Dump978 error help (short write, samples lost, exiting)
I’ve recently set up a nano three antenna on a raspberry pi and went through the instructions to successfully set up rtl-sdr. I also pulled the dump978 repo off of github.
I don’t get errors when I run rtl_test but when I run rtl_sdr -f 978000000 -s 2083334 -g 48 - | /home/pi/dump978/dump978 | /home/pi/dump978/uat2text which is supposed to output the messages in my terminal, it starts sampling and then abruptly stops before any messages show up.
output:
bash: /home/pi/dump978 Is a directory
Found 1 device(s)
   0: Realtek, RTL2838UHIDIR, SN: 00000001
Using device 0: Generic RTL2838U OEM
Detached kernel driver
Exact sample rate is: 2083334.141630 Hz
[R82XX] PLL not locked!
Sampling at 2083334 S/s
Tuned to 978000000 Hz
Tuner gain set to 48.0 dB
Reading samples in async mode...
Allocating 15 zero-copy buffers
Signal caught, exiting!
Short write, samples lost, exiting!
User cancel, exiting...
Reattached kernel driver
What could I be doing wrong here?
Please use dump978-fa (GitHub - flightaware/dump978: FlightAware's 978MHz UAT demodulator), the older dump978 is obsolete and unsupported (I am the author of both)
There are prebuilt armhf debian/raspbian packages suitable for a Pi available from the FlightAware repository.
Thank you this is super helpful! I’ll get these installed!
So I set up the piaware install per the directions here PiAware - dump1090 ADS-B integration with FlightAware - FlightAware and then changed the settings so that it would be using the dump978 only with these commands
sudo piaware-config uat-receiver-type sdr
sudo piaware-config receiver-type none
But for some reason when I try to use telnet to see the raw messages on port 30978 it fails to connect. Checking the ports in use on my pi gives me this output
tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN        575/lighttpd
tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN        575/lighttpd
tcp        0      0 0.0.0.0:8978            0.0.0.0:*               LISTEN        575/lighttpd
tcp        0      0 0.0.0.0:30002           0.0.0.0:*               LISTEN        355/dump1090-fa
tcp        0      0 0.0.0.0:30003           0.0.0.0:*               LISTEN        355/dump1090-fa
tcp        0      0 0.0.0.0:30004           0.0.0.0:*               LISTEN        355/dump1090-fa
tcp        0      0 0.0.0.0:30005           0.0.0.0:*               LISTEN        355/dump1090-fa
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN        398/sshd: /usr/sbin
tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN        359/cupsd
tcp        0      0 0.0.0.0:30104           0.0.0.0:*               LISTEN        355/dump1090-fa
tcp6       0      0 :::80                   :::*                    LISTEN        575/lighttpd
tcp6       0      0 :::30002                :::*                    LISTEN        355/dump1090-fa
tcp6       0      0 :::30003                :::*                    LISTEN        355/dump1090-fa
tcp6       0      0 :::30004                :::*                    LISTEN        355/dump1090-fa
tcp6       0      0 :::30005                :::*                    LISTEN        355/dump1090-fa
tcp6       0      0 :::22                   :::*                    LISTEN        398/sshd: /usr/sbin
tcp6       0      0 ::1:631                 :::*                    LISTEN        359/cupsd
tcp6       0      0 :::30104                :::*                    LISTEN        355/dump1090-fa
(edit: not sure why that pasted incorrectly but it did identify that those ports were all in use by 355/dump1090-fa)
so something isn’t working and it’s still just running the dump1090. I can’t find any other/different instructions from what I did. Am I missing a step?
You’re not using the piaware image?
Then you need to do somet stuff:
https://github.com/wiedehopf/adsb-wiki/wiki/Installing-dump978-fa-and-feeding-adsbexchange-with-UAT-traffic
You have 2 SDRs?
I’m trying it now with the image to see if that works easier. But no, only one SDR antenna, but I only care about the 978 stuff.
On my RPi running Raspberry Pi OS Bullseye image, with package install of BOTH dump1090-fa ver 7.1 AND dump978-fa ver 7.1
(1) netstat
pi@raspberrypi:~ $ sudo netstat -anp | grep -w LISTEN
tcp        0      0 0.0.0.0:30978     0.0.0.0:*   LISTEN      891835/dump978-fa
tcp        0      0 0.0.0.0:30979     0.0.0.0:*   LISTEN      891835/dump978-fa
tcp        0      0 127.0.0.1:32004   0.0.0.0:*   LISTEN      1003/rbfeeder
tcp        0      0 0.0.0.0:30053     0.0.0.0:*   LISTEN      1048/pfclient
tcp        0      0 0.0.0.0:30054     0.0.0.0:*   LISTEN      1048/pfclient
tcp        0      0 127.0.0.1:32457   0.0.0.0:*   LISTEN      1003/rbfeeder
tcp        0      0 127.0.0.1:32458   0.0.0.0:*   LISTEN      1003/rbfeeder
tcp        0      0 127.0.0.1:32459   0.0.0.0:*   LISTEN      1003/rbfeeder
tcp        0      0 0.0.0.0:8080      0.0.0.0:*   LISTEN      1134/lighttpd
tcp        0      0 0.0.0.0:80        0.0.0.0:*   LISTEN      1134/lighttpd
tcp        0      0 0.0.0.0:8978      0.0.0.0:*   LISTEN      1134/lighttpd
tcp        0      0 0.0.0.0:30002     0.0.0.0:*   LISTEN      549/dump1090-fa
tcp        0      0 0.0.0.0:30003     0.0.0.0:*   LISTEN      549/dump1090-fa
tcp        0      0 0.0.0.0:30004     0.0.0.0:*   LISTEN      549/dump1090-fa
tcp        0      0 0.0.0.0:30005     0.0.0.0:*   LISTEN      549/dump1090-fa
tcp        0      0 0.0.0.0:22        0.0.0.0:*   LISTEN      613/sshd: /usr/sbin
tcp        0      0 0.0.0.0:32088     0.0.0.0:*   LISTEN      1003/rbfeeder
tcp        0      0 0.0.0.0:30104     0.0.0.0:*   LISTEN      549/dump1090-fa
tcp6       0      0 :::30978          :::*        LISTEN      891835/dump978-fa
tcp6       0      0 :::30979          :::*        LISTEN      891835/dump978-fa
tcp6       0      0 :::80             :::*        LISTEN      1134/lighttpd
tcp6       0      0 :::8754           :::*        LISTEN      1044/fr24feed
tcp6       0      0 :::30002          :::*        LISTEN      549/dump1090-fa
tcp6       0      0 :::30003          :::*        LISTEN      549/dump1090-fa
tcp6       0      0 :::30004          :::*        LISTEN      549/dump1090-fa
tcp6       0      0 :::30005          :::*        LISTEN      549/dump1090-fa
tcp6       0      0 :::22             :::*        LISTEN      613/sshd: /usr/sbin
tcp6       0      0 :::30104          :::*        LISTEN      549/dump1090-fa
tcp6       0      0 :::30105          :::*        LISTEN      1279/fa-mlat-client
tcp6       0      0 :::30106          :::*        LISTEN      1279/fa-mlat-client
pi@raspberrypi:~ $
(2) status of dump978-fa
pi@raspberrypi:~ $ sudo systemctl status dump978-fa
● dump978-fa.service - dump978 ADS-B UAT receiver
     Loaded: loaded (/lib/systemd/system/dump978-fa.service; enabled; vendor preset: enabled)
     Active: active (running) since Thu 2022-01-27 17:57:37 GMT; 16min ago
   Main PID: 891835 (dump978-fa)
      Tasks: 4 (limit: 4165)
        CPU: 1min 27.492s
     CGroup: /system.slice/dump978-fa.service
             └─891835 /usr/bin/dump978-fa --sdr driver=rtlsdr,serial=00000978 --format CS8 --raw-port 30978 --json-port 30979
Jan 27 17:57:37 raspberrypi dump978-fa[891835]: usb_claim_interface error -6
Jan 27 17:57:37 raspberrypi dump978-fa[891835]: Found Rafael Micro R820T tuner
Jan 27 17:57:38 raspberrypi dump978-fa[891835]: Exact sample rate is: 2083333.135571 Hz
Jan 27 17:57:38 raspberrypi dump978-fa[891835]: [R82XX] PLL not locked!
