[Update - my bad, didn’t realize there was another service combine1090-dump that needed to be restarted, found that in another thread on googling some more…]
I just installed combine1090 as I have one main Raspberry Pi with piaware running dump1090-fa feeding FlightAware. One issue is that local airport flights are “too loud” and overload the dongle and cannot be tracked properly. So I have a second Raspberry Pi that I have configured with very low sensitivity, and I put combine1090 on the main receiver so I can get its map with the combined feed and can now see both near and far flights.
However, it appears the JSON_OPTIONS="–json-location-accuracy 2" is not being handled properly by combine1090. It’s behaving as if it is set to 1 as my location is not correct on the map. I have the same setting in both dump1090-fa config files and also the combine1090 config but it is still wrong. I’ve tried adding the lat/lon to combine1090 with no effect either.
Can you please check the logic for handling this value?
Thanks,
Erik
