Installed 3.7.1 on sd card and installed in rpi3B Got new station ID . dump1090 piaware seem to be working. FA is logging aircraft and skyview1090 shows 80+ aircraft. skyview978 will show 3-5 messages/second and up to 50 aircraft, but then messages/sec drops to 0 and all aircraft disappear from display. Intermittently the aircraft come back and then go away again. I have used 3 different dongles. Sample journal below. I notice PLL is not locked. I wonder if tuned frequency is drifting?
I am located 1.0 miles from a major international airport and have 2 busy GA airports 4 and 9 miles. The UAT aircraft are mostly GA (C172, C310, PA28) plus foreign air carriers (???why). and seem legitimate.
Additional I stopped dump1090 just in case rpi was overloaded.
journalctl -u dump978-fa
– Logs begin at Thu 2016-11-03 17:16:42 UTC, end at Sun 2019-05-19 18:36:53 UTC. –
May 19 17:17:09 piaware systemd[1]: Started dump978 ADS-B UAT receiver.
May 19 17:17:10 piaware dump978-fa[458]: raw-port: listening for connections on 0.0.0.0:30978
May 19 17:17:10 piaware dump978-fa[458]: raw-port: listening for connections on [::]:30978
May 19 17:17:10 piaware dump978-fa[458]: json-port: listening for connections on 0.0.0.0:30979
May 19 17:17:10 piaware dump978-fa[458]: json-port: listening for connections on [::]:30979
May 19 17:17:10 piaware dump978-fa[458]: Detached kernel driver
May 19 17:17:10 piaware dump978-fa[458]: Found Rafael Micro R820T tuner
May 19 17:17:11 piaware dump978-fa[458]: Reattached kernel driver
May 19 17:17:11 piaware dump978-fa[458]: usb_claim_interface error -6
May 19 17:17:11 piaware dump978-fa[458]: Detached kernel driver
May 19 17:17:11 piaware dump978-fa[458]: Found Rafael Micro R820T tuner
May 19 17:17:11 piaware dump978-fa[458]: Exact sample rate is: 2083333.135571 Hz
May 19 17:17:11 piaware dump978-fa[458]: [R82XX] PLL not locked!
May 19 17:17:12 piaware dump978-fa[458]: SoapySDR: using manual gain 49.0 dB
May 19 17:17:12 piaware dump978-fa[458]: SoapySDR: using stream setting buffsize=262144
May 19 17:17:12 piaware dump978-fa[458]: [::]:30978: accepted a connection from [::1]:51086
May 19 17:17:13 piaware dump978-fa[458]: [::]:30978: accepted a connection from [::1]:51090
May 19 17:46:23 piaware dump978-fa[458]: Sample source reports error: TIMEOUT
May 19 17:46:23 piaware dump978-fa[458]: Reattached kernel driver
May 19 17:46:23 piaware systemd[1]: dump978-fa.service: Main process exited, code=exited, status=1/FAILURE
May 19 17:46:23 piaware systemd[1]: dump978-fa.service: Unit entered failed state.
May 19 17:46:23 piaware systemd[1]: dump978-fa.service: Failed with result ‘exit-code’.
May 19 17:46:53 piaware systemd[1]: dump978-fa.service: Service hold-off time over, scheduling restart.
May 19 17:46:53 piaware systemd[1]: Stopped dump978 ADS-B UAT receiver.
May 19 17:46:54 piaware systemd[1]: Started dump978 ADS-B UAT receiver.
May 19 17:46:54 piaware dump978-fa[1127]: raw-port: listening for connections on 0.0.0.0:30978
May 19 17:46:54 piaware dump978-fa[1127]: raw-port: listening for connections on [::]:30978
May 19 17:46:54 piaware dump978-fa[1127]: json-port: listening for connections on 0.0.0.0:30979
May 19 17:46:54 piaware dump978-fa[1127]: json-port: listening for connections on [::]:30979
May 19 17:46:54 piaware dump978-fa[1127]: Detached kernel driver
May 19 17:46:54 piaware dump978-fa[1127]: Found Rafael Micro R820T tuner
May 19 17:46:55 piaware dump978-fa[1127]: Reattached kernel driver
May 19 17:46:55 piaware dump978-fa[1127]: usb_claim_interface error -6
May 19 17:46:55 piaware dump978-fa[1127]: Detached kernel driver
May 19 17:46:55 piaware dump978-fa[1127]: Found Rafael Micro R820T tuner
May 19 17:46:55 piaware dump978-fa[1127]: Exact sample rate is: 2083333.135571 Hz
May 19 17:46:55 piaware dump978-fa[1127]: [R82XX] PLL not locked!