Jan 27 17:57:38 raspberrypi dump978-fa[891835]: SoapySDR: using maximum manual gain 49.6 dB
Jan 27 17:57:38 raspberrypi dump978-fa[891835]: SoapySDR: using stream setting buffsize=262144
Jan 27 17:57:38 raspberrypi dump978-fa[891835]: Allocating 15 zero-copy buffers
Jan 27 17:57:42 raspberrypi dump978-fa[891835]: [::]:30978: accepted a connection from [::1]:49890
Jan 27 17:57:52 raspberrypi dump978-fa[891835]: 0.0.0.0:30979: accepted a connection from 127.0.0.1:36014
Jan 27 17:58:07 raspberrypi dump978-fa[891835]: [::]:30978: accepted a connection from [::1]:49902
pi@raspberrypi:~ $
Seems instead of installing dump978-fa, you have by mistake installed dump1090-fa
Seems instead of installing dump 978 -fa, you have by mistake installed dump 1090 -fa
I had installed both per the installation guide.
At any rate, the image version of piaware seems to work. I’m not getting any messages when I get port 30978. I just see this and it waits without receiving anything
!fecfix=1;program=dump978-fa;version=5.0;
I’m only a mile from a small-size airport so I thought I’d get messages no problem. It’s blizzarding out now, so I don’t expect air traffic, but I assumed I should at least be seeing the METAR messages, so it’s kinda weird.
To see uplink FIS-B messages you’d need approximate line of sight to one of the FAA’s 978MHz ground transmitters (they’re not necessarily at the airport)
note that skyaware / piaware et al do not decode/display uplink messages (but you should see the raw messages in the port 30978 output if they’re being received)
I am located at Toronto, which has 0 to 5 UAT equipped flights per day. Initially I also get this when check, but after some wait more data:
pi@raspberrypi:~ $ nc 127.0.0.1 30978
!fecfix=1;program=dump978-fa;version=7.1;
-10a6a8a13d90ab8ecb98641910150880280000000000000000000000006180000000;rs=5;rssi=-15.6;t=1643308737.477;
-10a6a8a13d90a38ed1ec6419101108802f0000000000000000000000006180000000;rs=4;rssi=-17.7;t=1643308742.689;
-00a6a8a13d909b8ed9f46429101108a02800;rs=5;rssi=-18.1;t=1643308749.272;
-08a6a8a13d90978edd1e6419101108a0381196908a37c40b06a5c2a0006180000000;rs=2;rssi=-13.0;t=1643308751.826;
-00a6a8a13d90978edd9a6419101108a03d00;rs=1;rssi=-13.6;t=1643308752.350;
-00a6a8a13d90918ee1406419101508a03900;rs=3;rssi=-15.7;t=1643308755.213;
-08a6a8a13d90858ee9486419101508a0281196908a37c40b86a5c2a0006170000000;rs=3;rssi=-14.1;t=1643308761.962;
-00a6a8a13d90838eeb3a6419101508801800;rs=3;rssi=-17.5;t=1643308763.588;
-10a6a8a13d90778ef288641910190880280000000000000000000000006170000000;rs=7;rssi=-15.8;t=1643308769.482;
-10a6a8a13d906b8efa12641910190880280000000000000000000000006170000000;rs=6;rssi=-16.3;t=1643308775.648;
-08a6a8a13d90698efc04641910190880281196908a37c40b6aa5c2a0006180000000;rs=4;rssi=-14.7;t=1643308777.401;
-00a6a8a13d90638efef06419101908802900;rs=3;rssi=-13.7;t=1643308779.622;
-10a6a8a13d90638effaa641910190880290000000000000000000000006180000000;rs=6;rssi=-16.8;t=1643308780.404;
-00a6a8a13d905f8f015e6419101908802800;rs=2;rssi=-13.1;t=1643308781.728;
-08a6a8a13d905d8f02966419101908801f0cac2cd5ed2d0b9ea5c0a0006180000000;rssi=-13.0;t=1643308782.772;
-08a6a8a13d905b8f0352641910190880181196908a37c40bd6a5c2a0006180000000;rs=6;rssi=-15.3;t=1643308783.295;
-00a6a8a13d90598f04c86419101908801900;rs=5;rssi=-15.6;t=1643308784.594;
-10a6a8a13d90558f067c6419101d08a02a0000000000000000000000006180000000;rssi=-12.5;t=1643308785.916;
-00a6a8a13d904d8f0ade6419101d08a02800;rs=2;rssi=-16.8;t=1643308789.446;
-00a6a8a13d90458f0f006419101909203900;rs=6;rssi=-17.1;t=1643308792.939;
-08a6a8a13d901f8f22fc641910190900281196908a37c40bdaa5c2a0006170000000;rs=5;rssi=-14.1;t=1643308809.392;
-00a6a8a13d8f898f69d6641910210aa02800;rs=6;rssi=-19.2;t=1643308867.260;
-10a6a8a13d8f7d8f6ebc6419101d0a801a0000000000000000000000006170000000;rs=7;rssi=-18.8;t=1643308871.368;
-00a6a8a13d8f738f73a4641910210a801900;rs=5;rssi=-20.8;t=1643308875.403;
-00a6a8a13d8efb8fa11a641910210b801f00;rs=5;rssi=-16.9;t=1643308912.390;
-10a6a8a13d8ee98fa87c641910210b802f0000000000000000000000006170000000;rs=3;rssi=-17.3;t=1643308918.325;
-10a6a8a13d8d378fcff6641910dd09004f0000000000000000000000006180000000;rs=2;rssi=-18.0;t=1643308950.479;
-00a6a8a13d8cdf8fd496641910d909004800;rs=2;rssi=-16.3;t=1643308954.289;
-00a6a8a13d8c0b8fdfc8642910dd08a02800;rs=5;rssi=-16.8;t=1643308963.595;
-00a6a8a13d8bd78fe276642910dd08a03c00;rs=6;rssi=-16.7;t=1643308965.794;
-08a6a8a13d8b7f8fe714642910e108a0481196908a37c40bcaa5c2a0006180000000;rs=2;rssi=-16.7;t=1643308969.551;
-00a6a8a13d8b1f8febf2641910e508a05900;rs=4;rssi=-16.7;t=1643308973.414;
-10a6a8a13d8abd8ff0d0641910e508a04c0000000000000000000000006170000000;rs=4;rssi=-16.1;t=1643308977.541;
-00a6a8a13d8aa58ff208641910e508a04800;rs=4;rssi=-15.5;t=1643308978.478;
-00a6a8a13d8a918ff300641910e508a03900;rs=2;rssi=-16.3;t=1643308979.219;
-00a6a8a13d8a5d8ff5ae641910e508a03900;rs=4;rssi=-18.8;t=1643308981.555;
I have also installed FR24’s UAT Feeder (BETA), which gets data from port 30979 of dump978-fa. It’s log are:
pi@raspberrypi:~ $ cat /var/log/uat_reader/uat_reader.log
2022-01-27 18:38:32.830 | 22-01-27 18:38:32.830 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":528,"ground_speed":528,"metadata":{"errors":4,"received_at":1643308712.78,"rssi":-17.4},"nic":9,"north_velocity":-3,"position":{"lat":43.28836,"lon":-79.67995},"pressure_altitude":39000,"true_track":90.3,"uplink_feedback":6,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
2022-01-27 18:38:32.830 | [i]sent 1,0 AC
2022-01-27 18:38:32.831 | 22-01-27 18:38:32.827 [D] sent 1 of 2 aircraft, 0 ignored, 1 outdated
2022-01-27 18:38:33.334 | 22-01-27 18:38:33.333 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","callsign":"WMN528","capability_codes":{"es_in":true,"tcas_operational":false,"uat_in":true},"east_velocity":528,"emergency":"none","emitter_category":"A2","geometric_altitude":37975,"ground_speed":528,"gva":2,"metadata":{"errors":6,"received_at":1643308713.317,"rssi":-17.7},"mops_version":2,"nac_p":10,"nac_v":2,"nic":9,"nic_baro":1,"nic_supplement":false,"north_velocity":-3,"operational_modes":{"atc_services":false,"ident_active":false,"tcas_ra_active":false},"position":{"lat":43.28836,"lon":-79.67794},"pressure_altitude":39000,"sda":2,"sil":3,"sil_supplement":"per_hour","single_antenna":true,"transmit_mso":15,"true_track":90.3,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
2022-01-27 18:38:57.494 | 22-01-27 18:38:57.493 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":528,"geometric_altitude":37975,"ground_speed":528,"metadata":{"errors":5,"received_at":1643308737.477,"rssi":-15.6},"nic":9,"north_velocity":-4,"position":{"lat":43.28796,"lon":-79.59706},"pressure_altitude":39000,"true_track":90.4,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":64,"vv_src":"geometric"}
2022-01-27 18:38:57.494 | [i]sent 1,0 AC
2022-01-27 18:38:57.494 | 22-01-27 18:38:57.491 [D] sent 1 of 1 aircraft, 0 ignored, 0 outdated
2022-01-27 18:39:02.715 | 22-01-27 18:39:02.715 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":528,"geometric_altitude":37975,"ground_speed":528,"metadata":{"errors":4,"received_at":1643308742.689,"rssi":-17.7},"nic":9,"north_velocity":-3,"position":{"lat":43.28787,"lon":-79.57968},"pressure_altitude":39000,"true_track":90.3,"uplink_feedback":7,"utc_coupled":true,"vertical_velocity_geometric":64,"vv_src":"geometric"}
2022-01-27 18:39:02.833 | [i]sent 1,0 AC
2022-01-27 18:39:02.833 | 22-01-27 18:39:02.711 [D] sent 1 of 1 aircraft, 0 ignored, 0 outdated
2022-01-27 18:39:09.320 | 22-01-27 18:39:09.320 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":528,"ground_speed":528,"metadata":{"errors":5,"received_at":1643308749.272,"rssi":-18.1},"nic":9,"north_velocity":-3,"position":{"lat":43.28779,"lon":-79.55762},"pressure_altitude":39025,"true_track":90.3,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":-64,"vv_src":"geometric"}
2022-01-27 18:39:09.320 | [i]sent 1,0 AC
2022-01-27 18:39:09.320 | 22-01-27 18:39:09.315 [D] sent 1 of 1 aircraft, 0 ignored, 0 outdated
2022-01-27 18:39:11.837 | 22-01-27 18:39:11.837 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","callsign":"WMN528","capability_codes":{"es_in":true,"tcas_operational":false,"uat_in":true},"east_velocity":528,"emergency":"none","emitter_category":"A2","geometric_altitude":37975,"ground_speed":528,"gva":2,"metadata":{"errors":2,"received_at":1643308751.826,"rssi":-13.0},"mops_version":2,"nac_p":10,"nac_v":2,"nic":9,"nic_baro":1,"nic_supplement":false,"north_velocity":-3,"operational_modes":{"atc_services":false,"ident_active":false,"tcas_ra_active":false},"position":{"lat":43.28774,"lon":-79.54893},"pressure_altitude":39000,"sda":2,"sil":3,"sil_supplement":"per_hour","single_antenna":true,"transmit_mso":1,"true_track":90.3,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":-128,"vv_src":"geometric"}
2022-01-27 18:39:12.403 | 22-01-27 18:39:12.403 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":528,"ground_speed":528,"metadata":{"errors":1,"received_at":1643308752.35,"rssi":-13.6},"nic":9,"north_velocity":-3,"position":{"lat":43.28774,"lon":-79.5476},"pressure_altitude":39000,"true_track":90.3,"uplink_feedback":5,"utc_coupled":true,"vertical_velocity_geometric":-128,"vv_src":"geometric"}
2022-01-27 18:39:15.235 | 22-01-27 18:39:15.235 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":528,"ground_speed":528,"metadata":{"errors":3,"received_at":1643308755.213,"rssi":-15.7},"nic":9,"north_velocity":-4,"position":{"lat":43.28768,"lon":-79.53758},"pressure_altitude":39000,"true_track":90.4,"uplink_feedback":1,"utc_coupled":true,"vertical_velocity_geometric":-128,"vv_src":"geometric"}
2022-01-27 18:39:15.235 | [i]sent 1,0 AC
2022-01-27 18:39:15.236 | 22-01-27 18:39:15.231 [D] sent 1 of 1 aircraft, 0 ignored, 0 outdated
2022-01-27 18:39:22.030 | 22-01-27 18:39:22.030 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","callsign":"WMN528","capability_codes":{"es_in":true,"tcas_operational":false,"uat_in":true},"east_velocity":528,"emergency":"none","emitter_category":"A2","geometric_altitude":37950,"ground_speed":528,"gva":2,"metadata":{"errors":3,"received_at":1643308761.962,"rssi":-14.1},"mops_version":2,"nac_p":10,"nac_v":2,"nic":9,"nic_baro":1,"nic_supplement":false,"north_velocity":-4,"operational_modes":{"atc_services":false,"ident_active":false,"tcas_ra_active":false},"position":{"lat":43.28755,"lon":-79.51552},"pressure_altitude":39000,"sda":2,"sil":3,"sil_supplement":"per_hour","single_antenna":true,"transmit_mso":33,"true_track":90.4,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":-64,"vv_src":"geometric"}
2022-01-27 18:39:22.030 | [i]sent 1,0 AC
2022-01-27 18:39:22.030 | 22-01-27 18:39:22.027 [D] sent 1 of 1 aircraft, 0 ignored, 0 outdated
2022-01-27 18:39:23.602 | 22-01-27 18:39:23.602 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":528,"ground_speed":528,"metadata":{"errors":3,"received_at":1643308763.588,"rssi":-17.5},"nic":9,"north_velocity":-4,"position":{"lat":43.28753,"lon":-79.51018},"pressure_altitude":39000,"true_track":90.4,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
2022-01-27 18:39:29.516 | 22-01-27 18:39:29.516 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":528,"geometric_altitude":37950,"ground_speed":528,"metadata":{"errors":7,"received_at":1643308769.482,"rssi":-15.8},"nic":9,"north_velocity":-5,"position":{"lat":43.2874,"lon":-79.49012},"pressure_altitude":39000,"true_track":90.5,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":64,"vv_src":"geometric"}
2022-01-27 18:39:29.516 | [i]sent 1,0 AC
2022-01-27 18:39:29.517 | 22-01-27 18:39:29.511 [D] sent 1 of 1 aircraft, 0 ignored, 0 outdated
2022-01-27 18:39:35.682 | 22-01-27 18:39:35.681 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":528,"geometric_altitude":37950,"ground_speed":528,"metadata":{"errors":6,"received_at":1643308775.648,"rssi":-16.3},"nic":9,"north_velocity":-5,"position":{"lat":43.28727,"lon":-79.46941},"pressure_altitude":39000,"true_track":90.5,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":64,"vv_src":"geometric"}
2022-01-27 18:39:35.682 | [i]sent 1,0 AC
2022-01-27 18:39:35.682 | 22-01-27 18:39:35.679 [D] sent 1 of 1 aircraft, 0 ignored, 0 outdated
2022-01-27 18:39:37.443 | 22-01-27 18:39:37.443 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","callsign":"WMN528","capability_codes":{"es_in":true,"tcas_operational":false,"uat_in":true},"east_velocity":528,"emergency":"none","emitter_category":"A2","geometric_altitude":37975,"ground_speed":528,"gva":2,"metadata":{"errors":4,"received_at":1643308777.401,"rssi":-14.7},"mops_version":2,"nac_p":10,"nac_v":2,"nic":9,"nic_baro":1,"nic_supplement":false,"north_velocity":-5,"operational_modes":{"atc_services":false,"ident_active":false,"tcas_ra_active":false},"position":{"lat":43.28725,"lon":-79.46407},"pressure_altitude":39000,"sda":2,"sil":3,"sil_supplement":"per_hour","single_antenna":true,"transmit_mso":26,"true_track":90.5,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":64,"vv_src":"geometric"}
2022-01-27 18:39:39.645 | 22-01-27 18:39:39.645 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":528,"ground_speed":528,"metadata":{"errors":3,"received_at":1643308779.622,"rssi":-13.7},"nic":9,"north_velocity":-5,"position":{"lat":43.28718,"lon":-79.45604},"pressure_altitude":39000,"true_track":90.5,"uplink_feedback":1,"utc_coupled":true,"vertical_velocity_geometric":64,"vv_src":"geometric"}
2022-01-27 18:39:40.464 | 22-01-27 18:39:40.463 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":528,"geometric_altitude":37975,"ground_speed":528,"metadata":{"errors":6,"received_at":1643308780.404,"rssi":-16.8},"nic":9,"north_velocity":-5,"position":{"lat":43.28718,"lon":-79.45405},"pressure_altitude":39000,"true_track":90.5,"uplink_feedback":1,"utc_coupled":true,"vertical_velocity_geometric":64,"vv_src":"geometric"}
