Team,
Iβm quite confused here. I got the new 978 Antenna yesterday and I cloned the dev branch from GitHub and build it successfully, I suppose
as per the instructions in the readme.
$ sudo apt-get install
build-essential
deb-helper
dh-systemd
libboost-system-dev
libboost-program-options-dev
libboost-regex-dev
libboost-filesystem-dev
libsoapysdr-dev
$ dpkg-buildpackage -b
$ sudo dpkg -i β¦/dump978-fa_.deb β¦/skyview978_.deb
once this was completed, the service was successfully started, yet I couldnβt open find the data nor I was open to reach any webpage http://
$ sudo systemctl status dump978-fa
β dump978-fa.service - dump978 ADS-B UAT receiver
Loaded: loaded (/lib/systemd/system/dump978-fa.service; enabled; vendor preset: enabled)
Active: active (running) since Sat 2019-04-06 16:20:38 PDT; 5min ago
Main PID: 2711 (dump978-fa)
CGroup: /system.slice/dump978-fa.service
ββ2711 /usr/bin/dump978-fa --sdr driver=rtlsdr --format CS8 --raw-port 30978 --json-port 30979
Apr 06 16:20:38 raspberrypi dump978-fa[2711]: json-port: listening for connections on 0.0.0.0:30979
Apr 06 16:20:38 raspberrypi dump978-fa[2711]: json-port: listening for connections on [::]:30979
Apr 06 16:20:39 raspberrypi dump978-fa[2711]: linux; GNU C++ version 6.2.0 20161010; Boost_106100; UHD_003.009.005-0-unknown
Apr 06 16:20:39 raspberrypi dump978-fa[2711]: Found Rafael Micro R820T tuner
Apr 06 16:20:39 raspberrypi dump978-fa[2711]: Exact sample rate is: 2083333.135571 Hz
Apr 06 16:20:40 raspberrypi dump978-fa[2711]: [R82XX] PLL not locked!
Apr 06 16:20:40 raspberrypi dump978-fa[2711]: SoapySDR: using maximum manual gain 49.6 dB
Apr 06 16:20:40 raspberrypi dump978-fa[2711]: SoapySDR: INFO: Using format CS8.
Apr 06 16:20:41 raspberrypi dump978-fa[2711]: [::]:30978: accepted a connection from [::1]:60102
so, I stoped the service and check if I can get the data thru an interactive mode similarly to dump1090.
$ dump1090-fa --interactive
Hex Mode Sqwk Flight Alt Spd Hdg Lat Long RSSI Msgs Ti |
ββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
A61B4E S ASA682 10725 47.222 -121.760 -22.0 447 22
A55AED S 4601 8950 -21.8 49 1
β¦
β¦
β¦
for 978 Mhz, I ran the following command with no luck to get any data for hours.
$ /usr/bin/dump978-fa --sdr driver=rtlsdr --format CS8
