Hello, just today set up a PiAware and it was found ok, but I have now changed it from wired Ethernet to wifi and changed the config file as instructed to point to my router.
I think the website is still assuming it is on the wired connection and kept the same local IP address so its not actually seeing it…any help appreciated
Did you set a fixed IP for the device in your router? In this case the IP adress will be the same, independent from the used network interface.
Ta FH,
Sorted itself out now and being picked up
