What I am trying to do is run the whole in Opera. Do not want to believe it, but this works. BingMap always starts up well after closing and speed of building up is miz good. What happens…with VPN oke, withoud no BingMap. Something with security??.
Bram, you are terrific. THANK YOU for all the help you have provided here to everyone. Community is great because of folks like you.
So, here is my set up.
-DEFAULT install of 3.6.3 from FlightAware. Clean Fresh Install. Works perfect
-Downloaded the 3d script from Shogoodae and it only got to display Map. No planes.
-…/data/airplanes.json is NOT reachable at all. Not locally not remotely.
-I do all my testing inside my own network
PiAware = 10.0.1.22
Local Net = 10.0.1.0/24
Viewing from 10.0.1.16
-Tried changing original 3D script to this.alt_baro and broke the map. Never loads fully and then frozen, no FPS
-Dete all 3D folder. Start fresh
-Download the 3d script from Brams, changed IP to http://10.0.1.22 and entered my Lat Lon
-Black map loads.
It seems it does not matter what the < then is set to. I have it set to < 50000 and still working but the entry MUST BE there. Without a “< xxxxx” there will nto be planes displayed. Not sure why.
Please edit setting in index.html
// ALL MANDATORY VARIABLES HERE... //
// Provide a Bing Maps API key here to enable the Bing imagery layer.
// You can obtain a free key (with usage limits) at
// https://www.bingmapsportal.com/ (you need a "basic key")
var BingMapsAPIKey = 'xxxxxxxxxxxxxxx';
// Location radar LAT / LON
var myLat = 51.00;
var myLon = 4.22;
// Default camera position (play and space key press)
var camLat = 51.6959:
var camLon = 3.8256;
var camDist = 138434;
var camPan = -0.027;
var camTilt = 1.055;
// ip adress dump1090 and pfclient
// change to external IP and forward the correct ports in Router
var hostIp = 'http://192.168.1.20'; // example 'http://192.168.1.200'
var dumpPort = 80; // dump1090 port number
var pfPort = 30053; // planefinder port number
Hallo Bram,
The 3d newone looks great, thanks, your a wizard.
One question, why is Schiphol the old map and when i zoom in it going to be new.
See the attachement. Is it possible to change that?
Beste Bramjacobse, after a few weeks silence (vacation) and good funtioning of the software a smal question. Is there a possibility to change the webserver port number of the 3d module. I tried something but no result.
Thanks for a answer.
greetings Ger