2022-01-27 18:39:41.785 | 22-01-27 18:39:41.784 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":528,"ground_speed":528,"metadata":{"errors":2,"received_at":1643308781.728,"rssi":-13.1},"nic":9,"north_velocity":-5,"position":{"lat":43.28714,"lon":-79.44937},"pressure_altitude":39000,"true_track":90.5,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":64,"vv_src":"geometric"}
2022-01-27 18:39:41.785 | [i]sent 1,0 AC
2022-01-27 18:39:41.785 | 22-01-27 18:39:41.779 [D] sent 1 of 1 aircraft, 0 ignored, 0 outdated
2022-01-27 18:39:42.792 | 22-01-27 18:39:42.791 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","capability_codes":{"es_in":true,"tcas_operational":false,"uat_in":true},"east_velocity":528,"emergency":"none","emitter_category":"A2","flightplan_id":"1476","geometric_altitude":37975,"ground_speed":528,"gva":2,"metadata":{"errors":0,"received_at":1643308782.772,"rssi":-13.0},"mops_version":2,"nac_p":10,"nac_v":2,"nic":9,"nic_baro":1,"nic_supplement":false,"north_velocity":-5,"operational_modes":{"atc_services":false,"ident_active":false,"tcas_ra_active":false},"position":{"lat":43.28712,"lon":-79.44602},"pressure_altitude":39000,"sda":2,"sil":3,"sil_supplement":"per_hour","single_antenna":true,"transmit_mso":39,"true_track":90.5,"uplink_feedback":7,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
2022-01-27 18:39:43.357 | 22-01-27 18:39:43.357 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","callsign":"WMN528","capability_codes":{"es_in":true,"tcas_operational":false,"uat_in":true},"east_velocity":528,"emergency":"none","emitter_category":"A2","geometric_altitude":37975,"ground_speed":528,"gva":2,"metadata":{"errors":6,"received_at":1643308783.295,"rssi":-15.3},"mops_version":2,"nac_p":10,"nac_v":2,"nic":9,"nic_baro":1,"nic_supplement":false,"north_velocity":-5,"operational_modes":{"atc_services":false,"ident_active":false,"tcas_ra_active":false},"position":{"lat":43.2871,"lon":-79.44401},"pressure_altitude":39000,"sda":2,"sil":3,"sil_supplement":"per_hour","single_antenna":true,"transmit_mso":53,"true_track":90.5,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
2022-01-27 18:39:44.617 | 22-01-27 18:39:44.617 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":528,"ground_speed":528,"metadata":{"errors":5,"received_at":1643308784.594,"rssi":-15.6},"nic":9,"north_velocity":-5,"position":{"lat":43.28708,"lon":-79.43999},"pressure_altitude":39000,"true_track":90.5,"uplink_feedback":1,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
2022-01-27 18:39:45.934 | 22-01-27 18:39:45.934 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":528,"geometric_altitude":37975,"ground_speed":528,"metadata":{"errors":0,"received_at":1643308785.916,"rssi":-12.5},"nic":9,"north_velocity":-6,"position":{"lat":43.28703,"lon":-79.43532},"pressure_altitude":39000,"true_track":90.7,"uplink_feedback":2,"utc_coupled":true,"vertical_velocity_geometric":-64,"vv_src":"geometric"}
2022-01-27 18:39:49.458 | 22-01-27 18:39:49.458 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":528,"ground_speed":528,"metadata":{"errors":2,"received_at":1643308789.446,"rssi":-16.8},"nic":9,"north_velocity":-6,"position":{"lat":43.28695,"lon":-79.42328},"pressure_altitude":39000,"true_track":90.7,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":-64,"vv_src":"geometric"}
2022-01-27 18:39:49.459 | [i]sent 1,0 AC
2022-01-27 18:39:49.459 | 22-01-27 18:39:49.455 [D] sent 1 of 1 aircraft, 0 ignored, 0 outdated
2022-01-27 18:39:52.980 | 22-01-27 18:39:52.980 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":529,"ground_speed":529,"metadata":{"errors":6,"received_at":1643308792.939,"rssi":-17.1},"nic":9,"north_velocity":-5,"position":{"lat":43.28686,"lon":-79.41193},"pressure_altitude":39000,"true_track":90.5,"uplink_feedback":1,"utc_coupled":true,"vertical_velocity_geometric":-128,"vv_src":"geometric"}
2022-01-27 18:40:03.626 | 22-01-27 18:40:03.619 [I] [stats]sent 54 bytes
2022-01-27 18:40:09.404 | 22-01-27 18:40:09.403 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","callsign":"WMN528","capability_codes":{"es_in":true,"tcas_operational":false,"uat_in":true},"east_velocity":529,"emergency":"none","emitter_category":"A2","geometric_altitude":37950,"ground_speed":529,"gva":2,"metadata":{"errors":5,"received_at":1643308809.392,"rssi":-14.1},"mops_version":2,"nac_p":10,"nac_v":2,"nic":9,"nic_baro":1,"nic_supplement":false,"north_velocity":-5,"operational_modes":{"atc_services":false,"ident_active":false,"tcas_ra_active":false},"position":{"lat":43.28645,"lon":-79.35704},"pressure_altitude":39000,"sda":2,"sil":3,"sil_supplement":"per_hour","single_antenna":true,"transmit_mso":54,"true_track":90.5,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":64,"vv_src":"geometric"}
2022-01-27 18:40:09.404 | [i]sent 1,0 AC
2022-01-27 18:40:09.404 | 22-01-27 18:40:09.399 [D] sent 1 of 1 aircraft, 0 ignored, 0 outdated
2022-01-27 18:40:39.408 | [n]ping 1
2022-01-27 18:40:40.408 | [n]syncing stream result: 1
2022-01-27 18:41:07.285 | 22-01-27 18:41:07.285 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":532,"ground_speed":532,"metadata":{"errors":6,"received_at":1643308867.26,"rssi":-19.2},"nic":9,"north_velocity":-7,"position":{"lat":43.28485,"lon":-79.16244},"pressure_altitude":39000,"true_track":90.8,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":-64,"vv_src":"geometric"}
2022-01-27 18:41:07.285 | [i]sent 1,0 AC
2022-01-27 18:41:07.285 | 22-01-27 18:41:07.278 [D] sent 1 of 1 aircraft, 0 ignored, 0 outdated
2022-01-27 18:41:11.438 | 22-01-27 18:41:11.437 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":532,"geometric_altitude":37950,"ground_speed":532,"metadata":{"errors":7,"received_at":1643308871.368,"rssi":-18.8},"nic":9,"north_velocity":-6,"position":{"lat":43.28472,"lon":-79.14898},"pressure_altitude":39000,"true_track":90.6,"uplink_feedback":2,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
2022-01-27 18:41:15.464 | 22-01-27 18:41:15.464 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":532,"ground_speed":532,"metadata":{"errors":5,"received_at":1643308875.403,"rssi":-20.8},"nic":9,"north_velocity":-7,"position":{"lat":43.28461,"lon":-79.13551},"pressure_altitude":39000,"true_track":90.8,"uplink_feedback":1,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
2022-01-27 18:41:15.464 | [i]sent 1,0 AC
2022-01-27 18:41:15.464 | 22-01-27 18:41:15.458 [D] sent 1 of 1 aircraft, 0 ignored, 0 outdated
2022-01-27 18:41:45.468 | [n]ping 1
2022-01-27 18:41:46.468 | [n]syncing stream result: 1
2022-01-27 18:41:52.455 | 22-01-27 18:41:52.455 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":534,"ground_speed":534,"metadata":{"errors":5,"received_at":1643308912.39,"rssi":-16.9},"nic":9,"north_velocity":-7,"position":{"lat":43.28332,"lon":-79.01065},"pressure_altitude":39000,"true_track":90.8,"uplink_feedback":7,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
2022-01-27 18:41:52.455 | [i]sent 1,0 AC
2022-01-27 18:41:52.455 | 22-01-27 18:41:52.450 [D] sent 1 of 1 aircraft, 0 ignored, 0 outdated
