Hi,
I started two days ago with 3.8.1 and raspberry. I’m impressive by the work. and the capacity to receive information from planes as far as 230 km. Thank you to the team.
I have a question about dump978 and skyaware978
I understand that dump978 is for UAT and this is different from dump1090.
The result of command $ piaware-status indicates in bold hereunder:
PiAware master process (piaware) is running with pid 725.
PiAware ADS-B client (faup1090) is running with pid 19114.
PiAware mlat client (fa-mlat-client) is running with pid 19147.
Local ADS-B receiver (dump1090-fa) is running with pid 19083.
dump1090-fa (pid 19083) is listening for ES connections on port 30005.
Your feeder ID is d7b15c75-xxxx-xxxx-xxxx-xxxxxxxxx (from /var/cache/piaware/feeder_id)
so why there are such messages in /var/log/syslog file?
Apr 17 18:25:51 localhost skyaware978[19070]: Connecting to localhost:30978
Apr 17 18:25:51 localhost skyaware978[19070]: connection to [::1]:30978 failed: Connection refused
Apr 17 18:25:51 localhost skyaware978[19070]: connection to 127.0.0.1:30978 failed: Connection refused
Apr 17 18:25:51 localhost skyaware978[19070]: Connection failed: Connection refused
Apr 17 18:26:17 localhost systemd[1]: dump978-fa.service: Service RestartSec=30s expired, scheduling restart.
Apr 17 18:26:17 localhost systemd[1]: dump978-fa.service: Scheduled restart job, restart counter is at 4941.
Apr 17 18:26:17 localhost systemd[1]: Stopped dump978 ADS-B UAT receiver.
Apr 17 18:26:17 localhost systemd[1]: Started dump978 ADS-B UAT receiver.
Apr 17 18:26:17 localhost dump978-fa[29310]: raw-port: listening for connections on 0.0.0.0:30978
Apr 17 18:26:17 localhost dump978-fa[29310]: raw-port: listening for connections on [::]:30978
Apr 17 18:26:17 localhost dump978-fa[29310]: json-port: listening for connections on 0.0.0.0:30979
Apr 17 18:26:17 localhost dump978-fa[29310]: json-port: listening for connections on [::]:30979
Apr 17 18:26:17 localhost dump978-fa[29310]: usb_claim_interface error -6
Apr 17 18:26:17 localhost dump978-fa[29310]: SoapySDR: using maximum manual gain 0.0 dB
Apr 17 18:26:17 localhost dump978-fa[29310]: SoapySDR: using stream setting buffsize=262144
Apr 17 18:26:21 localhost skyaware978[19070]: Connecting to localhost:30978
Apr 17 18:26:21 localhost skyaware978[19070]: Connected to [::1]:30978
Apr 17 18:26:21 localhost dump978-fa[29310]: [::]:30978: accepted a connection from [::1]:35524
Apr 17 18:26:22 localhost dump978-fa[29310]: Message source reports error: TIMEOUT
Apr 17 18:26:22 localhost dump978-fa[29310]: Abnormal exit
Apr 17 18:26:22 localhost skyaware978[19070]: Connection failed: End of file
Apr 17 18:26:22 localhost systemd[1]: dump978-fa.service: Main process exited, code=exited, status=1/FAILURE
Apr 17 18:26:22 localhost systemd[1]: dump978-fa.service: Failed with result ‘exit-code’.
Apr 17 18:26:52 localhost skyaware978[19070]: Connecting to localhost:30978
Apr 17 18:26:52 localhost skyaware978[19070]: connection to [::1]:30978 failed: Connection refused
Apr 17 18:26:52 localhost skyaware978[19070]: connection to 127.0.0.1:30978 failed: Connection refused
Apr 17 18:26:52 localhost skyaware978[19070]: Connection failed: Connection refused
Apr 17 18:26:52 localhost systemd[1]: dump978-fa.service: Service RestartSec=30s expired, scheduling restart.
Apr 17 18:26:52 localhost systemd[1]: dump978-fa.service: Scheduled restart job, restart counter is at 4942.
Apr 17 18:26:52 localhost systemd[1]: Stopped dump978 ADS-B UAT receiver.
Apr 17 18:26:52 localhost systemd[1]: Started dump978 ADS-B UAT receiver.
Apr 17 18:26:53 localhost dump978-fa[29332]: raw-port: listening for connections on 0.0.0.0:30978
Apr 17 18:26:53 localhost dump978-fa[29332]: raw-port: listening for connections on [::]:30978
Apr 17 18:26:53 localhost dump978-fa[29332]: json-port: listening for connections on 0.0.0.0:30979
Apr 17 18:26:53 localhost dump978-fa[29332]: json-port: listening for connections on [::]:30979
Apr 17 18:26:53 localhost dump978-fa[29332]: usb_claim_interface error -6
Apr 17 18:26:53 localhost dump978-fa[29332]: SoapySDR: using maximum manual gain 0.0 dB
Apr 17 18:26:53 localhost dump978-fa[29332]: SoapySDR: using stream setting buffsize=262144
Apr 17 18:26:58 localhost dump978-fa[29332]: Message source reports error: TIMEOUT
Apr 17 18:26:58 localhost dump978-fa[29332]: Abnormal exit
Apr 17 18:26:58 localhost systemd[1]: dump978-fa.service: Main process exited, code=exited, status=1/FAILURE
Apr 17 18:26:58 localhost systemd[1]: dump978-fa.service: Failed with result ‘exit-code’.
What is wrong and how I can correct ?
Thank you for your help
Phil
