Changing default port
Noob here and I need some help changing the default port for PiAware or dump1090-mutability.
Currently, am running the following on my Pi4.
  1. PiHole with web interface using lighttpd, defaulted to port 80.
  2. Unifi controller on port 8080 and 18443.
  3. Piaware and dump1090-mutability.
Everything is working fine, except that I am not able to access the local web interface for PiAware/dump1090-mutability as port 8080 has already been used by unifi controller.
I would like to change the default port for PiAware and dump-mutability to something else other than 8080.
How do I do that? Have tried looking through the lighttpd config and the dump1090-mutability config files, but I am totally lost.
If I change the lighttpd config to some other port, then PiHole would not be accessible…
Any help would be appreciated.
If it’s the PiAware image, this should do it;
sudo nano /etc/lighttpd/conf-enabled/89-dump1090-fa.conf
Change 8080 to what ever you like. Press Ctrl+O, [enter] to save, and Ctrl+X the exit the editor.
Restart PiAware;
sudo piaware-config -restart
Hi carstenks,
I have did the above steps, and changed the port to port 18080.
However, after I restart piaware, I am still seeing a page where it shows that pihole is still restricting the page.
SharedScreenshot|690x445
Just to be clear, I have removed dump1090-mutability and installed dump1090-fa.
port 8080 is used by unifi, and it is able to be accessed locally by http://localIP:8080
port 80 us used by Pihole that is running via lighttpd as well.
found my solution to this…
I added the following line in /etc/lighttpd/external.conf
server.modules += (“mod_alias”)