2022-01-27 18:41:58.371 | 22-01-27 18:41:58.371 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":534,"geometric_altitude":37950,"ground_speed":534,"metadata":{"errors":3,"received_at":1643308918.325,"rssi":-17.3},"nic":9,"north_velocity":-7,"position":{"lat":43.28313,"lon":-78.99037},"pressure_altitude":39000,"true_track":90.8,"uplink_feedback":7,"utc_coupled":true,"vertical_velocity_geometric":64,"vv_src":"geometric"}
2022-01-27 18:41:58.372 | [i]sent 1,0 AC
2022-01-27 18:41:58.372 | 22-01-27 18:41:58.366 [D] sent 1 of 1 aircraft, 0 ignored, 0 outdated
2022-01-27 18:42:28.375 | [n]ping 1
2022-01-27 18:42:29.375 | [n]syncing stream result: 1
2022-01-27 18:42:30.520 | 22-01-27 18:42:30.520 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":529,"geometric_altitude":37975,"ground_speed":531,"metadata":{"errors":2,"received_at":1643308950.479,"rssi":-18.0},"nic":9,"north_velocity":-54,"position":{"lat":43.27847,"lon":-78.88194},"pressure_altitude":39000,"true_track":95.8,"uplink_feedback":7,"utc_coupled":true,"vertical_velocity_geometric":192,"vv_src":"geometric"}
2022-01-27 18:42:30.521 | [i]sent 1,0 AC
2022-01-27 18:42:30.521 | 22-01-27 18:42:30.514 [D] sent 1 of 1 aircraft, 0 ignored, 0 outdated
2022-01-27 18:42:34.359 | 22-01-27 18:42:34.359 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":529,"ground_speed":531,"metadata":{"errors":2,"received_at":1643308954.289,"rssi":-16.3},"nic":9,"north_velocity":-53,"position":{"lat":43.27753,"lon":-78.86924},"pressure_altitude":39000,"true_track":95.7,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":192,"vv_src":"geometric"}
2022-01-27 18:42:43.607 | 22-01-27 18:42:43.607 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":528,"ground_speed":530,"metadata":{"errors":5,"received_at":1643308963.595,"rssi":-16.8},"nic":9,"north_velocity":-54,"position":{"lat":43.27525,"lon":-78.83849},"pressure_altitude":39025,"true_track":95.8,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":-64,"vv_src":"geometric"}
2022-01-27 18:42:43.607 | [i]sent 1,0 AC
2022-01-27 18:42:43.608 | 22-01-27 18:42:43.602 [D] sent 1 of 1 aircraft, 0 ignored, 0 outdated
2022-01-27 18:42:45.809 | 22-01-27 18:42:45.809 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":528,"ground_speed":530,"metadata":{"errors":6,"received_at":1643308965.794,"rssi":-16.7},"nic":9,"north_velocity":-54,"position":{"lat":43.2747,"lon":-78.83113},"pressure_altitude":39025,"true_track":95.8,"uplink_feedback":4,"utc_coupled":true,"vertical_velocity_geometric":-128,"vv_src":"geometric"}
2022-01-27 18:42:49.581 | 22-01-27 18:42:49.580 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","callsign":"WMN528","capability_codes":{"es_in":true,"tcas_operational":false,"uat_in":true},"east_velocity":528,"emergency":"none","emitter_category":"A2","geometric_altitude":37975,"ground_speed":530,"gva":2,"metadata":{"errors":2,"received_at":1643308969.551,"rssi":-16.7},"mops_version":2,"nac_p":10,"nac_v":2,"nic":9,"nic_baro":1,"nic_supplement":false,"north_velocity":-55,"operational_modes":{"atc_services":false,"ident_active":false,"tcas_ra_active":false},"position":{"lat":43.27375,"lon":-78.81845},"pressure_altitude":39025,"sda":2,"sil":3,"sil_supplement":"per_hour","single_antenna":true,"transmit_mso":50,"true_track":95.9,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":-192,"vv_src":"geometric"}
2022-01-27 18:42:49.581 | [i]sent 1,0 AC
2022-01-27 18:42:49.581 | 22-01-27 18:42:49.578 [D] sent 1 of 1 aircraft, 0 ignored, 0 outdated
2022-01-27 18:42:53.481 | 22-01-27 18:42:53.481 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":528,"ground_speed":531,"metadata":{"errors":4,"received_at":1643308973.414,"rssi":-16.7},"nic":9,"north_velocity":-56,"position":{"lat":43.27272,"lon":-78.80508},"pressure_altitude":39000,"true_track":96.1,"uplink_feedback":1,"utc_coupled":true,"vertical_velocity_geometric":-256,"vv_src":"geometric"}
2022-01-27 18:42:57.574 | 22-01-27 18:42:57.574 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":528,"geometric_altitude":37950,"ground_speed":531,"metadata":{"errors":4,"received_at":1643308977.541,"rssi":-16.1},"nic":9,"north_velocity":-56,"position":{"lat":43.27167,"lon":-78.79171},"pressure_altitude":39000,"true_track":96.1,"uplink_feedback":4,"utc_coupled":true,"vertical_velocity_geometric":-192,"vv_src":"geometric"}
2022-01-27 18:42:57.575 | [i]sent 1,0 AC
2022-01-27 18:42:57.575 | 22-01-27 18:42:57.573 [D] sent 1 of 1 aircraft, 0 ignored, 0 outdated
2022-01-27 18:42:58.519 | 22-01-27 18:42:58.519 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":528,"ground_speed":531,"metadata":{"errors":4,"received_at":1643308978.478,"rssi":-15.5},"nic":9,"north_velocity":-56,"position":{"lat":43.27141,"lon":-78.78837},"pressure_altitude":39000,"true_track":96.1,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":-192,"vv_src":"geometric"}
2022-01-27 18:42:59.273 | 22-01-27 18:42:59.273 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":528,"ground_speed":531,"metadata":{"errors":2,"received_at":1643308979.219,"rssi":-16.3},"nic":9,"north_velocity":-56,"position":{"lat":43.2712,"lon":-78.78571},"pressure_altitude":39000,"true_track":96.1,"uplink_feedback":1,"utc_coupled":true,"vertical_velocity_geometric":-128,"vv_src":"geometric"}
2022-01-27 18:43:01.601 | 22-01-27 18:43:01.601 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":528,"ground_speed":531,"metadata":{"errors":4,"received_at":1643308981.555,"rssi":-18.8},"nic":9,"north_velocity":-56,"position":{"lat":43.27064,"lon":-78.77835},"pressure_altitude":39000,"true_track":96.1,"uplink_feedback":1,"utc_coupled":true,"vertical_velocity_geometric":-128,"vv_src":"geometric"}
2022-01-27 18:43:26.451 | 22-01-27 18:43:26.451 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","capability_codes":{"es_in":true,"tcas_operational":false,"uat_in":true},"east_velocity":527,"emergency":"none","emitter_category":"A2","flightplan_id":"1476","geometric_altitude":37950,"ground_speed":530,"gva":2,"metadata":{"errors":5,"received_at":1643309006.404,"rssi":-16.9},"mops_version":2,"nac_p":10,"nac_v":2,"nic":9,"nic_baro":1,"nic_supplement":false,"north_velocity":-56,"operational_modes":{"atc_services":false,"ident_active":false,"tcas_ra_active":false},"position":{"lat":43.26414,"lon":-78.69552},"pressure_altitude":39000,"sda":2,"sil":3,"sil_supplement":"per_hour","single_antenna":true,"transmit_mso":39,"true_track":96.1,"uplink_feedback":7,"utc_coupled":true,"vertical_velocity_geometric":192,"vv_src":"geometric"}
2022-01-27 18:43:26.451 | [i]sent 1,0 AC
2022-01-27 18:43:26.451 | 22-01-27 18:43:26.449 [D] sent 1 of 1 aircraft, 0 ignored, 0 outdated
2022-01-27 18:43:30.981 | 22-01-27 18:43:30.981 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":527,"ground_speed":530,"metadata":{"errors":6,"received_at":1643309010.934,"rssi":-17.0},"nic":9,"north_velocity":-56,"position":{"lat":43.26296,"lon":-78.68017999999999},"pressure_altitude":39000,"true_track":96.1,"uplink_feedback":2,"utc_coupled":true,"vertical_velocity_geometric":192,"vv_src":"geometric"}