May 19 17:46:56 piaware dump978-fa[1127]: SoapySDR: using manual gain 49.0 dB
May 19 17:46:56 piaware dump978-fa[1127]: SoapySDR: using stream setting buffsize=262144
May 19 17:47:23 piaware dump978-fa[1127]: [::]:30978: accepted a connection from [::1]:51100
May 19 17:47:24 piaware dump978-fa[1127]: [::]:30978: accepted a connection from [::1]:51102
Forgot to say I tried that also. I am running a official RPi PS. Also pulled the 1090 dongle & tried a powered USB 3.0 hub. Though i am not convinced I have eliminated power as an issue
Means that the sample-reading thread didn’t get any data for 5 seconds; that usually means the dongle has wedged and is no longer sending data. (In normal operation, there’s a buffer of samples turning up multiple times per second). Agreed it’s probably a power issue. Reliably running two dongles on a single Pi seems to be a bit marginal on many setups.
Both of my stations (RPi Model2 and OrangePi PC) are running two dongles since end of March (3.7.0 >> 3.7.0.1 >> 3.7.1) without any problem. No special power supply or powered hub used, just the original power adapter which came with the board.
My 978 is running the SD v3.7.0.1. I frequently see what you described in
your original post. I can be watching the Skyview display with just a few
targets and suddenly it will “bloom” with several new targets, generally
all in about the same area. Then after just a couple good messages from
each they will all time out and go away in about a minute. A couple of minutes
later it does it again.
What I think is happening is that some aircraft in the area with 978 ADS-B in is
receiving ground station retransmissions of aircraft nearby. Those aircraft are
using 1090 ADS-B and can not be directly seen on 978. What you and I see on SV 978
is a sudden bloom of targets followed by them timing out. Those targets are yellow
TIS-B targets in italics with funky ICAO identifiers. On a busy GA day with a few
aircraft equipped with ASD-B in and you end up with a lot of yellow targets
coming and going on SV978.
When I first turned up my UAT feeder I spent about a week trying to figure out
why my receiver appeared to be flaky. I think what I have described here is
somewhat normal functioning for UAT978.
pi@piaware:~ $ journalctl -eu dump978-fa
May 20 04:29:43 piaware dump978-fa[32434]: raw-port: listening for connections on [:May 20 04:29:43 piaware dump978-fa[32434]: json-port: listening for connections on 0
May 20 04:29:43 piaware dump978-fa[32434]: json-port: listening for connections on [May 20 04:29:43 piaware dump978-fa[32434]: Found Rafael Micro R820T tuner
May 20 04:29:43 piaware dump978-fa[32434]: usb_claim_interface error -6
May 20 04:29:44 piaware dump978-fa[32434]: Found Rafael Micro R820T tuner
May 20 04:29:44 piaware dump978-fa[32434]: Exact sample rate is: 2083333.135571 Hz
May 20 04:29:44 piaware dump978-fa[32434]: [R82XX] PLL not locked!
May 20 04:29:44 piaware dump978-fa[32434]: SoapySDR: using manual gain 42.0 dB
May 20 04:29:44 piaware dump978-fa[32434]: SoapySDR: using stream setting buffsize=2
May 20 04:29:52 piaware dump978-fa[32434]: [::]:30978: accepted a connection from [:May 20 04:30:12 piaware dump978-fa[32434]: [::]:30978: accepted a connection from [:May 20 07:14:41 piaware dump978-fa[32434]: [::1]:33272: connection closed
May 20 07:14:42 piaware dump978-fa[32434]: Caught signal 15, exiting
May 20 07:14:42 piaware systemd[1]: Stopping dump978 ADS-B UAT receiver... May 20 07:14:42 piaware systemd[1]: dump978-fa.service: Main process exited, code=exMay 20 07:14:42 piaware systemd[1]: Stopped dump978 ADS-B UAT receiver.
May 20 07:14:42 piaware systemd[1]: dump978-fa.service: Unit entered failed state.
May 20 07:14:42 piaware systemd[1]: dump978-fa.service: Failed with result 'exit-cod
May 20 07:14:43 piaware systemd[1]: Started dump978 ADS-B UAT receiver.
May 20 07:14:43 piaware dump978-fa[29967]: raw-port: listening for connections on 0.
