What is the easiest way to add 978? I have a Pro stick + on a PI 4 running the Piaware image with FR24 and rbfeeder piggybacked. I have an orange Pro sick and dual band filter sitting here and would like to add 978UAT coverage.
Quote from āPiaware SD card image 3.8.0 Quickstart Guideā
Quick question, but how do you assign the correct āserial numberā to the correct radio? For example running a blue pro stick+ and orange pro stick you would want the blue on 1090 and orange on 978?
Thanks,
Chris
This will explain:
Thanks⦠Worked great!
Thanks Mark, that explains it.
Just wondering, how do you get two pro stick dongles on a Raspberry Pi? The Orange one I have blocks the remaining 3 USB ports.
You will need a USB extension.
I purchased these USB Extension on Amazon. Four (4) for $9.99 USD. Fairly short, 15cm.
https://www.amazon.com/gp/product/B01GA1GKYW/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
Removing the plastic cover is another possibility.
OK, next newbie question, where does one find a 978 Mhz dongle? I have searched for one and have come up short.
The orange one you have works for both 1090 & 978 mhz, as it does not have a built-in filter. You may need to add Flightaware light blue filter depending on rf noise at your location.
Alternatively, a dongle with builtin 978 filter
https://www.amazon.com/AirNav-RadarBox-FlightStick-UAT-Integrated/dp/B083JJG4LC
OK, so I began the 978 setup and got fairly far on my Pi with the Orange FlightStick. I see the UAT 978 on my Site page but the counts are zero. The following is the output from piaware-status
pi@piaware2:/var/log$ piaware-status
PiAware master process (piaware) is running with pid 479.
PiAware ADS-B client (faup1090) is running with pid 1596.
PiAware ADS-B UAT client (faup978) is not running.
PiAware mlat client (fa-mlat-client) is running with pid 1543.
Local ADS-B receiver (dump1090-fa) is running with pid 1307.
Local ADS-B UAT receiver (dump978) is not running.
dump1090-fa (pid 1307) is listening for ES connections on port 30005.
no program appears to be listening for UAT connections on port 30978.
faup978 is NOT connected to the ADS-B UAT receiver.
got ācouldnāt open socket: connection refusedā
dump978 is NOT producing data on localhost:30978.
Not sure where to go from here, any ideas?
Thank you in advance
This is the main problem.
Are you trying to set up a 978-only site, or a dual 1090 & 978 site? If youāre trying to set up a dual site, do you have two dongles connected and did you serialize them?
I am trying to setup a dual site. I only have the one orange dongle. So I misunderstood that you could run 978 on the orange stick or is it that you canāt run a dual all on the one dongle?
Please see this:
OK, good to know, I ordered one, it should be here tomorrow. Any additional advice on getting this setup? And I appreciate the help, thank you
Serialize two dongles as follows (8-digit):
Dongle for 1090 Mhz Serial#: 00001090
Dongle for 978 Mhz Serial # : 00000978
Please see this guide:
if you are using Piaware SD card image:
How to Install and Configure Piaware 5.0 SD card image - Quickstart Guide
See items 5 & 6 -
If you are using Raspbian image with package install of piaware, dump1090-fa, and dump978-fa:
[Package Install] How to Install and Configure Piaware on Raspberry Pi OS Image / RPi
See items 4 & 6
Perfect, thank you. It is amazing how answers seem to always create more questions. I am not sure if I have a SD image or a Raspbian image. I believe I install PiAware using apt-get, but donāt remember because it was a couple of years ago. Any easy way to tell?
If in SSH window (PuTTY) you see:
pi@piaware:~ $
Then it is Piaware SD card image. -
pi@raspberrypi:~ $
Then it is Raspbian image (now renamed to Raspberry Pi OS)
