Whew!! I was gonna make a quick summary but there are quite a few “incidents”.
That plane has definitely had some bugs over the years but still seems to be hard to land. There are an awful lot of hard landings and tail strikes in the database as well as other control issues. I’ve never compared them to another aircraft but it does seem high.
Here’s the summary I have so far, not complete but will continue to update it,
08/92 - Delta Air Lines - tail strike at Los Angeles, crew error, improper control use
09/92 - McDonnell-Douglas test flight - hard landing at Yuma, center gear collapsed
12/92 - China Airlines - upset in cruise flight, turbulence cited
02/93 - Viaco Aerea - hard landing at San Francisco, 7 tires blown
04/93 - Delta Air Lines - hard and bounced landing at LAX, nosewheel damage, crew error, improper flare
04/93 - China Eastern - upset in flight, slats accidentally deployed, pilot error, 60 serious, 2 fatal
06/94 - American Airlines - upset in cruise flight, crew error, accidentally bumped control, 15 minor, 2 serious
08/94 - Alitalia - hard 1.95g landing and tail strike at ORD, crew error, improper flare
11/94 - Fedex - hard landing and tail strike at ANC, crew error, unstabilized approach
04/95 - American Airlines - evacuation at JFK from reported fire #2 engine, 33 minor, 2 serious
06/95 - China Airlines - emergency landing smoke in the cockpit, faulty insulation in radio bay
05/96 - Fedex - hard landing and tail strike at ANC, wake turbulence from previous 747 cited
05/96 - Korean Air - tail strike at LAX, crew error, speed too low on final
06/96 - World Airways - overran runway on landing at Buenos Aires
07/96 - American Airlines - pitch oscillations in descent, max 2.28g loads, capt overrode a/p, 1 serious
04/97 - Garuda Indonesia - over ran runway landing at Jakarta
06/97 - Garuda Indonesia - tail strike on landing at Honolulu, crew error, improper use of autoland
06/97 - Japan Air Lines - upset in cruise, autopilot cited, 9 minor, 12 serious, 1 fatal
07/97 - Fedex - hard landing at EWR, gear collapsed, aircraft flipped, crew error, over control, 5 minor
10/97 - World Airways - tail strike on landing at Montevideo, Uruguay
06/98 - Japan Air Lines - slid off left side of wet runway landing at Manila, 7 minor
07/98 - LTU Int’l - rejected takeoff at Palma Mallorca, erroneous speed warning
09/98 - Swissair - on board fire, improper additional wiring, 229 fatal
09/98 - China Eastern - emergency landing with nose gear retracted, 9 minor
10/98 - Delta Air Lines - electrical burning smell in cockpit in cruise flight, diverted to Shannon
11/98 - Swissair - smoke in cockpit on climb out from Singapore, emergency landing
11/98 - Delta Air Lines - tail strike on landing at Portland, crew error, incorrect approach speed
12/98 - China Eastern - tail strike on landing at Shanghai
01/99 - American Airlines, smoke in the cabin, emergency landing Seattle
03/99 - World Airways, evidence of fire in cargo floorboards while performing C check, defective wiring found
04/99 - Korean Air - flight dove into ground, crew error, 37 injured, 9 fatal
06/99 - Fedex - damaged elevator after a GPWS pull up descending into Manila
08/99 - China Airlines - landing accident Hong Kong, flipped, exceeded crosswind specs, 44 serious, 3 fatal
08/99 - China Eastern - departed runway on landing at Shanghai, substantial damage
09/99 - World Airways - hard and bounced landing at Shannon, then runway over run
10/99 - Fedex - landing overun at Subic Bay, excessive speed, failed indicator and clogged pitot tube, 2 minor
10/99 - Fedex - center gear collapsed on landing at Newark, examination found evidence of overload
11/00 - Fedex - pitch oscillations in cruise flight, failed elevator solenoid
11/01 - Eva Air - hard landing at Taipei, nose gear and tire damage
02/02 - Fedex - tail strike landing Subic Bay, mechanical failure left inboard flap
02/02 - Delta Airlines - off side of runway landing at Dublin, wind 15 knots gusting 27 knots
03/02 - Delta Airlines - faulty wiring, engine fire warning, emerg landing w/ minor damage, 11 minor, 5 serious
05/02 - Fedex - windshield fire from heating element at SEA during pushback
06/02 - Fedex - flight control malfunction into Subic Bay, diverted to Manilla and suffered tail strike.
06/02 - Fedex - damaged elevator from 2.2g GPWS maneuver to landing at Subic Bay
01/03 - Alitalia - landed at JFK with jammed ailerons, potable water dripped on cables freezing them
05/03 - Gemini Cargo - runway over run at JFK, crew error, landed long and tail wind
01/04 - Varig - tail strike on landing at Mexico City
01/04 - Varig - off side of wet runway landing at Fortaleza, Brazil
09/04 - Fedex - hard landing and bounce at MEM, suffered tail strike on go around
10/04 - World Airways - tail strike on take off at ANC, 2 engine ferry, operator CG error
04/05 - World Airways - smoke in cockpit, faulty door lock actuator installation
06/05 - UPS - hard landing in Anchorage
06/05 - UPS - nose gear collapsed on landing at Louisville, crew error, derotation too fast
06/06 - Varig - center gear fracture landing at Brasilia
09/06 - Fedex - hard landing and tail strike at Subic Bay
11/06 - Fedex - center gear drag brace failed after landing at Paris
04/08 - Fedex - center gear cylinder found cracked at Singapore
03/09 - Fedex - hard landing & bounce Narita, left gear collapsed, aircraft flipped, 2 fatal
06/09 - China Cargo - hard landing and tail strike at Urumqi, China
06/09 - Saudi Arabian Cargo - hard landing in Khartoum, Sudan, substantial damage
09/09 - Lufthansa Cargo - hard landing at Mexico City, fuselage and nose gear damage
10/09 - Centurion Air Cargo - hard landing in Montevideo, Uruguay, right gear collapsed
11/09 - Fedex - smoke in cockpit during cruise, emergency landing
11/09 - Avient - runway over run from take off at Shanghai, 3 fatal