May 20 07:14:43 piaware dump978-fa[29967]: raw-port: listening for connections on [:May 20 07:14:43 piaware dump978-fa[29967]: json-port: listening for connections on 0
May 20 07:14:43 piaware dump978-fa[29967]: json-port: listening for connections on [May 20 07:14:43 piaware dump978-fa[29967]: Found Rafael Micro R820T tuner
May 20 07:14:43 piaware dump978-fa[29967]: usb_claim_interface error -6
May 20 07:14:44 piaware dump978-fa[29967]: Found Rafael Micro R820T tuner
May 20 07:14:44 piaware dump978-fa[29967]: Exact sample rate is: 2083333.135571 Hz
May 20 07:14:44 piaware dump978-fa[29967]: [R82XX] PLL not locked!
May 20 07:14:44 piaware dump978-fa[29967]: SoapySDR: using manual gain 42.0 dB
May 20 07:14:44 piaware dump978-fa[29967]: SoapySDR: using stream setting buffsize=2
May 20 07:14:52 piaware dump978-fa[29967]: [::]:30978: accepted a connection from [:May 20 07:15:12 piaware dump978-fa[29967]: [::]:30978: accepted a connection from [:~
May 20 07:14:42 piaware systemd[1]: dump978-fa.service: Failed with result 'exit-codMay 20 07:14:43 piaware systemd[1]: Started dump978 ADS-B UAT receiver.
pi@piaware:~ $
FAA only sends traffic data when there’s a 978 in/out equipped aircraft nearby to hear it. Also some of their radar sources seem to have a very low update rate.
(You maybe have two things going on - the TIS-B burstiness, which as mentioned above is expected; and the TIMEOUT thing, which is possibly a hardware problem but dump978 seems to be recovering from it OK when it happens, so I’d only expect a brief outage)
How can I turn off dump 978? It appears I have both 978 and 978-fa running and think that may be my issue. Is that what is happening? I copied this and hope it can help.
[2020-12-29 20:36 EST] faup978 exited normally
[2020-12-29 20:36 EST] lost connection to dump978-fa via faup978
[2020-12-29 20:36 EST] 2355 msgs recv’d from dump1090-fa (211 in last 5m); 2352 msgs sent to FlightAware
[2020-12-29 20:36 EST] 0 msgs recv’d from dump978-fa (0 in last 5m); 0 msgs sent to FlightAware
[2020-12-29 20:36 EST] no ADS-B data program seen listening on port 30978 for 30 seconds, next check in 60s
[2020-12-29 20:37 EST] no ADS-B data program seen listening on port 30978 for 90 seconds, next check in 60s
[2020-12-29 20:39 EST] faup978(19452): Connected to [::1]:30978
[2020-12-29 20:39 EST] ADS-B data program ‘dump978-fa’ is listening on port 30978, so far so good
[2020-12-29 20:39 EST] faup978(19452): Connecting to localhost:30978
[2020-12-29 20:39 EST] Starting faup978: /usr/lib/piaware/helpers/faup978 --connect localhost:30978
[2020-12-29 20:39 EST] lost connection to dump978-fa via faup978
[2020-12-29 20:39 EST] will reconnect to dump978-fa in 30 seconds
[2020-12-29 20:39 EST] faup978 exited normally
[2020-12-29 20:40 EST] faup978(19731): Connected to [::1]:30978
[2020-12-29 20:40 EST] faup978(19731): Connecting to localhost:30978
[2020-12-29 20:40 EST] Started faup978 (pid 19731) to connect to dump978-fa
[2020-12-29 20:40 EST] Starting faup978: /usr/lib/piaware/helpers/faup978 --connect localhost:30978
[2020-12-29 20:40 EST] faup978 exited normally
[2020-12-29 20:40 EST] will reconnect to dump978-fa in 30 seconds
[2020-12-29 20:40 EST] lost connection to dump978-fa via faup978
[2020-12-29 20:40 EST] no ADS-B data program seen listening on port 30978 for 31 seconds, next check in 60s
[2020-12-29 20:41 EST] 0 msgs recv’d from dump978-fa (0 in last 5m); 0 msgs sent to FlightAware
[2020-12-29 20:41 EST] 2626 msgs recv’d from dump1090-fa (271 in last 5m); 2623 msgs sent to FlightAware
[2020-12-29 20:41 EST] no ADS-B data program seen listening on port 30978 for 91 seconds, next check in 60s
[2020-12-29 20:42 EST] no ADS-B data program seen listening on port 30978 for 151 seconds, next check in 60s
[2020-12-29 20:43 EST] faup978(21477): Connected to [::1]:30978
[2020-12-29 20:43 EST] ADS-B data program ‘dump978-fa’ is listening on port 30978, so far so good
[2020-12-29 20:43 EST] faup978(21477): Connecting to localhost:30978
[2020-12-29 20:43 EST] Starting faup978: /usr/lib/piaware/helpers/faup978 --connect localhost:30978
[2020-12-29 20:43 EST] lost connection to dump978-fa via faup978
[2020-12-29 20:43 EST] faup978(21477): Connection failed: End of file
[2020-12-29 20:43 EST] will reconnect to dump978-fa in 30 seconds
[2020-12-29 20:43 EST] faup978 exited normally
Sorry for picture I have no e-mail on my pi
I am using the Blue FA dongle for 1090 and the Orange Dongle for 978 on a Pi 4 using the official Pi power supply no errors from the voltage check
Much better no 978 seen at all only 978-fa but my initial page on the Pi after I login shows 978 UAT receiver error Not connected to UAT receiver.
