Has anyone else noticed delays on the feeder check-in today? Previously when I refreshed the page, it stated ‘Feeder Check-In: a few seconds ago,’ and now it is more common to show 4 to 5 minutes. I have checked each of my feeders and some local to me, and they all have the same. Is this part of a new change on the back-end, or is there a backlog in the data processing?
I am relatively new to hosting feeders, so if this is ‘normal,’ that is fine. I am just concerned there may be a loss of data due to delays.
For both my devices (which are running fine) the stats show a delay of several minutes. Checking the logs locally the connect was made properly a few seconds ago, but it’s also not visible on the stats page.
Checking other feeders in my area of other users showing the same delay.
Just checked mine, it is still updating, but with delays on the stats page. Two minutes ago it stated “5 Minutes”, after checking now again it says “1 minute”
Feeder now says again “5 Minutes ago”.
It’s 08:30 local time and this is the last log:
[2021-03-30 08:24 CEST] mlat-client(32447): Aircraft: 4 of 6 Mode S, 24 of 24 ADS-B used
[2021-03-30 08:24 CEST] mlat-client(32447): Results: 7.5 positions/minute
[2021-03-30 08:24 CEST] mlat-client(32447): Server: 0.0 kB/s from server 0.0kB/s TCP to server 1.2kB/s UDP to server
However the local device says something different and the last update time is correct(It’s an AirSquitter, not a Raspberry with two our time zone difference):
You can access the logs from your device in the stats page. Sometimes it takes longer than 5 Minutes which doesn’t indicate an issue.
This is my log just a few seconds ago:
[2021-03-31 10:09 CEST] 326799 msgs recv'd from rcd (672 in last 5m); 326798 msgs sent to FlightAware
[2021-03-31 10:10 CEST] mlat-client(32447): Server: 0.1 kB/s from server 0.0kB/s TCP to server 1.5kB/s UDP to server
[2021-03-31 10:10 CEST] mlat-client(32447): Aircraft: 4 of 9 Mode S, 33 of 34 ADS-B used
[2021-03-31 10:10 CEST] mlat-client(32447): Receiver status: connected
[2021-03-31 10:10 CEST] mlat-client(32447): Results: 33.3 positions/minute
[2021-03-31 10:19 CEST] 328645 msgs recv'd from rcd (979 in last 5m); 328644 msgs sent to FlightAware
You can see that the difference is 10 minutes there, but it works without issues.
I would get concerned if it exceeds 20 Minutes or more
