FlightAware Discussions
dump1090 3D Viewer
#165
Hmmmm, Map is gone…:scream: , something to tweak tomorrow… :thinking:
#166
:airplane::small_airplane::flight_departure::flight_arrival::helicopter:
New version , have fun and post some screenshots :slight_smile:
Download - https://www.bramjacobse.nl/show/3d.zip
Please edit setting in index.html
// ALL MANDATORY VARIABLES HERE... //
// Provide a Bing Maps API key here to enable the Bing imagery layer.
// You can obtain a free key (with usage limits) at
// https://www.bingmapsportal.com/ (you need a "basic key")
var BingMapsAPIKey = 'xxxxxxxxxxxxxxx';
// Location radar LAT / LON
var myLat = 51.00;
var myLon = 4.22;
// Default camera position (play and space key press)
var camLat = 51.6959:
var camLon = 3.8256;
var camDist = 138434;
var camPan = -0.027;
var camTilt = 1.055;
 // ip adress dump1090 and pfclient
 //  change to external IP and forward the correct ports in Router
var hostIp = 'http://192.168.1.20'; // example 'http://192.168.1.200'
var dumpPort = 80; // dump1090 port number
var pfPort = 30053; // planefinder port number
#167
I get a 404 error for the 3d.zip file.
#168
Works fine for me: https://www.bramjacobse.nl/show/3d.zip
#172
Updated 3d.zip with CesiumJS 1.54
#173
works for me, with further tweak as am using mutability not fa … :grinning:
#174
Busy Friday evening
Windy saturday morning
#175
Freshed up the installation today (was there since August 2018).
The labels are missing…
PlaneFinder spits out data though:
$ http http://192.168.x.y:30053/ajax/aircraft
    "aircraft": {
        "3C49CB": {
            "altitude": 31850,
            "category": "A0",
            "flightno": "EW2037",
            "heading": 176,
            "is_adsb": true,
            "is_on_ground": false,
            "last_seen_time": 1550687902,
Any clues?
#176
PM send :slight_smile:
And updated 3d.zip
#177
Thanks for the quick fix, Bram!
Wish I could see them coming in that low on AMS, but I’m to far away at GRQ… and surrounded by high-rise buildings. :frowning:
#178
Same here - everything works like a charm, but the labels are missing. Great Work!
I’m using quite a specific setup as I work with a reverse proxy for the data (dump1090 on an internal host, 3d Viewer on an external), but in the debugger I see everything is fine.
#179
Do you have the Plane-Finder client installed…?
And can you acces the data from the plane-finder client http://x.x.x.x:30053/ajax/aircraft
Bram
#180
Hi Bram,
yes, pfclient ist up and running and the plane-finder client data gets loaded. Are there any fields in the json that must not be empty?
thanks
Danny
#181
Hi Bram,
Really interesting app that I would love to add to my collection.
I have dump1090 running on one PC and PFclient on another, so two different IP addresses.
Is there anyway I can add them both to the index.html file?
Thanks.
EDIT. I am getting terrain Ok, but no aircraft.
It seems that you don’t need to have both, dump1090 is for aircraft and positions and PFclient is for extra info, there is variable that you can set false and it will ignore PFclient?
Second EDIT. I am seeing the aircraft data in my browser debug console, but still nothing on the map.
#182
Add a extra line for IP pfclient in the index.html
var hostIppf = 'http://x.x.x.x'; //  ip of planefinder client
change
url: hostIp + ':' + pfPort + '/ajax/aircraft',
to
url: hostIppf + ':' + pfPort + '/ajax/aircraft',
Regards Bram
#183
Hi Baldgeek ,
Are you using dump1090-fa or other a other version…?
#184
Foggy Morning , and holding…:slight_smile:
Updated 3d.zip - https://www.bramjacobse.nl/show/3d.zip
added
new index-test.html  only uses dump1090-fa  and only show the flight Ident
#185
Ah, that would be the problem then, I am using dump1090. I did not know that FA had changed the data format.
Thanks for letting me know, I will spin up an FA build and see what happens.
Cheers.
#186
check this.
#187
I changed it, no aircraft. Will have to wait till I get a moment to spin up a FA build on the pi. Thanks for getting back to us. (Long term I would like to see about getting it to work on dump1090 as I have many of those feeds and a master feed for my whole system, be nice to see it run with that).