2022-01-27 18:43:31.422 | 22-01-27 18:43:31.422 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":526,"ground_speed":529,"metadata":{"errors":3,"received_at":1643309011.375,"rssi":-18.3},"nic":9,"north_velocity":-56,"position":{"lat":43.26285,"lon":-78.67885},"pressure_altitude":39000,"true_track":96.1,"uplink_feedback":1,"utc_coupled":true,"vertical_velocity_geometric":192,"vv_src":"geometric"}
2022-01-27 18:43:38.909 | 22-01-27 18:43:38.909 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":526,"ground_speed":528,"metadata":{"errors":5,"received_at":1643309018.851,"rssi":-16.1},"nic":9,"north_velocity":-55,"position":{"lat":43.2609,"lon":-78.65355},"pressure_altitude":39025,"true_track":96.0,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
2022-01-27 18:43:38.909 | [i]sent 1,0 AC
2022-01-27 18:43:38.909 | 22-01-27 18:43:38.905 [D] sent 1 of 1 aircraft, 0 ignored, 0 outdated
2022-01-27 18:43:39.287 | 22-01-27 18:43:39.286 [I] {"address":"a6a8a1","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":526,"ground_speed":528,"metadata":{"errors":2,"received_at":1643309019.27,"rssi":-15.8},"nic":9,"north_velocity":-55,"position":{"lat":43.26079,"lon":-78.65222},"pressure_altitude":39025,"true_track":96.0,"uplink_feedback":5,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
2022-01-27 18:44:08.912 | [n]ping 1
2022-01-27 18:44:09.913 | [n]syncing stream result: 1
2022-01-27 18:44:38.916 | [n]ping 2
2022-01-27 18:44:39.916 | [n]syncing stream result: 1
2022-01-27 18:45:08.920 | [n]ping 3
2022-01-27 18:45:09.920 | [n]syncing stream result: 1
2022-01-27 18:45:38.924 | [n]ping 4
2022-01-27 18:45:39.925 | [n]syncing stream result: 1
2022-01-27 18:46:08.928 | [n]ping 5
2022-01-27 18:46:09.929 | [n]syncing stream result: 1
2022-01-27 18:46:38.932 | [n]ping 6
2022-01-27 18:46:39.933 | [n]syncing stream result: 1
pi@raspberrypi:~ $
Output from dump978-fa port 30979
pi@raspberrypi:~ $ nc 127.0.0.1 30979
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":50,"ground_speed":92,"metadata":{"errors":6,"received_at":1644093700.932,"rssi":-17.9},"nic":8,"north_velocity":78,"position":{"lat":43.95821,"lon":-78.96687},"pressure_altitude":3300,"true_track":32.7,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":1216,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":148,"ground_speed":149,"metadata":{"errors":2,"received_at":1644093742.512,"rssi":-16.6},"nic":8,"north_velocity":-23,"position":{"lat":43.96117,"lon":-78.93705},"pressure_altitude":3600,"true_track":98.8,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":192,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":163,"geometric_altitude":3600,"ground_speed":164,"metadata":{"errors":6,"received_at":1644093839.987,"rssi":-16.5},"nic":7,"north_velocity":-19,"position":{"lat":43.95222,"lon":-78.83718},"pressure_altitude":3600,"true_track":96.6,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":163,"geometric_altitude":3600,"ground_speed":164,"metadata":{"errors":6,"received_at":1644093845.79,"rssi":-15.6},"nic":8,"north_velocity":-20,"position":{"lat":43.95169,"lon":-78.83092},"pressure_altitude":3600,"true_track":97.0,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":163,"ground_speed":164,"metadata":{"errors":2,"received_at":1644093846.864,"rssi":-15.6},"nic":8,"north_velocity":-20,"position":{"lat":43.9516,"lon":-78.82987},"pressure_altitude":3600,"true_track":97.0,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","callsign":"CGWCA","capability_codes":{"es_in":true,"tcas_operational":false,"uat_in":true},"east_velocity":163,"emergency":"none","emitter_category":"A1","geometric_altitude":3600,"ground_speed":164,"gva":2,"metadata":{"errors":7,"received_at":1644093847.369,"rssi":-17.1},"mops_version":2,"nac_p":9,"nac_v":1,"nic":8,"nic_baro":0,"nic_supplement":false,"north_velocity":-20,"operational_modes":{"atc_services":false,"ident_active":false,"tcas_ra_active":false},"position":{"lat":43.95151,"lon":-78.82881},"pressure_altitude":3600,"sda":2,"sil":3,"sil_supplement":"per_hour","single_antenna":true,"transmit_mso":28,"true_track":97.0,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","capability_codes":{"es_in":true,"tcas_operational":false,"uat_in":true},"east_velocity":163,"emergency":"none","emitter_category":"A1","flightplan_id":"5305","geometric_altitude":3600,"ground_speed":164,"gva":2,"metadata":{"errors":5,"received_at":1644093848.439,"rssi":-14.8},"mops_version":2,"nac_p":9,"nac_v":1,"nic":8,"nic_baro":0,"nic_supplement":false,"north_velocity":-20,"operational_modes":{"atc_services":false,"ident_active":false,"tcas_ra_active":false},"position":{"lat":43.95141,"lon":-78.82778},"pressure_altitude":3600,"sda":2,"sil":3,"sil_supplement":"per_hour","single_antenna":true,"transmit_mso":56,"true_track":97.0,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":163,"ground_speed":164,"metadata":{"errors":6,"received_at":1644093852.26,"rssi":-16.1},"nic":8,"north_velocity":-20,"position":{"lat":43.95104,"lon":-78.8236},"pressure_altitude":3600,"true_track":97.0,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","callsign":"CGWCA","capability_codes":{"es_in":true,"tcas_operational":false,"uat_in":true},"east_velocity":163,"emergency":"none","emitter_category":"A1","geometric_altitude":3600,"ground_speed":164,"gva":2,"metadata":{"errors":2,"received_at":1644093853.439,"rssi":-12.9},"mops_version":2,"nac_p":9,"nac_v":1,"nic":8,"nic_baro":0,"nic_supplement":false,"north_velocity":-20,"operational_modes":{"atc_services":false,"ident_active":false,"tcas_ra_active":false},"position":{"lat":43.95093,"lon":-78.82255},"pressure_altitude":3600,"sda":2,"sil":3,"sil_supplement":"per_hour","single_antenna":true,"transmit_mso":51,"true_track":97.0,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":163,"ground_speed":164,"metadata":{"errors":2,"received_at":1644093854.303,"rssi":-15.4},"nic":8,"north_velocity":-20,"position":{"lat":43.95083,"lon":-78.82148},"pressure_altitude":3600,"true_track":97.0,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":163,"geometric_altitude":3600,"ground_speed":164,"metadata":{"errors":7,"received_at":1644093855.507,"rssi":-16.7},"nic":8,"north_velocity":-20,"position":{"lat":43.95074,"lon":-78.82042},"pressure_altitude":3600,"true_track":97.0,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":163,"geometric_altitude":3600,"ground_speed":164,"metadata":{"errors":6,"received_at":1644093856.969,"rssi":-15.2},"nic":8,"north_velocity":-20,"position":{"lat":43.95066,"lon":-78.81939},"pressure_altitude":3600,"true_track":97.0,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":163,"ground_speed":164,"metadata":{"errors":5,"received_at":1644093857.996,"rssi":-15.6},"nic":8,"north_velocity":-20,"position":{"lat":43.95055,"lon":-78.81832},"pressure_altitude":3600,"true_track":97.0,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","capability_codes":{"es_in":true,"tcas_operational":false,"uat_in":true},"east_velocity":163,"emergency":"none","emitter_category":"A1","flightplan_id":"5305","geometric_altitude":3600,"ground_speed":164,"gva":2,"metadata":{"errors":4,"received_at":1644093858.856,"rssi":-16.2},"mops_version":2,"nac_p":9,"nac_v":1,"nic":8,"nic_baro":0,"nic_supplement":false,"north_velocity":-20,"operational_modes":{"atc_services":false,"ident_active":false,"tcas_ra_active":false},"position":{"lat":43.95046,"lon":-78.81729},"pressure_altitude":3600,"sda":2,"sil":3,"sil_supplement":"per_hour","single_antenna":true,"transmit_mso":59,"true_track":97.0,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":163,"ground_speed":164,"metadata":{"errors":3,"received_at":1644093859.909,"rssi":-15.3},"nic":8,"north_velocity":-20,"position":{"lat":43.95036,"lon":-78.81624},"pressure_altitude":3600,"true_track":97.0,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":163,"ground_speed":164,"metadata":{"errors":5,"received_at":1644093860.966,"rssi":-16.3},"nic":8,"north_velocity":-20,"position":{"lat":43.95027,"lon":-78.81519},"pressure_altitude":3600,"true_track":97.0,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":163,"geometric_altitude":3600,"ground_speed":164,"metadata":{"errors":6,"received_at":1644093861.243,"rssi":-16.2},"nic":8,"north_velocity":-20,"position":{"lat":43.95016,"lon":-78.81414},"pressure_altitude":3600,"true_track":97.0,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":162,"ground_speed":163,"metadata":{"errors":4,"received_at":1644093862.699,"rssi":-14.7},"nic":8,"north_velocity":-20,"position":{"lat":43.95008,"lon":-78.81311},"pressure_altitude":3600,"true_track":97.0,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","callsign":"CGWCA","capability_codes":{"es_in":true,"tcas_operational":false,"uat_in":true},"east_velocity":162,"emergency":"none","emitter_category":"A1","geometric_altitude":3600,"ground_speed":163,"gva":2,"metadata":{"errors":2,"received_at":1644093863.2,"rssi":-13.7},"mops_version":2,"nac_p":9,"nac_v":1,"nic":8,"nic_baro":0,"nic_supplement":false,"north_velocity":-20,"operational_modes":{"atc_services":false,"ident_active":false,"tcas_ra_active":false},"position":{"lat":43.94997,"lon":-78.81206},"pressure_altitude":3600,"sda":2,"sil":3,"sil_supplement":"per_hour","single_antenna":true,"transmit_mso":55,"true_track":97.0,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","capability_codes":{"es_in":true,"tcas_operational":false,"uat_in":true},"east_velocity":162,"emergency":"none","emitter_category":"A1","flightplan_id":"5305","geometric_altitude":3600,"ground_speed":163,"gva":2,"metadata":{"errors":3,"received_at":1644093864.853,"rssi":-12.5},"mops_version":2,"nac_p":9,"nac_v":1,"nic":8,"nic_baro":0,"nic_supplement":false,"north_velocity":-20,"operational_modes":{"atc_services":false,"ident_active":false,"tcas_ra_active":false},"position":{"lat":43.94988,"lon":-78.811},"pressure_altitude":3600,"sda":2,"sil":3,"sil_supplement":"per_hour","single_antenna":true,"transmit_mso":44,"true_track":97.0,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":163,"ground_speed":164,"metadata":{"errors":2,"received_at":1644093865.378,"rssi":-12.1},"nic":8,"north_velocity":-20,"position":{"lat":43.9498,"lon":-78.80997},"pressure_altitude":3600,"true_track":97.0,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":163,"geometric_altitude":3600,"ground_speed":164,"metadata":{"errors":2,"received_at":1644093866.429,"rssi":-12.5},"nic":8,"north_velocity":-20,"position":{"lat":43.94969,"lon":-78.80894},"pressure_altitude":3600,"true_track":97.0,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":162,"ground_speed":163,"metadata":{"errors":1,"received_at":1644093867.779,"rssi":-12.2},"nic":8,"north_velocity":-20,"position":{"lat":43.9496,"lon":-78.80791},"pressure_altitude":3600,"true_track":97.0,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":162,"ground_speed":163,"metadata":{"errors":1,"received_at":1644093868.227,"rssi":-13.6},"nic":8,"north_velocity":-20,"position":{"lat":43.9495,"lon":-78.80686},"pressure_altitude":3600,"true_track":97.0,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","callsign":"CGWCA","capability_codes":{"es_in":true,"tcas_operational":false,"uat_in":true},"east_velocity":162,"emergency":"none","emitter_category":"A1","geometric_altitude":3600,"ground_speed":163,"gva":2,"metadata":{"errors":3,"received_at":1644093869.601,"rssi":-13.0},"mops_version":2,"nac_p":9,"nac_v":1,"nic":8,"nic_baro":0,"nic_supplement":false,"north_velocity":-20,"operational_modes":{"atc_services":false,"ident_active":false,"tcas_ra_active":false},"position":{"lat":43.94941,"lon":-78.80583},"pressure_altitude":3600,"sda":2,"sil":3,"sil_supplement":"per_hour","single_antenna":true,"transmit_mso":58,"true_track":97.0,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":162,"ground_speed":163,"metadata":{"errors":1,"received_at":1644093870.247,"rssi":-12.3},"nic":8,"north_velocity":-20,"position":{"lat":43.9493,"lon":-78.80478},"pressure_altitude":3600,"true_track":97.0,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":163,"geometric_altitude":3600,"ground_speed":164,"metadata":{"errors":2,"received_at":1644093871.645,"rssi":-13.8},"nic":8,"north_velocity":-20,"position":{"lat":43.9492,"lon":-78.80373},"pressure_altitude":3600,"true_track":97.0,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":162,"geometric_altitude":3600,"ground_speed":163,"metadata":{"errors":0,"received_at":1644093872.689,"rssi":-14.0},"nic":8,"north_velocity":-20,"position":{"lat":43.94911,"lon":-78.80268},"pressure_altitude":3600,"true_track":97.0,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":163,"ground_speed":164,"metadata":{"errors":1,"received_at":1644093873.511,"rssi":-13.6},"nic":8,"north_velocity":-20,"position":{"lat":43.949,"lon":-78.80163},"pressure_altitude":3600,"true_track":97.0,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","capability_codes":{"es_in":true,"tcas_operational":false,"uat_in":true},"east_velocity":162,"emergency":"none","emitter_category":"A1","flightplan_id":"5305","geometric_altitude":3600,"ground_speed":163,"gva":2,"metadata":{"errors":4,"received_at":1644093874.353,"rssi":-15.7},"mops_version":2,"nac_p":9,"nac_v":1,"nic":8,"nic_baro":0,"nic_supplement":false,"north_velocity":-21,"operational_modes":{"atc_services":false,"ident_active":false,"tcas_ra_active":false},"position":{"lat":43.9489,"lon":-78.80058},"pressure_altitude":3600,"sda":2,"sil":3,"sil_supplement":"per_hour","single_antenna":true,"transmit_mso":30,"true_track":97.4,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":162,"ground_speed":163,"metadata":{"errors":2,"received_at":1644093876.64,"rssi":-15.1},"nic":8,"north_velocity":-21,"position":{"lat":43.94872,"lon":-78.79849},"pressure_altitude":3600,"true_track":97.4,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":162,"geometric_altitude":3600,"ground_speed":163,"metadata":{"errors":6,"received_at":1644093877.311,"rssi":-15.1},"nic":8,"north_velocity":-20,"position":{"lat":43.94862,"lon":-78.79746},"pressure_altitude":3600,"true_track":97.0,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":162,"ground_speed":163,"metadata