sharing-key with this command:
sudo rbfeeder --showkey
If you already have a sharing-key from a previous installation, you can set the same key using this command:
sudo rbfeeder --setkey ‹your sharing key›
(e) Install mlat-client
The installation of mlat-client from RB24 repository by command sudo apt install mlat-client fails with following error message:
mlat-client:arm64 Depends python3 (< 3.12) but this is not installable (Trixie apt provides python 3.13)
Solution: Build & install mlat-client using source code
sudo apt install build-essential devscripts debhelper dh-python python3-dev
git clone https://github.com/mutability/mlat-client
cd mlat-client
sudo dpkg-buildpackage -b --no-sign
cd ../
sudo dpkg -i mlat-client_0.2.13_*.deb
And that is all. The rbfeeder installation is completed.
Check status by following command
sudo systemctl status rbfeeder
