We’ve been exploring some potential uses for Docker and Grafana recently.
For those of you unfamiliar with Docker, it is a useful tool that makes it easy to create and deploy applications in the form of “containers”. Think of a container as a pre-packaged, lightweight environment containing all the software and dependencies required for an application to run. No need to worry about the hassle of installing dependencies on your system.
Introducing…fa-grafana, a Dockerized environment that will run Grafana dashboards on top of existing PiAware installations.
Grafana has some cool dashboard and alert features that I think could be used to monitor and alert you about the aircraft you see and your Pi’s health. More to look into on that…For this initial version, fa-grafana just uses the dump1090-exporter dashboard with a few UI tweaks to display dump1090 metrics.
Let me know if you run into any issues. I’ve been running it on a Pi 3B+ but will need to do some more testing on different Pi models to see how it performs. (If ports 3000, 9090, or 9105 are in use on your Pi, you may see issues. Working out making them configurable)
Clean install on a non piaware image (Pi3B with buster). All commands complete successfully until the final command
ERROR: for grafana Cannot create container for service grafana: Conflict. The container name “/grafana” is already in use by container “7ae74f1f5a23d9b5781c67ae356edecd8357826704470f49b150c00cc4397423”. You have to remove (or rename) that container to be able to reuse that name.
I’ve run through the instructions (copied and pasted each one) but I am getting:
docker-compose: command not found.
I cant see any errors?
Reading package lists… Done
git installed. Proceeding…
pip3 installed. Proceeding…
Installing docker-compose…
Installing docker…
Adding pi user to docker group…
All necessary programs installed! Clone the fa-grafana directory and start up docker containers using docker-compose.
@kevdel I have not tested that yet. dump1090-exporter fetches data from data/aircraft.json on host:8080 by default so as long as your host is running dump1090, it should be possible. I will check it out.
@finchang I just commited a change to restart the prometheus and grafana containers if Docker is still running on a reboot. Stop the containers, git pull, and start them up again and they should run automatically after a reboot.
Inside the fa-grafana directory…
sudo docker-compose down
git pull
sudo docker-compose up -d