7% CPU load
Piaware Feeder normal
1090 receiver normal
Flightaware feed normal
Multilatateration normal
And if I use my homepage and check site configuration I get this which seems normal since I am sure there is no steady stream of 978.
no ADS-B data program seen listening on port 30978 for 70 seconds, next check in 60s
Seems to lose the 978-fa connection at times but does restart [2020-12-30 10:09 EST] mlat-client(826): Server status: synchronized with 240 nearby receivers
[2020-12-30 10:09 EST] mlat-client(826): Receiver: 151.7 msg/s received 75.6 msg/s processed (50%)
[2020-12-30 10:09 EST] mlat-client(826): Receiver status: connected
[2020-12-30 10:09 EST] mlat-client(826): Aircraft: 1 of 1 Mode S, 19 of 25 ADS-B used
[2020-12-30 10:09 EST] mlat-client(826): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.9kB/s UDP to server
[2020-12-30 10:09 EST] 0 msgs recv’d from dump978-fa (0 in last 5m); 0 msgs sent to FlightAware
[2020-12-30 10:09 EST] 1628 msgs recv’d from dump1090-fa (404 in last 5m); 1567 msgs sent to FlightAware
[2020-12-30 10:09 EST] no ADS-B data program seen listening on port 30978 for 190 seconds, next check in 60s
[2020-12-30 10:10 EST] no ADS-B data program seen listening on port 30978 for 250 seconds, next check in 60s
[2020-12-30 10:11 EST] no ADS-B data program seen listening on port 30978 for 310 seconds, next check in 60s
[2020-12-30 10:12 EST] no ADS-B data program seen listening on port 30978 for 370 seconds, trying to start it…
[2020-12-30 10:12 EST] attempting to start dump978…
[2020-12-30 10:12 EST] attempting to start dump978-fa using ‘systemctl --no-block restart dump978-fa.service < /dev/null’…
[2020-12-30 10:13 EST] no ADS-B data program seen listening on port 30978 for 10 seconds, next check in 60s
[2020-12-30 10:14 EST] no ADS-B data program seen listening on port 30978 for 70 seconds, next check in 60s
[2020-12-30 10:14 EST] 0 msgs recv’d from dump978-fa (0 in last 5m); 0 msgs sent to FlightAware
[2020-12-30 10:15 EST] no ADS-B data program seen listening on port 30978 for 130 seconds, next check in 60s
[2020-12-30 10:16 EST] no ADS-B data program seen listening on port 30978 for 190 seconds, next check in 60s
[2020-12-30 10:17 EST] no ADS-B data program seen listening on port 30978 for 250 seconds, next check in 60s
[2020-12-30 10:18 EST] no ADS-B data program seen listening on port 30978 for 310 seconds, next check in 60s
[2020-12-30 10:19 EST] no ADS-B data program seen listening on port 30978 for 371 seconds, trying to start it…
[2020-12-30 10:19 EST] attempting to start dump978-fa using ‘systemctl --no-block restart dump978-fa.service < /dev/null’…
[2020-12-30 10:19 EST] attempting to start dump978…
[2020-12-30 10:19 EST] no ADS-B data program seen listening on port 30978 for 10 seconds, next check in 60s
[2020-12-30 10:19 EST] 2637 msgs recv’d from dump1090-fa (526 in last 5m); 2576 msgs sent to FlightAware
[2020-12-30 10:19 EST] 0 msgs recv’d from dump978-fa (0 in last 5m); 0 msgs sent to FlightAware
[2020-12-30 10:20 EST] no ADS-B data program seen listening on port 30978 for 70 seconds, next check in 60s