":{"errors":4,"received_at":1644093878.349,"rssi":-14.4},"nic":8,"north_velocity":-20,"position":{"lat":43.94853,"lon":-78.79643},"pressure_altitude":3600,"true_track":97.0,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","callsign":"CGWCA","capability_codes":{"es_in":true,"tcas_operational":false,"uat_in":true},"east_velocity":163,"emergency":"none","emitter_category":"A1","geometric_altitude":3600,"ground_speed":164,"gva":2,"metadata":{"errors":5,"received_at":1644093879.444,"rssi":-15.5},"mops_version":2,"nac_p":9,"nac_v":1,"nic":8,"nic_baro":0,"nic_supplement":false,"north_velocity":-20,"operational_modes":{"atc_services":false,"ident_active":false,"tcas_ra_active":false},"position":{"lat":43.94845,"lon":-78.79538},"pressure_altitude":3600,"sda":2,"sil":3,"sil_supplement":"per_hour","single_antenna":true,"transmit_mso":7,"true_track":97.0,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","capability_codes":{"es_in":true,"tcas_operational":false,"uat_in":true},"east_velocity":162,"emergency":"none","emitter_category":"A1","flightplan_id":"5305","geometric_altitude":3600,"ground_speed":163,"gva":2,"metadata":{"errors":5,"received_at":1644093880.279,"rssi":-14.6},"mops_version":2,"nac_p":9,"nac_v":1,"nic":8,"nic_baro":0,"nic_supplement":false,"north_velocity":-20,"operational_modes":{"atc_services":false,"ident_active":false,"tcas_ra_active":false},"position":{"lat":43.94834,"lon":-78.79433},"pressure_altitude":3600,"sda":2,"sil":3,"sil_supplement":"per_hour","single_antenna":true,"transmit_mso":52,"true_track":97.0,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":162,"ground_speed":163,"metadata":{"errors":1,"received_at":1644093881.798,"rssi":-15.0},"nic":8,"north_velocity":-20,"position":{"lat":43.94825,"lon":-78.7933},"pressure_altitude":3600,"true_track":97.0,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":163,"geometric_altitude":3600,"ground_speed":164,"metadata":{"errors":3,"received_at":1644093882.431,"rssi":-15.5},"nic":8,"north_velocity":-20,"position":{"lat":43.94814,"lon":-78.79225},"pressure_altitude":3600,"true_track":97.0,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":162,"ground_speed":163,"metadata":{"errors":5,"received_at":1644093883.576,"rssi":-16.6},"nic":8,"north_velocity":-20,"position":{"lat":43.94804,"lon":-78.7912},"pressure_altitude":3600,"true_track":97.0,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":162,"ground_speed":163,"metadata":{"errors":3,"received_at":1644093886.803,"rssi":-16.1},"nic":8,"north_velocity":-20,"position":{"lat":43.94776,"lon":-78.78804},"pressure_altitude":3600,"true_track":97.0,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":162,"geometric_altitude":3600,"ground_speed":163,"metadata":{"errors":4,"received_at":1644093887.795,"rssi":-15.4},"nic":8,"north_velocity":-20,"position":{"lat":43.94767,"lon":-78.78699},"pressure_altitude":3600,"true_track":97.0,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":162,"geometric_altitude":3600,"ground_speed":163,"metadata":{"errors":7,"received_at":1644093888.222,"rssi":-16.2},"nic":8,"north_velocity":-19,"position":{"lat":43.94757,"lon":-78.78594},"pressure_altitude":3600,"true_track":96.7,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":163,"geometric_altitude":3600,"ground_speed":164,"metadata":{"errors":4,"received_at":1644093893.394,"rssi":-15.4},"nic":8,"north_velocity":-19,"position":{"lat":43.94711,"lon":-78.78073},"pressure_altitude":3600,"true_track":96.6,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":163,"ground_speed":164,"metadata":{"errors":0,"received_at":1644093894.214,"rssi":-15.0},"nic":8,"north_velocity":-18,"position":{"lat":43.94703,"lon":-78.7797},"pressure_altitude":3600,"true_track":96.3,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","callsign":"CGWCA","capability_codes":{"es_in":true,"tcas_operational":false,"uat_in":true},"east_velocity":162,"emergency":"none","emitter_category":"A1","geometric_altitude":3600,"ground_speed":163,"gva":2,"metadata":{"errors":7,"received_at":1644093895.703,"rssi":-14.4},"mops_version":2,"nac_p":9,"nac_v":1,"nic":8,"nic_baro":0,"nic_supplement":false,"north_velocity":-19,"operational_modes":{"atc_services":false,"ident_active":false,"tcas_ra_active":false},"position":{"lat":43.94694,"lon":-78.77865},"pressure_altitude":3600,"sda":2,"sil":3,"sil_supplement":"per_hour","single_antenna":true,"transmit_mso":24,"true_track":96.7,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","capability_codes":{"es_in":true,"tcas_operational":false,"uat_in":true},"east_velocity":163,"emergency":"none","emitter_category":"A1","flightplan_id":"5305","geometric_altitude":3600,"ground_speed":164,"gva":2,"metadata":{"errors":4,"received_at":1644093896.722,"rssi":-14.7},"mops_version":2,"nac_p":9,"nac_v":1,"nic":7,"nic_baro":0,"nic_supplement":false,"north_velocity":-19,"operational_modes":{"atc_services":false,"ident_active":false,"tcas_ra_active":false},"position":{"lat":43.94686,"lon":-78.77757},"pressure_altitude":3600,"sda":2,"sil":3,"sil_supplement":"per_hour","single_antenna":true,"transmit_mso":32,"true_track":96.6,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":162,"ground_speed":163,"metadata":{"errors":3,"received_at":1644093897.636,"rssi":-16.1},"nic":7,"north_velocity":-19,"position":{"lat":43.94677,"lon":-78.77654},"pressure_altitude":3600,"true_track":96.7,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":162,"ground_speed":163,"metadata":{"errors":6,"received_at":1644093899.992,"rssi":-19.0},"nic":7,"north_velocity":-19,"position":{"lat":43.9466,"lon":-78.77446},"pressure_altitude":3600,"true_track":96.7,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":162,"ground_speed":163,"metadata":{"errors":3,"received_at":1644093900.805,"rssi":-15.8},"nic":7,"north_velocity":-19,"position":{"lat":43.94649,"lon":-78.77341},"pressure_altitude":3600,"true_track":96.7,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","callsign":"CGWCA","capability_codes":{"es_in":true,"tcas_operational":false,"uat_in":true},"east_velocity":162,"emergency":"none","emitter_category":"A1","geometric_altitude":3600,"ground_speed":163,"gva":2,"metadata":{"errors":0,"received_at":1644093901.368,"rssi":-14.6},"mops_version":2,"nac_p":9,"nac_v":1,"nic":7,"nic_baro":0,"nic_supplement":false,"north_velocity":-19,"operational_modes":{"atc_services":false,"ident_active":false,"tcas_ra_active":false},"position":{"lat":43.94641,"lon":-78.77236},"pressure_altitude":3600,"sda":2,"sil":3,"sil_supplement":"per_hour","single_antenna":true,"transmit_mso":27,"true_track":96.7,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
{"address":"c07ef5","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":162,"ground_speed":163,"metadata":{"errors":2,"received_at":1644093902.98,"rssi":-13.4},"nic":7,"north_velocity":-19,"position":{"lat":43.94632,"lon":-78.77135},"pressure_altitude":3600,"true_track":96.7,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":0,"vv_src":"geometric"}
^C
pi@raspberrypi:~ $
