Try two simple things:
- Try after rebootig Pj
- Try another Browser
That worked! I didn’t change browesers but those last updates. That allowed the 1090 extension to work. Any idea on why using port 8080 isn’t working? Not a big deal since we got at least one map to work.
Seems Browser related.
Try several browsers (Firefox, Google Chrome, Internet Explorer, Safari etc), and see how each behaves on these addresses.
ip-of-pi
ip-of-pi:80
ip-of-pi:8080
ip-of-pi/dump1090/
Just out of curiosity, which guide/method you have followed to install dump1090-mutability v 1.15~dev?
Try this:
(1) Open file /etc/default/dump1090-mutability for editing
sudo nano /etc/default/dump1090-mutability
(2) In the file opened, scroll down to this text
# Bind ports on a particular address. If unset, binds to all interfaces.
# This defaults to binding to localhost. If you need to allow remote
# connections, change this.
NET_BIND_ADDRESS="127.0.0.1"
# Misc options
(3) In line NET_BIND_ADDRESS=“127.0.0.1” , delete 127.0.0.1 (leave quotes “”).
The line will now be like below:
NET_BIND_ADDRESS=""
(4) Save (Ctrl+o) and Close (Ctrl+x)
(5) Restart dump1090-mutability
sudo systemctl restart dump1090-mutability
(6) Open browser, type ip-of-pi:8080, clear cache (Ctrl+Shift+Delete) and Reload (Ctrl+F5).
And I’ve done some playing with this router. When I have my network inspection at normal it won’t allow the connection to dump1090. When I turn it off I can connect to it. And it’s the same for all of my devices, I might be having to change the router out. I’ll run those last comands when i get home later tonight and see what they pull. Apologies for being slow, got locked out on reply’s cause I’m new.
So I ran through it all, it seems to be the router. I don’t need to get into those ports now that I have dump1090 working. Thank you very much for all of your help.
I am running Flight Feeder. No airplanes visible on skyview.
Am tracking and reporting - however - at about half usual level.
About a dozen uplink blackouts in last several days.
