IP Address off 1 digit
I am having a problem with my PiAware setup.
I just did a clean install of version 10.1 on my Pi flightaware.
And now my Site local IP on MY Flightawarwe page doesn’t match my skyaware map page. (Which shows the aircraft
It is 1 digit off.
I can’t change the IP address via my router as they are locked.
Any help would be grateful
Not sure if I’ve got this right - your receiver is working correnctly, but the local IP you can watch skyaware is different to what is displayed on your My Stats page?
If that’s correct, I’d guess you enabled both WiFi and wired lan (which will give the Pi two valid IP’s)
I expect you have created a new site.
You will need to set the feeder-id to the same as your original site. See:
Yep he made a new site indeed (actually 2 new ones)
Found the problem. You ae’re right I had two staions :slight_smile:
