I received the message concerning expanding the SD space on the raspberry pi and I am trying to figure out how to connect to the raspberry pi. I know on regular raspberry pi’s (I have 1 running PiHole and two others) I can connect and HDMI cable to one of our TV’s and a keyboard and see the Raspberry Pi startup alone with a username prompt when I hit return.
With the raspberry pi running PiAware, I am not seeing any output when it boots, and after I know it is working and I hit return I still see no output. Of course I would not believe SSH Server is running so I could at least do the default pi username and raspberrypi for the password.
Of course I would like to change the default password on the Raspberry pi and extend the SD card.
I finally did get the PiAware up and running, got the SSH Server enabled and am now able to log into the PiAware Raspberry Pi.
Still getting no display using an HDMI cable connected to the RaspberryPi, which is connected to the HDMI port on the TV. Not needed as much now, but I am curious as to why it is not working. I ended not using the SD card that came with the kit. Downloaded the image from the PiAware site, and was able to get it up and going still without the display.
I am using the FlightAware image, but did not use the one that was included with the kit.
Have not seen the “SD space” message again, but was able to expand the SDCard space, change the name.
Funny thing was, though I have not tried it since, when I tried the same SD card on a different Raspberry Pi I had, same results. I have not tried it since I got it up and running.
